Gary Emerson wrote:
Martin Gregorie wrote: wrote: This is great discussion. I was doing a bit of research myself (it has been over 10 years since I did any HW design, so am pretty rusty). Another option that sounds even better is to use the new chips designed for exactly this to control DirectFETs. That way the voltage drop and power waste will be significantly reduced with very little additional cost. The chips I were looking at were IR5001S: http://www.irf.com/product-info/data...ta/ir5001s.pdf or LT4351: http://www.linear.com/pc/productDeta...,C1079,P21 73 I have used DirectFET stuff in robotics and found them to be very reliable and very simple to design with. My biggest problem is all these components are only available in surface mount these days and I have never tried to build a circuit using them. That should be easy enough to do with a pair of suitable power MOSFETs and an LM358 dual op-amp to control the MOSFETs. If I don't split my supply (see earlier post) I'm thinking about making this type of circuit this because the voltage drop in the MOSFET will be very small. Size isn't an issue - suitable MOSFETs are in TO-220 type packages and the LM358 is an 8 pin DIP package. How much lower thatn 0.3V drop will the MOSFETs get you? The forward resistance is around 0.015 ohms (HUF75337P3, 62A, 55V, TO220 package), so at 5amps that's a 75 mV drop. That looks like a worthwhile improvement. The MBR1035 was the lowest drop type (0.6v drop) I could find at RS Components or Maplins, the only two decent retail outlets in the UK. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Lew Hartswick wrote:
Gary Emerson wrote: With 18Amps of forward current capability (each), there isn't really any "need" for the two diodes in parallel, but for an extra $5 and a few extra minutes of wiring, if any one diode ever did fail "open" the other would still provide power. Most likely overkill. Yes because most often (probably at least 90% of the time) a diode fails "short" Therefore you may be reducing the reliability. :-) ...lew... Fail "short" won't leave you without power on a flight. Fail "open" might... |
Electric maned airplane | Flyingmonk | Piloting | 26 | July 20th 06 05:43 AM |
Electric maned airplane | Flyingmonk | Home Built | 26 | July 20th 06 05:43 AM |
Becker AR-3201 radio owners: check your batteries | sssarah | Soaring | 3 | May 24th 06 07:40 AM |
Switching Batteries Advice? | ContestID67 | Soaring | 17 | January 12th 06 01:02 AM |
Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 04:30 PM |
