#21
Morgans wrote
So, fixing the mounts and stiffening the wings was the only thing that was changed; no different operating procedures? The "old" Electras that I flew at Air Florida did have a speed limit imposed by the FAA. I have forgotten just what it was...34 years ago. Bob Moore |
Bob Moore wrote:
The Electra (L-188) engine (Allison) always turned at 1061 RPM except at ground idle. It had no Prop Control. C'mon Bob, I seriously doubt the *engine* ran at 1061 RPM! ![]() Happy Flying! Scott Skylane |
"Scott Skylane" wrote in message ... Bob Moore wrote: The Electra (L-188) engine (Allison) always turned at 1061 RPM except at ground idle. It had no Prop Control. C'mon Bob, I seriously doubt the *engine* ran at 1061 RPM! ![]() Why not? It is a turbine engine, after all. -- Jim in NC |
Morgans wrote:
"Scott Skylane" wrote in message ... Bob Moore wrote: The Electra (L-188) engine (Allison) always turned at 1061 RPM except at ground idle. It had no Prop Control. C'mon Bob, I seriously doubt the *engine* ran at 1061 RPM! ![]() Why not? It is a turbine engine, after all. That would make it even more surprising. That would be extremely slow for a turbine. It isn't bad for a large piston engine, but still on the slow side. Matt |
"Scott Skylane" wrote in message ... Bob Moore wrote: The Electra (L-188) engine (Allison) always turned at 1061 RPM except at ground idle. It had no Prop Control. C'mon Bob, I seriously doubt the *engine* ran at 1061 RPM! ![]() Happy Flying! Scott Skylane Well, the output shaft & prop did. As I remember there was about an 11:1 reduction from the turbine. Al G VP-48 Crew 6 Moffat/Adak/Agana |
"Matt Whiting" wrote That would make it even more surprising. That would be extremely slow for a turbine. It isn't bad for a large piston engine, but still on the slow side. Note to self: remove egg from face. g I finally saw it. I was looking at it and sseing 10,610 RPM, or something like that. Perhaps that is prop speed, at 1,061 RPM ? -- Jim in NC |
Morgans wrote:
"Matt Whiting" wrote That would make it even more surprising. That would be extremely slow for a turbine. It isn't bad for a large piston engine, but still on the slow side. Note to self: remove egg from face. g I finally saw it. I was looking at it and sseing 10,610 RPM, or something like that. Perhaps that is prop speed, at 1,061 RPM ? That would make a lot of sense. 1,000 RPM for a large prop would be plenty fast. Matt |
#28
john smith wrote:
Jack Allison's discussion of the Hartzell AD for his Arrow has gotten me to thinking. What aircraft do you fly/have you flown/do you have first hand knowledge of which have a red zone somewhere in the green arc of the tachometer? For example, I know there are/were certain models of Cessna 210's that had such markings, but I cannot remember the specific models/engine/prop combinations. I have a modified Cessna 172 with the Lycoming O-360-A1A engine and Hartzel prop. I have a redline limitation between 2100 and 2250 rpm. Really stinks. -- Regards, Ross C-172F 180 hp KSWI |
#29
Although there is red marking in the green arc, the POH for the 1979
Piper Turbo Arrow IV/PA28RT-201T, the LIMITATIONS SECTION lists the following placards: AVOID CONTINUOUS GROUND OPERATION 1700-2100 RPM IN CROSS/TAIL WIND OVER 10 KTS. AVOID CONTINUOUS OPERATION 2000-2200 RPM ABOVE 32" MANIFOLD PRESSURE I believe this applies to the two-bladed prop only and not the three-bladed prop, but I can find nothing in the manual to support this theory. I do not find the placards on the panel of the aircraft I fly which has the three-bladed prop. These two lines in the LIMITATIONS SECTION are the only place in the POH which mention this condition. |
#30
Morgans wrote
Perhaps that is prop speed, at 1,061 RPM ? Obviously.... :-) Bob Moore |
| Thread Tools | |
| Display Modes | |
| Verdant green... | Jay Honeck | Piloting | 17 | July 9th 06 07:58 AM |
| Military Green Laser Pointer | [email protected] | Naval Aviation | 0 | July 5th 05 07:42 PM |
| Simple Green Pirep | JJS | Owning | 13 | May 19th 05 04:35 AM |
| I am in The Killing Zone | Marco Rispoli | Piloting | 68 | June 14th 04 06:16 PM |
| Garmin gpsmap 76s airspace zone home made maps (follow up) | Gilles_Sauvagnat | Soaring | 0 | May 13th 04 09:41 PM |
