![]() Jay Honeck wrote: Setting up the over-lap between the screens so that it doesn't look weird must be a tricky affair, indeed. Sorry abbout piggy-backing this on Margy - Jay's post was gone. You could see where the projector's image ends on the screen and mask and paint a thin black line on the screen. That would make overlap a non issue, and be a minimal distraction. That would be the easy way out. (Gears turning...where can I mount a curved screen? Whey can I even *buy* a curved screen? :-) Get some bulk screen material, and sew a flap on the bottom and the top of the material. Get some thin wall electrical conduit, and bend the appropriate radius in the tube, with a top and bottom matching tube. You would want to weld the joints, instead of using a connector. If you weld it yourself, be sure to not breath the fumes, because the galvanized pipe welding fumes will give you a very nasty headache, just for starts. To mount it, make brackets to screw to the tubes, and fasten them on after the screen has been streached on, so the screen will se the same tension everywhere. To make it somewhat portable, use some spreaders from the top to bottom tube, mounted the same way, but mounted so they will be back away from the screen. A mounting from the bottom to the floor could have some casters, so you could roll it out of the way. I'm not sure, but I think for the best results, a special lens would need to be used, or a program to get the right aspect ration projected onto the screen. Even then, I'm not so sure that it would be projected in focus without a special lens, since the distance from the lens to a flat screen is different (longer) at the sides of the picture as compared to the center of the picture. With the curved screen, it would be the same distance on the edges and the center. -- Jim in NC |
I'll bet it would be more in focus. I don't think lenses are designed to take the straightness of a screen into account, and we just put up with blurry edges and a sharper donut. Jose -- Humans are pack animals. Above all things, they have a deep need to follow something, be it a leader, a creed, or a mob. Whosoever fully understands this holds the world in his hands. for Email, make the obvious change in the address. |
On Thu, 08 Feb 2007 20:41:38 -0500, Margy Natalie
wrote: Jay Honeck wrote: I see three projectors. Unless they have very special lenses indeed, I don't see how they can project clear images onto curved screens. Setting up the over-lap between the screens so that it doesn't look weird must be a tricky affair, indeed. (Gears turning...where can I mount a curved screen? Whey can I even *buy* a curved screen? :-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" http://www.e-planetarium.com/ You can run movies in them too. They are called planetariums:-)) There they build the curved surface and then spraypaint the reflective surface on it. Margy Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
On Dec 30 2006, 8:29 am, "Jay Honeck" wrote:
I see three projectors. Unless they have very special lenses indeed, I don't see how they can project clear images onto curved screens. Setting up the over-lap between the screens so that it doesn't look weird must be a tricky affair, indeed. (Gears turning...where can I mount a curved screen? Whey can I even *buy* a curved screen? :-) Jay - see http://www.panoramtech.com/resource/spie1.html about complex projection surfaces and multiple projectors - the theory behind it also: http://www.vistasystems.net/ for boxes that do it..... Randy |
16 Mar 2006 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | March 17th 06 12:39 AM |
30 Jan 2006 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | January 31st 06 03:21 AM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
30 Jan 2004 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | January 31st 04 03:55 AM |
Local TV News ran an accurate story about airframe icing last night | Peter R. | Piloting | 5 | January 29th 04 01:01 AM |
