![]() "tom" wrote in message oups.com... I fly a homebuilt Savannah (there are quite a few flying in Oz) and if the pilot weighs less than about 120 pounds, and the fuel is nearly exhausted, the CG is just slightly forward of the envelop. tom Tom, do you carry some ballast to correct this? I know nobody plans to run out of fuel but if it happened , say from a fuel leak, I would hate to be worrying about an off field landing with a forward cg. terry d&tm wrote: Are there any single engine airplanes out there that really can go outside the envelope by burning fuel? Terry PPL downunder |
I weigh 170, so the only ballast I carry is around my ass. 8^)
tom d&tm wrote: "tom" wrote in message oups.com... I fly a homebuilt Savannah (there are quite a few flying in Oz) and if the pilot weighs less than about 120 pounds, and the fuel is nearly exhausted, the CG is just slightly forward of the envelop. tom Tom, do you carry some ballast to correct this? I know nobody plans to run out of fuel but if it happened , say from a fuel leak, I would hate to be worrying about an off field landing with a forward cg. terry |
oups.com... I weigh 170, so the only ballast I carry is around my ass. 8^) tom "Does this airplane make me look fat...?" ;O) Jay B |
Only when I fly naked.
tom Jay Beckman wrote: "tom" wrote in message oups.com... I weigh 170, so the only ballast I carry is around my ass. 8^) tom "Does this airplane make me look fat...?" ;O) Jay B |
d&tm wrote:
Are there any single engine airplanes out there that really can go outside the envelope by burning fuel? ( I am only interested in the normal ategory - not utility). Perhaps the training is just to prepare you for heavy aircraft? I believe Bonanzas can have this problem in certain configurations. It depends on which where the CG is. If you've got an aft CG and burning fuel drives it more aft, you've got problems. In my plane, we typically sit on the forward CG limit with the tanks full. Since the envelope is sloped on the forward CG side (the limit moves aft as you go up in gross weight), even as the CG moves forward with fuel burn, you're also getting lighter so the CG limit is moving forward faster. |
![]() "Ron Natalie" wrote in message ... d&tm wrote: Are there any single engine airplanes out there that really can go outside the envelope by burning fuel? ( I am only interested in the normal ategory - not utility). Perhaps the training is just to prepare you for heavy aircraft? I believe Bonanzas can have this problem in certain configurations. It depends on which where the CG is. If you've got an aft CG and burning fuel drives it more aft, you've got problems. In my plane, we typically sit on the forward CG limit with the tanks full. Since the envelope is sloped on the forward CG side (the limit moves aft as you go up in gross weight), even as the CG moves forward with fuel burn, you're also getting lighter so the CG limit is moving forward faster. Similar to the Warrior. but you can barely get enough wt in the front to reach the forward limit. expecially when I am one of them ( 180 lbs). But it is just possible with a couple of sumu wrestlers and less than full fuel to exceed the forward limit, in this case burning fuel actually brings you back in bacause as you say the cg moves forward but the limit moves forward faster at lower wt. What is your plane John? terry PPL downuder |
d&tm wrote:
Are there any single engine airplanes out there that really can go outside the envelope by burning fuel? The Bonanza is the big example that comes to mind. The moment of the Fuel is forward of the main spar and as you burn your fuel off, the CG moves aft. If you have the 5th and 6th seats filled or have lots of aft baggage, you can end up aft of limits, which can bite when you are low/slow on approach. Dave |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Running dry? | Greg Copeland | Piloting | 257 | August 26th 05 03:47 PM |
"Tanks on both" checklist item | Koopas Ly | Piloting | 46 | December 12th 03 03:42 PM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
Hot Starting Fuel Injected Engines | Peter Duniho | Piloting | 23 | October 18th 03 02:50 AM |
