When I listen to real ATC on liveatc.net, it sounds just as bad. The
quality problems aren't the same, but their magnitude is. I'm surprised more aircraft aren't running into each other. I can only hope that the audio quality is much better aboard the actual aircraft, but I doubt it. My experience is that controllers are always pretty clear, although they may talk rapid fire. I think this is because controllers have good headsets.. not much background noise, and powerful (?) ground based transmitters. As opposed to pilots who have lots of noise around them. For someone like me that is more visual than auditory (it sounds like you are similar) it takes practice to be able to visualize what I just heard. It helps that for almost everything it follows a very standard format (and controllers are good at following that format) as opposed to us pilots that tend to try it on the cool, i.e. "uh, up from 4 for 5.2" etc. Those Don Brown columns I pointed you to earlier has a whole bunch of columns on phraseology and its usefuleness for safety. Do you listen to Vatsim on a headset? Might make it easier. |
![]() "Mxsmanic" wrote in message ... Anyway, so I can just say "request descent" when I'm ready to start down? Affirm, exactly that. And if you are not going to collide against another aircraft or terrain, they usually clear you to descend. Gus Cabre EGYC |
Gus Cabre writes:
Affirm, exactly that. And if you are not going to collide against another aircraft or terrain, they usually clear you to descend. I'll try that, then. Is there any difference between "request descent" and "request lower"? Can I be more specific, like "request descent to cross BUBBL at 12000" (if the FMC is trying to do that)? -- Transpose mxsmanic and gmail to reach me by e-mail. |
You can always ask. If it is not convenient they will tell you. They might
clear you to descend at a different waypoint or "not before XYZ". Gus EGYC "Mxsmanic" wrote in message ... Gus Cabre writes: Affirm, exactly that. And if you are not going to collide against another aircraft or terrain, they usually clear you to descend. I'll try that, then. Is there any difference between "request descent" and "request lower"? Can I be more specific, like "request descent to cross BUBBL at 12000" (if the FMC is trying to do that)? -- Transpose mxsmanic and gmail to reach me by e-mail. |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1 Okay.. KLAX LOOP4.DAG.KEPEC1 KLAS at FL290? I'll actually give an objective tutorial on this, as it's in the sector I'm affiliated with and do most of my time in. Also as I am doing this objectively, anyone else who would like to objectively chime in, please do so. Look CLOSELY at those charts, and I mean closely. There are some things you will need to adhere to that your FMS may or may not know about that is not depicted totally in words. CAVEAT. the charts I'll list are not to be used for real world flight. LOOP4: http://www.laartcc.org/charts/DP-LOOP.pdf KEPEC1: http://www.laartcc.org/arrivals/STAR-KEPEC.pdf KLAS ILS 25L: http://www.laartcc.org/charts/KLAS-I25L.pdf I suggest looking at the KEPEC1 first before the LOOP4. Yes, it's the arrival and you haven't even departed yet, but you are in the flight planning stage at this moment, and there is something important that needs to be learned. The KEPEC1 arrival is an RNAV procedure, requiring RNAV-capable equipment. Aircraft that are /E, /F, /G, and /R are RNAV capable. If said aircraft is RVSM capable, then the following suffixes apply: /J, /K, /L, /Q (FAAO 7110.65, 2-3-7). If your aircraft is not one of then your flight plan will be rejected because you can not use the KEPEC1 arrival. LOOP4. If your aircraft is not capable of climbing at 500ft per nautical mile to 10000, you're using the wrong SID. LOOP4 requires it. I'm going to assume that you a) have RNAV and RVSM capable equipment onboard and your aircraft is able to meet the climbing requirement, and that you are familiar with ATC in the terminal area. You've received your clearance, and will be cruising at FL290. Great. ATC clears you to takeoff on 24L. You best look at the LOOP4 chart again, as you have 2 crossing restrictions you must meet. You must cross the SMO R-160 at or below 3000ft. From there, you should get vectors back to LAX with something being told to you like: "Turn left direct Los Angeles, resume the LOOP4 departure, comply with all restrictions, climb and maintain 15000". You do exactly that. Your restrictions are to cross LAX at or above 10000, KEGGS at or above 13000, and COOPP at or above 15000. Sometime at that point you'll be handed to the Center controller who will climb you to your cruise altitude. That ends the use of LOOP4 unless you end up NORDO for some reason. Now, you're en route, and you're ready for the arrival. You're still at FL290. Staying that high until your FMS starts to descend is really going to increase your descent rate, as well as try its hardest to maintain a slow speed for your descent. Not good. Also, the DAG/HEC corridor is one of the busiest streams in US Airspace. Just about every arrival into the LA Basin passes in that corridor, and all northeastbound flights leave the basin through that corridor. You may have a flight which ATC has positively separated you from, laterally and vertically. It is best to let them control your descent instead of asking. ATC should tell you something like the following: "Cross MISEN at and maintain FL240". If you look at KEPEC1, you have a segment there where you have a crossing restriction at MISEN of FL240 or higher. The closer you are to that, the easier your descent will be for your next crossing restriction, which is CLARR. ATC will tell you this: "Cross CLARR at and maintain 13000 and 250kts. Las Vegas altimeter xx.xx". From here, you'll be descending and reducing speed for the arrival, and must hit CLARR at that altitude and speed. From there, the arrival tells you everything you need to do. Should ATC have you execute the full arrival, they will tell you something like: "Descend via the KEPEC1 arrival". That's it. From there, you're crossing KEPEC below 13000 and above 12000, IPUMY below 12000 and above 1000, NIPZO above 9000 and below 1000, SUNST at 8000 and 210kts, KIMME at 210kts, CHIPZ at 170kts. Look now at the ILS 25L chart. You'll notice that the altitude you're at by the time you hit PRINO is the same altitude you should be at for executing the ILS approach from PRINO. So ATC should only have to tell you: "After PRINO, cleared ILS 25L approach". No PTAC is needed, as the RNAV arrival drops you off directly on the IAF for the approach. From there, follow the chart down. 8000 or above at PRINO, 6500 or above at LARRE, 4900 or above at SHAND, 3800 or above at RELIN. In short, like everyone else has mentioned, just because your FMS thinks it's okay to descend, doesn't mean that it's kosher with ATC for you to descend. They may have other things impending your descent. When in doubt, ask. The worst you'll get back is 'no', and a reason for why you can't at that time. BL. - - -- Brad Littlejohn | Email: Unix Systems Administrator, | Web + NewsMaster, BOFH.. Smeghead! ![]() PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.6 (GNU/Linux) iD8DBQFFnCBXyBkZmuMZ8L8RAnh7AKDKuOLSIDNqR14KTgvPcQ xjTmg+0gCfT7n6 cnVQ34bLprbBOctBe7NLTL8= =zQYN -----END PGP SIGNATURE----- |
A Guy Called Tyketto writes:
Okay.. KLAX LOOP4.DAG.KEPEC1 KLAS at FL290? Yes. I'll actually give an objective tutorial on this, as it's in the sector I'm affiliated with and do most of my time in. OK. I often take my routes directly from FlightAware, so that I'm flying the same routes people fly in real life. If I'm staying within SoCal, I also use TEC routes. Look CLOSELY at those charts, and I mean closely. Which charts? I have VFR sectionals and TACs, plus SIDs, STARs, and instrument approach plates, but no IFR charts. I suggest looking at the KEPEC1 first before the LOOP4. Yes, it's the arrival and you haven't even departed yet, but you are in the flight planning stage at this moment, and there is something important that needs to be learned. The KEPEC1 arrival is an RNAV procedure, requiring RNAV-capable equipment. Aircraft that are /E, /F, /G, and /R are RNAV capable. If said aircraft is RVSM capable, then the following suffixes apply: /J, /K, /L, /Q (FAAO 7110.65, 2-3-7). If your aircraft is not one of then your flight plan will be rejected because you can not use the KEPEC1 arrival. The aircraft is RNAV-capable, but I will grant that I didn't notice that it was RNAV. I just look at the fixes and so on most of the time, knowing that ATC will probably tell me to do something different, anyway. LOOP4. If your aircraft is not capable of climbing at 500ft per nautical mile to 10000, you're using the wrong SID. LOOP4 requires it. The aircraft is capable of this. I'm going to assume that you a) have RNAV and RVSM capable equipment onboard and your aircraft is able to meet the climbing requirement, and that you are familiar with ATC in the terminal area. Yes, it's a BBJ2 or 737-800, and I know ATC a little in the area, as I fly around there a lot. You've received your clearance, and will be cruising at FL290. Great. ATC clears you to takeoff on 24L. Yes. More specifically, I was told to climb and maintain 5000. Departure told me to climb and maintain 15000 (IIRC) and to proceed direct LAX, which I did. You best look at the LOOP4 chart again, as you have 2 crossing restrictions you must meet. You must cross the SMO R-160 at or below 3000ft. I believe the FMC knew that, although I wasn't watching to see. ATC had already told me to climb and maintain 5000, which I assumed overrode all other instructions. From there, you should get vectors back to LAX with something being told to you like: "Turn left direct Los Angeles, resume the LOOP4 departure, comply with all restrictions, climb and maintain 15000". I was told proceed direct LAX, climb and maintain 15000. No mention of restrictions, though. Had ATC said that, I probably would have looked back at the plate to see (although the restrictions are mostly coded into the FMC's database). In reality, all I really did was dial 15000 into the MCP, letting the FMC continue its climb, and I plugged LAX into the FMC as the current leg, forcing it to proceed to LAX directly (LAX was the next leg, anyway). You do exactly that. Your restrictions are to cross LAX at or above 10000, KEGGS at or above 13000, and COOPP at or above 15000. Sometime at that point you'll be handed to the Center controller who will climb you to your cruise altitude. That ends the use of LOOP4 unless you end up NORDO for some reason. I was handed to Center, which then told me to climb and maintain FL290. Now, you're en route, and you're ready for the arrival. You're still at FL290. Staying that high until your FMS starts to descend is really going to increase your descent rate, as well as try its hardest to maintain a slow speed for your descent. Not good. I recall stepping through the legs looking for anything that seemed like a steep descent and possibly tweaking some legs, although I don't remember the details. What I do remember is that I reached the top of my descent and the FMC started down, then ATC called me and asked why I was low. So I reset the MCP to FL290 and went back up. Seconds later, Center told me to cross something at something (I don't remember what now). My guess was that he forgot that I'd be starting my descent and remembered when he saw me descending, so he called me on it and then cleared me down. Also, the DAG/HEC corridor is one of the busiest streams in US Airspace. It's extremely busy even in the virtual US airspace. The difference in the simulated world is that pilots look for heavy traffic, whereas I presume they aren't so thrilled about it in real life. Just about every arrival into the LA Basin passes in that corridor, and all northeastbound flights leave the basin through that corridor. You may have a flight which ATC has positively separated you from, laterally and vertically. It is best to let them control your descent instead of asking. Fine with me. I just wasn't sure about whether I was supposed to start on my own or wait to be cleared down. ATC should tell you something like the following: "Cross MISEN at and maintain FL240". I recall something like that, but I don't remember the fix or altitude. If you look at KEPEC1, you have a segment there where you have a crossing restriction at MISEN of FL240 or higher. The closer you are to that, the easier your descent will be for your next crossing restriction, which is CLARR. ATC will tell you this: "Cross CLARR at and maintain 13000 and 250kts. Las Vegas altimeter xx.xx". Yes, I recall getting that. From here, you'll be descending and reducing speed for the arrival, and must hit CLARR at that altitude and speed. I recall some trouble hitting the descent, but I tweaked it and arrived at the right altitude and speed. I think starting the descent late messed it up. From there, the arrival tells you everything you need to do. Should ATC have you execute the full arrival, they will tell you something like: "Descend via the KEPEC1 arrival". Unfortunately, they vectored me around, and then told me to follow some traffic going the opposite way (towards the airport, whereas I was still headed east). I messed up so much fiddling with the FMC and autopilot that I couldn't follow the other guy in, so I had to go around. Then it was more vectors, and following someone else in. I gave up on the AP and flew by hand towards the other aircraft, then intercepted the localizer and configured everything for a nice autoland. That's it. From there, you're crossing KEPEC below 13000 and above 12000, IPUMY below 12000 and above 1000, NIPZO above 9000 and below 1000, SUNST at 8000 and 210kts, KIMME at 210kts, CHIPZ at 170kts. Yeah, if ATC doesn't send me hither and yon instead. Look now at the ILS 25L chart. You'll notice that the altitude you're at by the time you hit PRINO is the same altitude you should be at for executing the ILS approach from PRINO. So ATC should only have to tell you: "After PRINO, cleared ILS 25L approach". I think ATC was looking to have more fun. In simulation, ATC, like pilots, tends to look for challenges rather than seeing traffic and complexity as undesirable. No PTAC is needed, as the RNAV arrival drops you off directly on the IAF for the approach. From there, follow the chart down. 8000 or above at PRINO, 6500 or above at LARRE, 4900 or above at SHAND, 3800 or above at RELIN. I wish. In short, like everyone else has mentioned, just because your FMS thinks it's okay to descend, doesn't mean that it's kosher with ATC for you to descend. They may have other things impending your descent. When in doubt, ask. The worst you'll get back is 'no', and a reason for why you can't at that time. OK. I will ask next time. I have yet to do an approach (in the presence of ATC) that followed the plates, though. Somebody always wants me to do something different. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Hash: SHA1 Mxsmanic wrote: A Guy Called Tyketto writes: Look CLOSELY at those charts, and I mean closely. Which charts? I have VFR sectionals and TACs, plus SIDs, STARs, and instrument approach plates, but no IFR charts. I just told you. LOOP4, KEPEC1, ILS 25L at KLAS. Those are also charts. The aircraft is RNAV-capable, but I will grant that I didn't notice that it was RNAV. I just look at the fixes and so on most of the time, knowing that ATC will probably tell me to do something different, anyway. You should look at those, because if you choose the wrong chart, and your equipment can't support the chart you're filing, you'll be given another SID/STAR to use. Yes, it's a BBJ2 or 737-800, and I know ATC a little in the area, as I fly around there a lot. You best look at the LOOP4 chart again, as you have 2 crossing restrictions you must meet. You must cross the SMO R-160 at or below 3000ft. I believe the FMC knew that, although I wasn't watching to see. ATC had already told me to climb and maintain 5000, which I assumed overrode all other instructions. If you lost your FMC, what would you do? You just can't let your instruments do everything for you the moment you rotate. I'd fathom to see what would happen if you were a /A and didn't have an FMC. Now, you're en route, and you're ready for the arrival. You're still at FL290. Staying that high until your FMS starts to descend is really going to increase your descent rate, as well as try its hardest to maintain a slow speed for your descent. Not good. I recall stepping through the legs looking for anything that seemed like a steep descent and possibly tweaking some legs, although I don't remember the details. What I do remember is that I reached the top of my descent and the FMC started down, then ATC called me and asked why I was low. So I reset the MCP to FL290 and went back up. Seconds later, Center told me to cross something at something (I don't remember what now). My guess was that he forgot that I'd be starting my descent and remembered when he saw me descending, so he called me on it and then cleared me down. I doubt it. There's two places where the Center controller could give you the crossing restriction; one at MISEN, the other at CLARR. If he gave you the one at MISEN (which I know he did), it would make the CLARR crossing restriction a lot easier to make. "Cross CLARR at and maintain 13000 and 250kts. Las Vegas altimeter xx.xx". Yes, I recall getting that. "Descend via the KEPEC1 arrival". Unfortunately, they vectored me around, and then told me to follow some traffic going the opposite way (towards the airport, whereas I was still headed east). I messed up so much fiddling with the FMC and autopilot that I couldn't follow the other guy in, so I had to go around. Then it was more vectors, and following someone else in. I gave up on the AP and flew by hand towards the other aircraft, then intercepted the localizer and configured everything for a nice autoland. They had visual approaches in use. Also, it has been said befo 99.9% of all landings are hand flown, not autolanding, unless on a Cat III ILS approach. ILS 25L is not CATIII. OK. I will ask next time. I have yet to do an approach (in the presence of ATC) that followed the plates, though. Somebody always wants me to do something different. It could be because visual approaches may be in use over using an instrument approach. It provides more flexibility with ATC, plus puts separation responsibility back on the pilot. If you were following traffic, and you were coming in too fast and had to go around, that may not be ATC's fault. There would be some things you could have done to slow your speed down. BL. - - -- Brad Littlejohn | Email: Unix Systems Administrator, | Web + NewsMaster, BOFH.. Smeghead! ![]() PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.6 (GNU/Linux) iD8DBQFFnFyxyBkZmuMZ8L8RAlRPAJ46F/N4zOsSv1e6XGhgEKxPzl4IIQCfciYC xuJph8+VuIj1wpVcmleP2to= =LYDq -----END PGP SIGNATURE----- |
