A Guy Called Tyketto writes:
Not often. For the most, visual approaches are used over ILS approaches. When cleared for the visual approach, you won't be using autoland, as you won't be on an ILS approach, regardless of if you join the localizer and track it. You're still on the visual approach. Yes, from a regulatory standpoint. But I can still configure for autoland. It looks like any other landing from the tower, heh heh. Anyway, the usual reason for this is that I'm working on the systems and procedures, and not on the actual flying of the aircraft. If I want to practice flying it, I set up a different flight. Sometimes I just fly offline for practice in flying skills, since I don't need ATC for that. Exercises like flying holds by hand or by autopilot, touch and go landings, etc. I do this more in the Baron than in the 737. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Not often. For the most, visual approaches are used over ILS approaches. When cleared for the visual approach, you won't be using autoland, as you won't be on an ILS approach, regardless of if you join the localizer and track it. You're still on the visual approach. I'm kind of surprised that ATC so often goes with visual approaches for IFR flights. Wouldn't it be more straightforward to funnel everyone into ILS approaches, given that they are already IFR? -- Transpose mxsmanic and gmail to reach me by e-mail. |
A Guy Called Tyketto wrote:
Not often. For the most, visual approaches are used over ILS approaches. When cleared for the visual approach, you won't be using autoland, as you won't be on an ILS approach, regardless of if you join the localizer and track it. You're still on the visual approach. That just isn't so. Jet aircraft are required to remain on, or above, the ILS G/S whether on an ILS approach or on a visual approach. At the company I worked for, failure to tune and identify the ILS for a visual approach to an ILS runway was a check-ride bust. As to autoland, most of them are down in good weather for proficiency and to maintain certification of the airborne equipment. Autolands can (and are) even be practiced on visual approaches provided the ILS is intercepted prior to the PFAF. |
![]() -----Original Message----- From: Mxsmanic ] Posted At: Thursday, January 04, 2007 3:23 AM Posted To: rec.aviation.ifr Conversation: Confusion about when it's my navigation, and when it's ATC Subject: Confusion about when it's my navigation, and when it's ATC .... I do have a problem with transitions between automated systems and flying by hand. Sometimes it's hard for me to keep track of what the systems are doing and what I am doing. As a last recort I occasionally disengage the automation entirely and fly by hand (particularly for approaches and landings), but that is not the objective, that's just to get on the ground safely. So you are really using your home computer as a procedure and systems simulator and not a flight training tool. I will agree that learning systems and procedures are part of the flight training process (or any training process that involves automation), but they are not as big a part of the overall training as you seem to believe. I say that because of your devotion to the idea that you really are doing exactly the same thing as a professional pilot actually flying an aircraft along the same routes. There are a lot of freewill decisions that still take place in the cockpit and those decisions can not be simulated. You just can't let your instruments do everything for you the moment you rotate. This is another way of saying that the freewill decision process has to be considered and you have to allocate the variables those decisions introduce. If it were considered safe, reliable, or even desirable to automate the entire process (as a systems simulator provides) then there would be no flight training requirements because there would be no pilots. True flying is involves much less systems integration and systems management than you seem to believe. Sure, flying will always involve some systems management -- hell we can't even fly our Super Cubs or Taylorcraft in controlled airspace anymore without working with the system somewhat. My point to this post is that you seem to have the incorrect idea about systems management and procedure memorization being the most significant part of operating an aircraft -- that's not the way it is for the large majority of people who fly. You can if they work as designed. And real life comes very close to that, although I understand most pilots fly the first part of the departure by hand, and often landings as well. Refer to your earlier posting about rudeness and consider that you have no experience on which to base your comment immediately above, yet you still have taken an authoritative position from your tone and word choice. This is why others have suggested you consider your own "attitude". |
Jim Carter writes:
So you are really using your home computer as a procedure and systems simulator and not a flight training tool. I use it for both. When I fly a 737-800, there's a much greater emphasis on systems and procedures. When I fly a Baron 58, there's a much greater emphasis on flight training itself. I use the Baron for pattern practice, but the 737 for complex navigation and ATC practice. I will agree that learning systems and procedures are part of the flight training process (or any training process that involves automation), but they are not as big a part of the overall training as you seem to believe. I think that depends hugely on what type of flying you intend to do. For airline pilots, systems and procedures seem to be the lion's share of what they do. Actually flying the plane is becoming increasingly incidental. I say that because of your devotion to the idea that you really are doing exactly the same thing as a professional pilot actually flying an aircraft along the same routes. Exactly the same thing? I think not. But I come very close. There are a lot of freewill decisions that still take place in the cockpit and those decisions can not be simulated. I make free-will decisions, too. However, in practical commercial aviation, the idea is to reduce free will to a minimum. Free will does not yield economical and low-maintenance flight. Flying exclusively by the numbers with a computer does. Airlines would probably love to dispense with pilots entirely. If it were considered safe, reliable, or even desirable to automate the entire process (as a systems simulator provides) then there would be no flight training requirements because there would be no pilots. That time will come. Their presence even today is increasingly as a back-up. It's already possible to fly aircraft from gate to gate without a pilot, although such systems have not actually been deployed commercially, as far as I know. True flying is involves much less systems integration and systems management than you seem to believe. Maybe in a Cessna, but not in commercial aviation. My point to this post is that you seem to have the incorrect idea about systems management and procedure memorization being the most significant part of operating an aircraft -- that's not the way it is for the large majority of people who fly. Do you fly large jets for an airline, or small aircraft? -- Transpose mxsmanic and gmail to reach me by e-mail. |
