A Guy Called Tyketto writes:
I'd hate to see what would happen if tower tells you that you have a 40 or 50kt overtake on the traffic you're following, and to S-turn. Kills your autoland. All you have to do is pull a switch and take over. If you want the realism, you should and fly the approach and land, and use your instruments when you need them. Yes, in principle. But if I'm practicing the systems and automation, I use those. If I'm offline, I can just stop the simulation when I've covered the part I want to practice, and then go back and do it again. If I'm online, I'm required to land, as it is bad form to simply disappear from the controller's scope with no explanation. So I may autoland, both for the practice with automation and to conform to the requirement to land, given that online simulation is supposed to be like real life. -- Transpose mxsmanic and gmail to reach me by e-mail. |
A Guy Called Tyketto wrote:
I'd hate to see what would happen if tower tells you that you have a 40 or 50kt overtake on the traffic you're following, and to S-turn. Kills your autoland. If you want the realism, you should and fly the approach and land, and use your instruments when you need them. Should you get the helmet and can't see them, you would be screwed... royally. You can't S-turn at busy airline airports very often. |
Not often. For the most, visual approaches are used over ILS approaches. When cleared for the visual approach, you won't be using autoland, as you won't be on an ILS approach, regardless of if you join the localizer and track it. You're still on the visual approach. I'm kind of surprised that ATC so often goes with visual approaches for IFR flights. Wouldn't it be more straightforward to funnel everyone into ILS approaches, given that they are already IFR? -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() Mxsmanic wrote: I'm kind of surprised that ATC so often goes with visual approaches for IFR flights. Wouldn't it be more straightforward to funnel everyone into ILS approaches, given that they are already IFR? Another case of where simulation doesn't match real life. By giving a visual approach clearance, separation rules change. A controller can funnel more airplanes into the approach. Otherwise he can't have more than one airplane on the approach at the same time. It's also one of those reasons controllers like for you to cancel in the air for uncontrolled airports (you wouldn't know about that because thats just "fun" flying) is because they can't let an IFR departure while your on the approach. Or another approach. Hence, the airport is "closed" for IFR arrivals/departures. Real world example, departing Quincy IFR one time (in VMC). Plane takes off ahead of us on an IFR clearance. We can't take off IFR because that plane just took off. And radar coverage at KUIN is spotty below 5000. So I can wait on the ground until said plane gets into radar coverage, or just depart VFR and pick up my clearance airborne. We departed VFR. |
bdl writes:
Another case of where simulation doesn't match real life. By giving a visual approach clearance, separation rules change. A controller can funnel more airplanes into the approach. Otherwise he can't have more than one airplane on the approach at the same time. OK, but I don't see how this distinguishes simulation from real life. It's also one of those reasons controllers like for you to cancel in the air for uncontrolled airports (you wouldn't know about that because thats just "fun" flying) is because they can't let an IFR departure while your on the approach. Actually, I did know that. ATC does that in simulation, too. Real world example, departing Quincy IFR one time (in VMC). Plane takes off ahead of us on an IFR clearance. We can't take off IFR because that plane just took off. And radar coverage at KUIN is spotty below 5000. So I can wait on the ground until said plane gets into radar coverage, or just depart VFR and pick up my clearance airborne. We departed VFR. Simulation traffic is usually low enough that this isn't a factor at uncontrolled airports. Of course, when controllers are in short supply, sometimes even KLAX or KORD are uncontrolled, which makes things a bit weird. -- Transpose mxsmanic and gmail to reach me by e-mail. |
bdl wrote:
Another case of where simulation doesn't match real life. By giving a visual approach clearance, separation rules change. A controller can funnel more airplanes into the approach. Otherwise he can't have more than one airplane on the approach at the same time. Depends what you mean by approach. If there is radar and a non-conflicted missed approach there can be quite a string of aircraft on the ILS. |
![]() bdl wrote: Another case of where simulation doesn't match real life. By giving a visual approach clearance, separation rules change. Separation does not change because visual approaches are in use. It remains the same unless visual separation is used. This is independent of any type of approach clearance. A controller can funnel more airplanes into the approach. Otherwise he can't have more than one airplane on the approach at the same time. Not even remotley true. You are mixing and matching rules. |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1 Mxsmanic wrote: A Guy Called Tyketto writes: Not often. For the most, visual approaches are used over ILS approaches. When cleared for the visual approach, you won't be using autoland, as you won't be on an ILS approach, regardless of if you join the localizer and track it. You're still on the visual approach. I'm kind of surprised that ATC so often goes with visual approaches for IFR flights. Wouldn't it be more straightforward to funnel everyone into ILS approaches, given that they are already IFR? No. And if you understood more about ATC in general, as well as the differences between visual and instrument approaches, you wouldn't be asking this question. What would you do if the runway in use does not have an instrument approach? You'd be screwed. I'd love to see you land at KLAS during the summer when winds are out of the east and density altitude is so high that they have 19L/R and 7L/R active. There is no correlation between VFR/IFR and visual/instrument approaches. BL. - -- Brad Littlejohn | Email: Unix Systems Administrator, | Web + NewsMaster, BOFH.. Smeghead! ![]() PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.6 (GNU/Linux) iD8DBQFFnprlyBkZmuMZ8L8RAvv3AJ0arFR62WVDOVkp9fJY+/wxGfDAuwCgly9I TG1sXMKn9xv1T6vOEWbWDH8= =o9er -----END PGP SIGNATURE----- |
Not often. For the most, visual approaches are used over ILS approaches. When cleared for the visual approach, you won't be using autoland, as you won't be on an ILS approach, regardless of if you join the localizer and track it. You're still on the visual approach. That just isn't so. Jet aircraft are required to remain on, or above, the ILS G/S whether on an ILS approach or on a visual approach. At the company I worked for, failure to tune and identify the ILS for a visual approach to an ILS runway was a check-ride bust. As to autoland, most of them are down in good weather for proficiency and to maintain certification of the airborne equipment. Autolands can (and are) even be practiced on visual approaches provided the ILS is intercepted prior to the PFAF. |
Hash: SHA1 Sam Spade wrote: A Guy Called Tyketto wrote: Not often. For the most, visual approaches are used over ILS approaches. When cleared for the visual approach, you won't be using autoland, as you won't be on an ILS approach, regardless of if you join the localizer and track it. You're still on the visual approach. That just isn't so. Jet aircraft are required to remain on, or above, the ILS G/S whether on an ILS approach or on a visual approach. At the company I worked for, failure to tune and identify the ILS for a visual approach to an ILS runway was a check-ride bust. This would be a company policy, no? Because it could still be done in any other aircraft outside your company. BL. - -- Brad Littlejohn | Email: Unix Systems Administrator, | Web + NewsMaster, BOFH.. Smeghead! ![]() PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.6 (GNU/Linux) iD8DBQFFnukEyBkZmuMZ8L8RAv1XAKCfj+FajnHlCSUmibkiUn qoSwwTWACdG9B7 hbOiFPvSRrU9vjUr8YKRGHE= =bsZe -----END PGP SIGNATURE----- |
