![]() "Dudley Henriques" wrote in message ... Had a Q&A once as a guest speaker on aviation with a troop of Cub Scouts. One of them asked me what Orville and Wilber Wright were REALLY like!!!!!! :-)) When you flew during the war, was it the blue or the grey? -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO (MTJ) |
![]() "Matt Barrow" wrote in message ... "Dudley Henriques" wrote in message ... Had a Q&A once as a guest speaker on aviation with a troop of Cub Scouts. One of them asked me what Orville and Wilber Wright were REALLY like!!!!!! :-)) When you flew during the war, was it the blue or the grey? PLEASE Matt!!! Try to be "CIVIL" here :-))))) Dudley Henriques |
("Matt Barrow" wrote)
When you flew during the war, was it the blue or the grey? "...three if by air" I wonder if the other side's pilots wore red coats. :-) "What a revolting development this is!" (Daffy) Ducking and running Montblack-powder |
![]() Dudley Henriques wrote: Actually "knew him" would be more accurate. Tex died back in 98. Great guy, and he pulled off one hell of a stunt back there with the prototype Dash 80! We always kidded him about it looking like a "whale" roll!!! :-)) Hey Dudley, Speaking of whales... D'ya think the structure (spars?) on the A380 would hold up to a barrel roll? Airbus could use some positive press for that program right about now. That'd be even more spectacular than the photos of the A380 four-ship from last year! |
Well....you can do a barrel roll all the way down to 1g if you have the
right parameters set up and execute properly. As near as I can figure, to set this up for the 380 you would need about all the sky you could get both under you and around you!!!:-)) Dudley Henriques "Kingfish" wrote in message ups.com... Dudley Henriques wrote: Actually "knew him" would be more accurate. Tex died back in 98. Great guy, and he pulled off one hell of a stunt back there with the prototype Dash 80! We always kidded him about it looking like a "whale" roll!!! :-)) Hey Dudley, Speaking of whales... D'ya think the structure (spars?) on the A380 would hold up to a barrel roll? Airbus could use some positive press for that program right about now. That'd be even more spectacular than the photos of the A380 four-ship from last year! |
Is it truly an entirely 1 g maneuver? It seems like you would have to pull
1+ G's at the end. The nose goes down and has to be pulle dback up, no? mike "Dudley Henriques" wrote in message ... Well....you can do a barrel roll all the way down to 1g if you have the right parameters set up and execute properly. As near as I can figure, to set this up for the 380 you would need about all the sky you could get both under you and around you!!!:-)) Dudley Henriques |
No it's not entirely a 1g maneuver. This comes up from time to time.
The entry to the roll initiation can either be considered or not considered as part of the maneuver. Usually, in the classic sense at least, the entry to the roll initiation point is considered as part of the maneuver. In this case, you have to pull above 1g leaving level flight and as such, the g during this phase of the roll has to be above 1g naturally. If you have to dive to gain entry airspeed as is the case in low powered airplanes like say a clipped winged Cub for example, the climb phase into the roll from the entry airspeed point is also above 1g. Also, if the roll is done in a way that requires the aircraft to be returned to level flight, the exit phase as the nose comes back to level flight will also be above 1 g. I should be a bit more clear when I speak peripherally on barrel rolls, as many pilots consider them only from the level flight to level flight scenario; where as in reality, a barrel roll can be performed from almost any attitude of flight; most of these not requiring a return to level flight at all....and subsequently not requiring higher entry and exit g. When I speak of barrel rolls, I should specify that I'm not speaking of the classic barrel roll entry and exit. I speak ONLY of the part of the roll beginning at the initiating point where the aircraft begins it's path through 3 dimensional roll. Because this point can be executed from various attitudes of flight, it is this point that I describe as being capable of being performed at various levels of positive g down to 1g. In other words, I only consider the aircraft in barrel roll when the flight path is transitioning through 3 dimensional flight. I use this analogy because in actuality, a barrel roll can be initiated from flight attitudes other than from the classic level flight entry. The actual roll can be performed as loosely down to 1g (I've even done them completely unloaded) or as tight (higher positive g) as the aircraft's roll axis through 3 dimensions will allow (in a fighter for example...a vector or lag roll) To clarify on your point; if a barrel roll is started from level flight and ended at level flight, the entry and exit flight path will indeed require positive g above 1. Dudley Henriques "mike regish" wrote in message . .. Is it truly an entirely 1 g maneuver? It seems like you would have to pull 1+ G's at the end. The nose goes down and has to be pulle dback up, no? mike "Dudley Henriques" wrote in message ... Well....you can do a barrel roll all the way down to 1g if you have the right parameters set up and execute properly. As near as I can figure, to set this up for the 380 you would need about all the sky you could get both under you and around you!!!:-)) Dudley Henriques |
No. Not crashing afterwards was not part of the requirements. ![]() Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
![]() Kingfish wrote: Dudley Henriques wrote: Actually "knew him" would be more accurate. Tex died back in 98. Great guy, and he pulled off one hell of a stunt back there with the prototype Dash 80! We always kidded him about it looking like a "whale" roll!!! :-)) Hey Dudley, Speaking of whales... D'ya think the structure (spars?) on the A380 would hold up to a barrel roll? Airbus could use some positive press for that program right about now. That'd be even more spectacular than the photos of the A380 four-ship from last year! I hope it could hold up to 1 g. According to the history channel, the head guys called the pilot to the mat and brought in some engineers. Their main concern was that the aircraft was not certified for neg g's and they thought fuel/oil/etc could unport. When the pilot explained to him that he never got over 1.5 g's they seemed calmer. -Robert |
"B A R R Y" wrote in message et... Dudley Henriques wrote: Know the event well, as well as the guy who did it :-) You know him? Cool! I loved "Jet Age Test Pilot"! Actually "knew him" would be more accurate. Tex died back in 98. Great guy, and he pulled off one hell of a stunt back there with the prototype Dash 80! We always kidded him about it looking like a "whale" roll!!! :-)) Dudley Henriques Tex is gone, but the Dash 80, restored to it's original (ugly) brown and yellow paint scheme stands in the Smithsonian's Udvar-Hazy center. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | May 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | April 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | March 1st 04 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | February 1st 04 07:27 AM |
