Chris wrote:
"Robert M. Gary" wrote in message oups.com... Mike wrote: Hi, I'm interested in learning more about airplane construction, say maybe a Cessna 172. I know the basics of airframes and power plants, but what I'm having a hard time finding is actual diagrams and depictions of the actual assembly. For example, wing root connections, engine mounts, supporting structures, etc. I imagine this might be available in a mechanics manual, but I don't know where else to look. I've scoured the Internet with no success. When I saw how the wings are attached on a Cessna it almost made me not want to fly one. Not much holding them on. Rational or not, I feel better in turb in my Mooney knowing the entire cabin is sitting on the one piece wing. -Robert Try standing at the back of an empty 757, on a positioning leg. I could swear that you can see the fuselage gently flex as it flies- a bit like a fish going through water. Now that does scare the sh1t out of you. I certainly believe that. I was on a flight out west a while ago, and I guess the pilot realized he was going to overshoot the centerline on the turn to final, so he/she banked more suddenly than usual. Definitely heard the flex, that's for sure ![]() -- Mike |
Ummm.. re" things that move..float or fly..."
Those that don't bend or flex, - break.. ![]() Dave On Wed, 10 Jan 2007 16:41:32 -0500, Mike wrote: Chris wrote: "Robert M. Gary" wrote in message oups.com... Mike wrote: Hi, I'm interested in learning more about airplane construction, say maybe a Cessna 172. I know the basics of airframes and power plants, but what I'm having a hard time finding is actual diagrams and depictions of the actual assembly. For example, wing root connections, engine mounts, supporting structures, etc. I imagine this might be available in a mechanics manual, but I don't know where else to look. I've scoured the Internet with no success. When I saw how the wings are attached on a Cessna it almost made me not want to fly one. Not much holding them on. Rational or not, I feel better in turb in my Mooney knowing the entire cabin is sitting on the one piece wing. -Robert Try standing at the back of an empty 757, on a positioning leg. I could swear that you can see the fuselage gently flex as it flies- a bit like a fish going through water. Now that does scare the sh1t out of you. I certainly believe that. I was on a flight out west a while ago, and I guess the pilot realized he was going to overshoot the centerline on the turn to final, so he/she banked more suddenly than usual. Definitely heard the flex, that's for sure ![]() |
The more you know the more you can do.
Nothing like assembling a sailplane, loading it full of water and bombing down a ridge at red-line for a few hours. Then you just pull the wings and tail back off and trailer it home. Robert M. Gary wrote: Mike wrote: Hi, I'm interested in learning more about airplane construction, say maybe a Cessna 172. I know the basics of airframes and power plants, but what I'm having a hard time finding is actual diagrams and depictions of the actual assembly. For example, wing root connections, engine mounts, supporting structures, etc. I imagine this might be available in a mechanics manual, but I don't know where else to look. I've scoured the Internet with no success. When I saw how the wings are attached on a Cessna it almost made me not want to fly one. Not much holding them on. Rational or not, I feel better in turb in my Mooney knowing the entire cabin is sitting on the one piece wing. -Robert |
![]() Bill Watson wrote: The more you know the more you can do. Nothing like assembling a sailplane, loading it full of water and bombing down a ridge at red-line for a few hours. Then you just pull the wings and tail back off and trailer it home. the size of those pins/bolts that hold the wings on should attract the attention of any pilot not used to rigging sailpanes :-) |
Understand that bolts used in aircraft construction are not
"hardware store" items. The steel and the tolerances for aircraft grade fasteners are better than hardware store Grade 8 bolts. Beech uses bolts in tension to hold the wing on the Bonanza, Baron and King Air models. When there is a crash, the bolts are rarely broken. But if the bolts are not properly installed and maintained, corrosion can weaken the bolts causing them to break. Cessna uses a bolt installed in shear through fittings like you fingers meshed. This is called "double shear" and as long as the bolt is a snug fit in the hole the bolt can hold more load than the airplane is designed to experience. But a bolt in tension is stronger than a bolt in shear. "george" wrote in message ups.com... | | Bill Watson wrote: | | The more you know the more you can do. | | Nothing like assembling a sailplane, loading it full of water and | bombing down a ridge at red-line for a few hours. | | Then you just pull the wings and tail back off and trailer it home. | | the size of those pins/bolts that hold the wings on should attract the | attention of any pilot not used to rigging sailpanes :-) | |
![]() Jim Macklin wrote: Understand that bolts used in aircraft construction are not "hardware store" items. The steel and the tolerances for aircraft grade fasteners are better than hardware store Grade 8 bolts. Beech uses bolts in tension to hold the wing on the Bonanza, Baron and King Air models. When there is a crash, the bolts are rarely broken. But if the bolts are not properly installed and maintained, corrosion can weaken the bolts causing them to break. Cessna uses a bolt installed in shear through fittings like you fingers meshed. This is called "double shear" and as long as the bolt is a snug fit in the hole the bolt can hold more load than the airplane is designed to experience. But a bolt in tension is stronger than a bolt in shear. The hardware-store Grade 2 bolts (no marks on the head) is around 55 to 60 ksi, really dangerous stuff on anything other than your kid's push kart. Grade 5 (three radial marks on the head) are 120ksi, same as an AN bolt. The Grade 8 (five radial marks) is 150ksi, better than the AN bolt. But the AN bolt is made of 2330 nickel steel, making it more corrosion-resistant and more ductile, which means it will stretch more before it breaks. The part will appear loose before it comes off. The AN bolt's tolerances are a bit better and the thread length is just what's needed, not the great length of thread on the industrial bolt that ends up inside the joint where it doesn't support the shear loads well. And the thread fit is far better on the AN bolt. Shear strength for steel is typically 70% of tensile. Someone asked about the Cardinal's (177) wing attach. It's been a long time, but I think it was something like 1/2" bolts in sextuple shear, spaced about 7 inches apart. The spar fittings were cast aluminum. Dan |
Jim Macklin wrote:
Understand that bolts used in aircraft construction are not "hardware store" items. The steel and the tolerances for aircraft grade fasteners are better than hardware store Grade 8 bolts. Beech uses bolts in tension to hold the wing on the Bonanza, Baron and King Air models. When there is a crash, the bolts are rarely broken. But if the bolts are not properly installed and maintained, corrosion can weaken the bolts causing them to break. Cessna uses a bolt installed in shear through fittings like you fingers meshed. This is called "double shear" and as long as the bolt is a snug fit in the hole the bolt can hold more load than the airplane is designed to experience. But a bolt in tension is stronger than a bolt in shear. I'd have to pull out my AISC manual to be sure, but I believe that a bolt in double shear has more capacity than in tension. If you are comparing single shear to tension, then I agree with you. Matt |
What is "double shear" and "single shear"? Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
Jose wrote:
I'd have to pull out my AISC manual to be sure, but I believe that a bolt in double shear has more capacity than in tension. If you are comparing single shear to tension, then I agree with you. What is "double shear" and "single shear"? It refers to the number of planes in shear. Think of the rivet in a scissors. There is one shear plane where the two halves of the scissors meet and are held together by the pin/rivet. Now think of a sandwich of three pieces of metal held together with a bolt or pin or rivet. There are now two planes that are in shear and thus you have twice as much shear resistance of the outer two pieces of metal are pulled one direction and the middle piece is pulled another direction. Matt |
![]() Matt Whiting wrote: Cessna uses a bolt installed in shear through fittings like you fingers meshed. This is called "double shear" and as long as the bolt is a snug fit in the hole the bolt can hold more load than the airplane is designed to experience. But a bolt in tension is stronger than a bolt in shear. I'd have to pull out my AISC manual to be sure, but I believe that a bolt in double shear has more capacity than in tension. If you are comparing single shear to tension, then I agree with you. Matt That's right. The 70% figure refers to single shear. I made a mistake on the Grade 8 bolt head marking. It has six radial marks, not five. Five is a Grade 7, not a common bolt. The grades go clear to Grade 16, IIRC. Dan |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
