Libelle Camelbak stowage
Old January 12th 07, 06:31 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
Default Libelle Camelbak stowage
Gav Goudie wrote:
Why dont you just put it behind your head like everyone
else?!
As I said at the start, I'd seen somebody else claim he did this and I
want to know how, because there are no lashing points to prevent
anything placed there to get amongst the rudder pedals or disapear under
the pan during a winch launch. That doesn't mean I'd do it: I'm allergic
to loose stuff getting to where it shouldn't be.
I have a spar-top bag that will take the Camelbak and a fleece but
little else: some place to put the canopy cover would be nice too.
Is there an issue with the Camelbak dribbling down your neck or on your
pants (if you leave the tube dangling) if its behind your head?
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old January 12th 07, 07:32 PM posted to rec.aviation.soaring
jcarlyle
I put the Camelbak just in back of my head, in front of the spars,
wrapping its harness around the spar safety pins to keep it secure.
Nothing else is there except for the battery, so there's no need to
fret about fouling flight controls.
My Camelbak will indeed leak if the tube isn't kept nearly horizontal.
When I put it in the plane I route the tube outside the cockpit, and
after I'm in I route it over my shoulder and then under my shoulder
harness. Once (but only once) I got out and left the tube dangling on
the seat. I discovered after I'd gotten in again that it takes a long
time for your pants and underpants to dry out... grin
-John
Martin Gregorie wrote:
Ouch. But, surely that means putting the Camelbak through the hatch
behind the spars? That makes my teeth itch: there are far too many
control runs back there for it to get tangled up with.
(from another message)
Old January 13th 07, 12:23 AM posted to rec.aviation.soaring
Nice. The only trouble is that I carefully trimmed the straps off the
Camelbak to stop them tangling round things they shouldn't ought to.
Back then I was flying the club's Pegase and the Camelbak sat nicely
behind the adjustable seat back. I've wondered about doing the same in
the Libelle: its only a 1.5 litre Camelbak so it may be possible to sit
it in behind the top of the seat.
I take the points made about being clouted round the ears by the water
supply: actually, a gallon of water weighs 10 lbs, not 8. My Camelbak is
only 1.5 kg (3.5 lbs but still.... My spar-top bag clips onto the
grunging bar studs so it may restrain a Camelbak that's on the inside.
That certainly needs investigation.
I thought that might be the case. BTW, I've sat on the valve too when it
got down between me and the side of the seat pan.
org |
Old January 13th 07, 01:19 AM posted to rec.aviation.soaring
Andy[_1_]
That depend on which side of the pond you are on. Despite the American
proclivity for having everything oversize, their gallon is a wimp of a
portion as are their pints of beer.
Andy
Old January 13th 07, 08:28 AM posted to rec.aviation.soaring
Bruce Greef
-John
Also not applicable to Libelle as I fly a Std. Cirrus.
My solution was to make up a carbon fibre plate that holds my radio speaker, and
keeps stuff on the shelf behind my head. I put my bag behind this but offset so
that in the event of large decelleration forces being applied the CG of the bag
will be on the port side of the plate. Theory is that any liquid filled
projectile will pass a centimetre or so to the left of my ear.
Strangely my cheap Raleigh cycling bag does not leak with the tube significantly
lower than the bag.
Old January 12th 07, 07:43 PM posted to rec.aviation.soaring
Nyal Williams
I put mine right beside me on my right side with no
further tiedown (Discus B) standing upright and behind
the back rest. (I'm a little guy and there is enough
room for that; don't remember about the Libelle cockpit
arrangement.
Why not put it in front of your chest under the harness?
Again, a little guy solution.
of the spars,
keep it secure.
no need to
nearly horizontal.
the cockpit, and
my shoulder
tube dangling on
it takes a long
-John
through the hatch
are far too many
your head?
Old January 12th 07, 09:22 PM posted to rec.aviation.soaring
jcarlyle
Were that I were little, Nyal - or at least littler! grin I should
have said before that I'm flying an ASW-19, it's Martin who's
interested in the Libelle libation setup.
That said, at first I did try putting the Camelbak behind the seat, but
found there wasn't enough room since I've got to have it all the way
back. I don't think I could put it on my chest after I've got the
parachute on, but then I haven't tried. Basically, I'm satisfied with
it in front of the spars, as I've checked my electrical system and I
make sure it's fastened to the spar pins so it can't become a
projectile.
-John
arrangement.
Old January 13th 07, 12:37 AM posted to rec.aviation.soaring
Ah Ha. *NOW* I understand how you tied it to the wing pins. I was
wondering! That would also work for a Pegase or ASW-20 but not for a
Libelle with its single wing pin.
However, I could probably use a double keyhole in an alloy plate to tie
it to the grunging pins on top of the spars. Said pins are like the
heads of two rather large nails that project from the tops of the spars
and are used with the grunging bar[1] to pull the wings together during
rigging.
[1] general term in the Cambridge club for this tool. SZD Juniors
and Kestrels also have grunging bars.
org |
Libelle usergroups/owners websites AdamLibelle Soaring 4 September 5th 06 10:40 AM
Interesting Standard Libelle Peter Thomas Soaring 0 April 21st 06 11:00 PM
H201 Libelle and wing dropping ruediger Soaring 18 October 26th 04 06:37 AM
Dual Tires on Libelle 201b Ray Lovinggood Soaring 11 September 9th 04 04:34 PM
Libelle Web Site f.blair Soaring 0 June 23rd 04 08:06 AM
