yah.. that's a trolls response.. but for those out there that already know
how to fly.. a SIM when USED PROPERLY with a QUALIFIED INSTRUCTOR and replicates the aircraft to be flown can be used to practice Check List Items, Systems Knowledge and Procedures My First "SIM" was a card board mock up of the Navigator crew station on the B-52, so We could practice checklists and know where all the 100 switches and dials were. The next "Sim" was a "radar" trainer with a large glass board that would replicated a radar scope and feed images to the radar (we are talking 1970s technology), the T10 Trainer. Oh, I should not forget the "cardboard box" solar system SIM for learning how to use a sextant and take "Cel Shots" My Last SIM, was the full motion B-1 Weapons System Trainer. BT "Mxsmanic" wrote in message ... Mortimer Schnerd, RN writes: We did most of the training in a multi sim, then went for a couple of flights in a Seminole. Why waste time in a sim? It has nothing to do with real flying. I know this because experts here have told me so. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Any comments about the best training aircraft for these purpose ? (PA34 Seneca, Beech Duchess, PA44 Seminole, Diamond DA42, All of them will teach you the basics. The DA42 has diesel engines with electronic controls. It will teach you the basics, but the procedures for securing the engines won't carry over to piston twins. There are big differences concerning the rating requirements. Some flight schools offer a multi training of 6 hours, other 25 hours for the rating. US regs don't require a minimum number of hours. Each schools' curriculum is based on experience and insurance requirements. Having a high-performance sign-off will help expedite the course. D. |
![]() On Jan 14, 10:00 am, wrote: Hi, i'm interested in the multiengine rating (land), VFR-add-on to my PP-ASEL. Any comments about the best training aircraft for these purpose ? (PA34 Seneca, Beech Duchess, PA44 Seminole, Diamond DA42, ..) There are big differences concerning the rating requirements. Some flight schools offer a multi training of 6 hours, other 25 hours for the rating. Why it is so ? Mike Hey Mike, my $0.02- I learned in a Seminole, and now I am transitioning into a DA42. Both are fairly easy to fly. The Seminole has counter rotating engines which make the critical engine not a factor. The one I trained in has steam gauges. The DA42 is a G1000 plane, and FADEC controlled. Are you familiar with the G1000? It will take you a while to get used to the display and setting up the GPS, finding pages, etc. You can get a free simulator from Garmin to work through this, but be aware it will take a little while. (If equipped the Avidyne in the Seminole will need some transition time as well). The DA42 is really nice to fly. Decent power, nice handling characteristics while flying, and during single engine operations. The 44' wingspan takes a bit getting used to (the winglets sit over 7' in the air, so it requires careful taxiing). A little info on both: Seminole: -Will teach you about controlling constant speed engines with standard controls (mix, prop, throttles, and manual feathering) -Cowl Flaps, and proper cooling needs -Burns around 20 GPH. -Counter rotating engines means that Vmc is lower -You can shut engines off during training and fully secure them w/o damaging the engine-- -Janitrol heater and associated controls/limitations- (quick heat!) -Stall characteristics are pretty benign Twin Star: -A bit faster (~165 to 170kts cruise) -G1000 -FADEC-- not as much to master, engine shutdown, feathering is just the flip of a switch -A lot of failures will need to be simulated but not physically done, for example, you can not shutdown engine using full shutoff during training (as it will damage the fuel pump). -Burns around 10GPH (Jet A) -Has a critical engine -Stall characteristics are pretty benign -can extend the gear at any speed up to Vne -Anti ice capability along with oxygen -newer models have the Garmin autopilot with flight director -About 50 different abnormal conditions that require the use of special checklists (not critical problems, but need checklists to resolve) -Full electrical system failure will eventually lead to engine shutdown -Quieter than the Seminole (from the inside) -simple run up -needs continual crosswind correction during landing (those winglets work like sails as well) -takes a while to get heat in the cabin Len CPS/MEL IA KBFI |
All airplanes need continual crosswind correction, any time
there is a crosswind. " wrote in message oups.com... | | | On Jan 14, 10:00 am, wrote: | Hi, | | i'm interested in the multiengine rating (land), VFR-add-on to my | PP-ASEL. | Any comments about the best training aircraft for these purpose ? | (PA34 Seneca, Beech Duchess, PA44 Seminole, Diamond DA42, ..) | | There are big differences concerning the rating requirements. | Some flight schools offer a multi training of 6 hours, other 25 hours | for the rating. | | Why it is so ? | | Mike | | Hey Mike, my $0.02- | | I learned in a Seminole, and now I am transitioning into a DA42. Both | are fairly easy to fly. The Seminole has counter rotating engines | which make the critical engine not a factor. The one I trained in has | steam gauges. The DA42 is a G1000 plane, and FADEC controlled. | | Are you familiar with the G1000? It will take you a while to get used | to the display and setting up the GPS, finding pages, etc. You can get | a free simulator from Garmin to work through this, but be aware it will | take a little while. (If equipped the Avidyne in the Seminole will need | some transition time as well). | | The DA42 is really nice to fly. Decent power, nice handling | characteristics while flying, and during single engine operations. The | 44' wingspan takes a bit getting used to (the winglets sit over 7' in | the air, so it requires careful taxiing). | | A little info on both: | | Seminole: | -Will teach you about controlling constant speed engines with standard | controls (mix, prop, throttles, and manual feathering) | -Cowl Flaps, and proper cooling needs | -Burns around 20 GPH. | -Counter rotating engines means that Vmc is lower | -You can shut engines off during training and fully secure them w/o | damaging the engine-- | -Janitrol heater and associated controls/limitations- (quick heat!) | -Stall characteristics are pretty benign | | Twin Star: | -A bit faster (~165 to 170kts cruise) | -G1000 | -FADEC-- not as much to master, engine shutdown, feathering is just the | flip of a switch | | -A lot of failures will need to be simulated but not physically done, | for example, you can not shutdown engine using full shutoff during | training (as it will damage the fuel pump). | -Burns around 10GPH (Jet A) | -Has a critical engine | -Stall characteristics are pretty benign | -can extend the gear at any speed up to Vne | -Anti ice capability along with oxygen | -newer models have the Garmin autopilot with flight director | -About 50 different abnormal conditions that require the use of special | checklists (not critical problems, but need checklists to resolve) | -Full electrical system failure will eventually lead to engine shutdown | -Quieter than the Seminole (from the inside) | -simple run up | -needs continual crosswind correction during landing (those winglets | work like sails as well) | -takes a while to get heat in the cabin | | Len | CPS/MEL IA | KBFI | |
Yes, you are correct. What I should have stated is that the Twinstar is
more sensitive to it than the seminole. I find I've needed to put in more correction and need to keep it in longer on the landing roll than the seminole. The seminole is more tolerant of taking out the crosswind correction in the beginning part of the landing roll, whereas the twinstar needs to have it kept in till you are just about stopped. Len Jim Macklin wrote: All airplanes need continual crosswind correction, any time there is a crosswind. " wrote in message oups.com... | | | On Jan 14, 10:00 am, wrote: | Hi, | | i'm interested in the multiengine rating (land), VFR-add-on to my | PP-ASEL. | Any comments about the best training aircraft for these purpose ? | (PA34 Seneca, Beech Duchess, PA44 Seminole, Diamond DA42, ..) | | There are big differences concerning the rating requirements. | Some flight schools offer a multi training of 6 hours, other 25 hours | for the rating. | | Why it is so ? | | Mike | | Hey Mike, my $0.02- | | I learned in a Seminole, and now I am transitioning into a DA42. Both | are fairly easy to fly. The Seminole has counter rotating engines | which make the critical engine not a factor. The one I trained in has | steam gauges. The DA42 is a G1000 plane, and FADEC controlled. | | Are you familiar with the G1000? It will take you a while to get used | to the display and setting up the GPS, finding pages, etc. You can get | a free simulator from Garmin to work through this, but be aware it will | take a little while. (If equipped the Avidyne in the Seminole will need | some transition time as well). | | The DA42 is really nice to fly. Decent power, nice handling | characteristics while flying, and during single engine operations. The | 44' wingspan takes a bit getting used to (the winglets sit over 7' in | the air, so it requires careful taxiing). | | A little info on both: | | Seminole: | -Will teach you about controlling constant speed engines with standard | controls (mix, prop, throttles, and manual feathering) | -Cowl Flaps, and proper cooling needs | -Burns around 20 GPH. | -Counter rotating engines means that Vmc is lower | -You can shut engines off during training and fully secure them w/o | damaging the engine-- | -Janitrol heater and associated controls/limitations- (quick heat!) | -Stall characteristics are pretty benign | | Twin Star: | -A bit faster (~165 to 170kts cruise) | -G1000 | -FADEC-- not as much to master, engine shutdown, feathering is just the | flip of a switch | | -A lot of failures will need to be simulated but not physically done, | for example, you can not shutdown engine using full shutoff during | training (as it will damage the fuel pump). | -Burns around 10GPH (Jet A) | -Has a critical engine | -Stall characteristics are pretty benign | -can extend the gear at any speed up to Vne | -Anti ice capability along with oxygen | -newer models have the Garmin autopilot with flight director | -About 50 different abnormal conditions that require the use of special | checklists (not critical problems, but need checklists to resolve) | -Full electrical system failure will eventually lead to engine shutdown | -Quieter than the Seminole (from the inside) | -simple run up | -needs continual crosswind correction during landing (those winglets | work like sails as well) | -takes a while to get heat in the cabin | | Len | CPS/MEL IA | KBFI | |
Commercial 250nm VFR flight - all 3 landings on the same day? | Jim Macklin | Piloting | 39 | December 20th 06 12:11 PM |
Aw Rating merger and Today's ASW | Charlie Wolf | Naval Aviation | 5 | May 12th 05 10:34 PM |
Instrument Rating Checkride PASSED (Very Long) | Alan Pendley | Instrument Flight Rules | 24 | December 16th 04 02:16 PM |
Enlisted pilots | John Randolph | Naval Aviation | 41 | July 21st 03 02:11 PM |
