Commencing a GPS approach from a fix other than the FAF
Old January 17th 07, 08:48 AM posted to rec.aviation.ifr
Chris Quaintance
Default Commencing a GPS approach from a fix other than the FAF
I think this is the problem. I'd expect MOVER to be the first fix once
the approach is loaded and I expand the approach in the flight plan
view. I could then go Direct-to EWTOF quite easily and still be in
proper sequence. However, the first fix is UBBEP. I replicated this
behavior on the 480 sim, as well.
How do I load the approach such that at least all of the fixes from the
IAF (in this case MOVER) are there and ready to go? I can't seem to
find a way to make this happen. I'd like it to either magically be
there when the approach is loaded or at least allow me to select the
applicable transition. No dice.
Thanks,
--Chris
Mike Adams wrote:
Sam Spade wrote:
This handling is now approved and is no problem whatsoever with a Garmin
400 or 500.
Is it with the 480?
It works much the same on the 480. You have to put in the approach transition from the applicable IAF,
MOVER in this case, Execute it, and then do a Direct-to EWTOF as a separate action. The only
problem, mentally, is that you have to look on the chart to find the applicable transition that contains the
waypoint you're looking for, rather than being able to select it directly on the approach menu.
Mike
Old January 17th 07, 02:08 PM posted to rec.aviation.ifr
Ron Natalie
Huh, I get the choice of Vectors, MOVER, ISIFU, and SHOEY. Picking
any other than VECTORS gives me the the EWTOF waypoint. Are you
sure you selected something OTHER than vectors (and you did remember
to EXEC it!)
Old January 17th 07, 02:09 PM posted to rec.aviation.ifr
Ron Natalie
Mike Adams wrote:
400 or 500.
Is it with the 480?
Well in this case, they all have it except for Vectors. There is only
one IAF (which there are two additional transitions leading to).
Old January 17th 07, 02:15 AM posted to rec.aviation.ifr
Roy Smith
Sam Spade wrote:
Roy Smith wrote:
"Chris Quaintance" wrote:
Hi Folks-
Please forgive what is probably a simple question regarding GPS
approaches. I am new the the /G world. I was out flying my 182P today
to do some practice approaches. The airplane is equipped with a GNS480
and I have a Garmin 296 on the yolk. I was buzzing around NW of the
Salinas airport on vectors and was told to expect the GPS13 approach as
I requested. So far, so good. Fight plan entered into the 480 and the
296, approach loaded on both.
Here's the approach:
http://www.naco.faa.gov/d-tpp/0701/00363G13.PDF
NorCal cleared me direct EWTOF at 3200, cleared for the approach. When
looking at the approach on both the 480 and the 296, it seemed to
commence at UBBEP rather than EWTOF.
Yeah, right, you got a bum clearance. I had a similar experience not long
ago and wrote about it here (http://tinyurl.com/yt8vkn). It's pretty
common.
The problem is that while from the point of view of somebody sitting in a
dark room watching blips move around a screen, it's a perfectly reasonable
thing to have you do, the software in the GPS wants you to either start the
approach from an IAF, or get vectors to final. It would be nice if
controllers gave clearances that were flyable, but the often don't, and
then you're struggling to figure out how to tell the GPS to do something it
doesn't want to do.
Roy,
400 or 500.
Is it with the 480?
At least with the software rev we've got, it is. When you select an
approach, the only things that come up in the menu are Vectors and all the
IAFs. I believe you can fake it out by looking on the approach plate,
figuring out which IAF you can select that gives you a route including the
specified IF, load that up, then go into FPL mode, scroll down to the IF,
and do -D- to that. That's a lot of fumbling, looking, and button-pushing
to do at a busy time of the flight.
It ATC is allowed to send you direct to an IF, then the distinction between
IF and IAF has, for all practical matters, been eliminated. If that's the
case, then the databases and/or software needs to be updated to have the
IFs show up in the menu.
Old January 17th 07, 02:48 AM posted to rec.aviation.ifr
Matt Whiting
Roy Smith wrote:
Sam Spade wrote:
Hi Folks-
common.
doesn't want to do.
Roy,
400 or 500.
Is it with the 480?
Yes, but once you select one of the IAFs and it loads the approach into
the active flight plan, aren't all of the waypoints then available for a
direct-to operation?
Matt
Old January 17th 07, 04:43 AM posted to rec.aviation.ifr
Roy Smith
Yes, but it would still be a lot simplier if the IF just showed up in the
initial menu.
Old January 24th 07, 10:07 PM posted to rec.aviation.ifr
Sam Spade
It will take quite a few years for the FAA to identify all the IFs.
Direct-to-the IF is not an "if" for RNAV IAPs. ;-)
It's been in the AIM and 7110.65 for about a year now.
Old January 24th 07, 11:02 PM posted to rec.aviation.ifr
Stan Prevost[_1_]
"Sam Spade" wrote in message
between IF and IAF has, for all practical matters, been eliminated. If
that's the case, then the databases and/or software needs to be updated
to have the IFs show up in the menu.
What's to identify? If it is not an IAF, and not the FAF, and is on an
intermediate segment, it is an IF. Why does it need to be "identified"?
PCG:
INTERMEDIATE FIX- The fix that identifies the beginning of the intermediate
approach segment of an instrument approach procedure. The fix is not
normally identified on the instrument approach chart as an intermediate fix
(IF).
Intermediate Approach- The segment between the intermediate fix or point and
the final approach fix.
(Is that circular, or what?)
Old January 17th 07, 10:43 PM posted to rec.aviation.ifr
Dave J
rant mode
Having earned my instrument rating and done all my flying behind panels
that do NOT include an IFR GPS, I frequently find myself a little
queasy when I read these posts about GPS approaches.
I'm a young man (33) and am a professional in the computer industry (or
was, until I decided to go back to grad school) and yet, I find the
complexity of operating a GPS just plain outrageous. I've rented
aircraft with panel GPS and fiddled with the simulators on my PC and I
always come away with this feeling of "argggh!" this is way too hard.
I think the people who invented these panel units (or set up the IFR
certification for them) seriously screwed up by not fully appreciating
what was good about the old nav radios. To me, the nice thing is that
using a nav radio is NOT A NEGOTIATION. You set it and that's that. You
can do it ahead of time. You can change it at any time, without
updating a plan, etc. You can put a frequency in there long before what
appears on the nav head will make sense -- and that's okay. You as the
pilot get to decide when to look at the needle. With these GPS systems
it seems like you are constantly dealing with the after-effects of some
engineer/programmer who is not in the air with you.
Oh, and here's another nice thing about nav radios. They look and work
the same in a 737 and a 152. But god forbid you jump into an aircraft
with a different GPS unit than the one you're familiar with. You're
gonna be in trouble!
I dunno. I get what's great about GPS. I have a handheld (196) and like
it. (And it's flightplan logic is substantially easier than a 430/530,
btw).
Aviation used to represent the cutting edge in human factors research.
What happened?
/rant mode
-- dave j
R172K Approach Configuration facpi Instrument Flight Rules 10 January 5th 07 03:58 PM
RNAV vectors Dan Luke Instrument Flight Rules 74 December 26th 06 10:31 PM
Trust those Instruments.... Trust those Instruments..... A Lieberman Instrument Flight Rules 1 May 2nd 06 03:54 PM
Approach Question- Published Missed Can't be flown? Brad Z Instrument Flight Rules 8 May 6th 04 04:19 AM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 11:13 AM
