![]() wrote My son and I finished a small boat last year, using 1/4" Chilean Pine plywood, and we put some impressive curves in it. See this picture of an identical boat: http://www.glen-l.com/designs/outboard/dsn-sqtd.html Nice boat! -- Jim in NC |
"Lou" wrote in news:1169120606.808676.277590
@l53g2000cwa.googlegroups.com: Mine also calls for 1/4" but only from the front spar to the back spar, since I have flaps. Laminating 2 peices should be ok but I wouldn't us an 1/8" trowel. I would spred the glue around with a popsicle stick or scrap wood, quite a few clamps, and straps of wood to put on top. Clamp one end, then start clamping every couple of inches until you reach the other end. OK. Here's what I'm thinking now. I use a couple of 3/4 ply ribs as a mold with holes drilled near the upper edge as a place to locate the clamps. A few pieces of wood across the underside of the ply to keep it from sagging and a few pieces clamped right on top of those to ensure a good contact between the two glued surfaces. the width is only 12 inches so I'm supposing the two pieces would have adequate surface contact (i.e, no gaps) and I should end up with a molded walkway.. |
Good news for private pilots' spouses | Skylune | Piloting | 30 | July 7th 06 11:19 PM |
Wing dihedral | Dallas | Piloting | 35 | March 20th 06 04:01 PM |
The Impossibility of Flying Heavy Aircraft Without Training | Immanuel Goldstein | Piloting | 365 | March 16th 06 01:15 AM |
The Impossibility of Flying Heavy Aircraft Without Training | Immanuel Goldstein | Home Built | 331 | March 10th 06 01:07 AM |
An Affordable Homebrue 60 in DS machine | Grant | Soaring | 0 | August 8th 03 03:52 AM |
