I just saw a beautiful Lancair 320 painted in the hangar. It looks
great until you get up close. The polyurethane paint is very glossy, but there is dust particles and trash all over it. Even a few insects in the middle of our NC winter. Not to worry, says the painter, who runs an autobody repair shop. He says he'll use 600 grit and water sand it all out and you'll never see a bit of trash in the paint. Well, I hope. What do you think? We had another builder here rent a booth in a fancy car painting shop, and the paint job on his Zenair Zodiac looked flawless. In Greenville, SC they used to transport plastic airplanes with the wings off to a nice filtered booth at an auto paint shop down White Horse Rd. and paint them there. The pressure air used for the spray system was freeze-dried to take out water and other impurities. The painter was a real pro who instructed in the auto body section at Greenville Tech. The ships always came back to the hangar looking great. How's about it? Do you paint in the hangar or in a paint shop booth? We have two more to do and want clean glossy finishes without flaws. TIA. |
jls wrote:
I just saw a beautiful Lancair 320 painted in the hangar. It looks great until you get up close. The polyurethane paint is very glossy, but there is dust particles and trash all over it. Even a few insects in the middle of our NC winter. Not to worry, says the painter, who runs an autobody repair shop. He says he'll use 600 grit and water sand it all out and you'll never see a bit of trash in the paint. Well, I hope. What do you think? We had another builder here rent a booth in a fancy car painting shop, and the paint job on his Zenair Zodiac looked flawless. In Greenville, SC they used to transport plastic airplanes with the wings off to a nice filtered booth at an auto paint shop down White Horse Rd. and paint them there. The pressure air used for the spray system was freeze-dried to take out water and other impurities. The painter was a real pro who instructed in the auto body section at Greenville Tech. The ships always came back to the hangar looking great. How's about it? Do you paint in the hangar or in a paint shop booth? We have two more to do and want clean glossy finishes without flaws. TIA. It is true that polyurethane paints can be wet sanded and buffed once they have cured. I have seen it done within the last month. The best way is to make sure that there is no dust in the air, and no insects can get in the paint during the two hours that the paint is drying to tack free. Obviously, a paint booth is great if the airplane is small enough. If not, then the hangar should be very clean, and sealed against insects. It also helps to have banks of halogen or florescent lighting so that the painter can really see what they are doing. If I saw "dust" in the paint I would wonder if the piece was really clean before the paint was applied. Don W. |
Don W wrote: jls wrote: I just saw a beautiful Lancair 320 painted in the hangar. It looks great until you get up close. The polyurethane paint is very glossy, but there is dust particles and trash all over it. Even a few insects in the middle of our NC winter. Not to worry, says the painter, who runs an autobody repair shop. He says he'll use 600 grit and water sand it all out and you'll never see a bit of trash in the paint. Well, I hope. What do you think? We had another builder here rent a booth in a fancy car painting shop, and the paint job on his Zenair Zodiac looked flawless. In Greenville, SC they used to transport plastic airplanes with the wings off to a nice filtered booth at an auto paint shop down White Horse Rd. and paint them there. The pressure air used for the spray system was freeze-dried to take out water and other impurities. The painter was a real pro who instructed in the auto body section at Greenville Tech. The ships always came back to the hangar looking great. How's about it? Do you paint in the hangar or in a paint shop booth? We have two more to do and want clean glossy finishes without flaws. TIA. It is true that polyurethane paints can be wet sanded and buffed once they have cured. I have seen it done within the last month. The best way is to make sure that there is no dust in the air, and no insects can get in the paint during the two hours that the paint is drying to tack free. Obviously, a paint booth is great if the airplane is small enough. If not, then the hangar should be very clean, and sealed against insects. It also helps to have banks of halogen or florescent lighting so that the painter can really see what they are doing. If I saw "dust" in the paint I would wonder if the piece was really clean before the paint was applied. Don W. Getting a glossy, perfect finish requires more than wet sanding with #600. After the #500, more wet sanding with #1200, then #2000, then a power buffer with 3M "Finesse It," then "Perfect It." The finish will resemble hand-rubbed lacquer, with the deep gloss. Yes -- a paint booth is far preferable, but, strictly speaking, not a requirement. |
![]() " jls" wrote in message ... I just saw a beautiful Lancair 320 painted in the hangar. It looks great until you get up close. The polyurethane paint is very glossy, but there is dust particles and trash all over it. Even a few insects in the middle of our NC winter. Not to worry, says the painter, who runs an autobody repair shop. He says he'll use 600 grit and water sand it all out and you'll never see a bit of trash in the paint. Well, I hope. What do you think? We had another builder here rent a booth in a fancy car painting shop, and the paint job on his Zenair Zodiac looked flawless. In Greenville, SC they used to transport plastic airplanes with the wings off to a nice filtered booth at an auto paint shop down White Horse Rd. and paint them there. The pressure air used for the spray system was freeze-dried to take out water and other impurities. The painter was a real pro who instructed in the auto body section at Greenville Tech. The ships always came back to the hangar looking great. How's about it? Do you paint in the hangar or in a paint shop booth? We have two more to do and want clean glossy finishes without flaws. TIA. Two things you might consider if you do the hanger again. Always keep the floor soaked. You would be amaized how much dust you kick up walking or dragging an air hose. Try to close up the hanger as much as possible, and force feed makeup air through some sort of filter. Get creative, a cluser of hardware store HVAC filters are cheap, maybe a couple dollars a piece, and I have even seen wet bedsheets used. Neither will make up for the benefit of a good commerical booth, but they can make a lof of difference on a dusty day. You might even want to stick a air fitting in the end of a 10' piece of cheap tubing, and flatten the opposite end. Hook it to a air hose and blow your lights and ceiling beams down the day before each job. I haven't painted many airplanes, but I have a bunch of cars. |
... I just saw a beautiful Lancair 320 painted in the hangar. It looks great until you get up close. The polyurethane paint is very glossy, but there is dust particles and trash all over it. Even a few insects in the middle of our NC winter. Not to worry, says the painter, who runs an autobody repair shop. He says he'll use 600 grit and water sand it all out and you'll never see a bit of trash in the paint. Well, I hope. What do you think? I suspect that it will look better than it does now... ... How's about it? Do you paint in the hangar or in a paint shop booth? We have two more to do and want clean glossy finishes without flaws. TIA. I ain't never painted no airplane, but I did a 26'sailboat in polyurethane (Awlgrip) not too long ago- does that count? Not having a booth, I did it in a plastic "tent" outdoors (30'x14'about 15 feet at the peak). It turned out pretty darn good, if I may say so myself... Issues: Temperature - Linear polyurethane wants to stay warm overnight to cure. Dirt - A plastic "tent" with a big plastic tarp for a floor worked fine for me. But a real booth would be a lot nicer to work in and probably have better light (that helps a LOT). Overspray - LPU overspray stays sticky for a long time. You need to be able to control it - if you are in typical T hanger you will probably really **** off the guy next door. Air - you REALLY want a source of outside air to breathe. The MSDS claims that the paint has "poor warning qualities" - that's a euphemism for "by the time you smell it in your mask, you are f***ed". Da Gun - what kind of gun are you using? Plain white isn't as demanding as metalics, but I've learned that a cheap spray gun is more trouble than it is worth. I have an old top of the line (for it's day) Binks out in the garage - it was worth every penny. Nowadays HVLP stuff seems to be the way to go - on a large project you may save enough on the reduction in waste (from overspray) to pay for the gun. I don't have any recommendation on the modern guns though. Prep is 99 percent of finished result. If you can feel ANYTHING when you slide your hand across the surface you WILL see it when you spray a gloss coat on. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Maxwell wrote:
Try to close up the hanger as much as possible, and force feed makeup air through some sort of filter. Get creative, a cluser of hardware store HVAC filters are cheap, maybe a couple dollars a piece, and I have even seen wet bedsheets used. Precisely. I've not painted an airplane (well not seriously) but I've help paint a fire engine with Imron. We were supposed to get access to a paint booth at a nearby heavy equipment manufacturer but that fell through so we entirely wrapped the equipment bay with heavy plastic and blew in filtered air. The result (5 coats of color, 5 coats of clear) were astounding. |
![]() " jls" wrote in message ... I just saw a beautiful Lancair 320 painted in the hangar. It looks great until you get up close. The polyurethane paint is very glossy, but there is dust particles and trash all over it. Even a few insects in the middle of our NC winter. Not to worry, says the painter, who runs an autobody repair shop. He says he'll use 600 grit and water sand it all out and you'll never see a bit of trash in the paint. Well, I hope. What do you think? We had another builder here rent a booth in a fancy car painting shop, and the paint job on his Zenair Zodiac looked flawless. In Greenville, SC they used to transport plastic airplanes with the wings off to a nice filtered booth at an auto paint shop down White Horse Rd. and paint them there. The pressure air used for the spray system was freeze-dried to take out water and other impurities. The painter was a real pro who instructed in the auto body section at Greenville Tech. The ships always came back to the hangar looking great. How's about it? Do you paint in the hangar or in a paint shop booth? We have two more to do and want clean glossy finishes without flaws. TIA. It is all about prep work. You can get a good paint job painting almost anywhere if you take proper measures against dust and other trash. The first step is to give the hangar a thorough cleaning. Get a pressure sprayer and clean the walls, ceiling, and floor. Vacuum, sweep, etc. thoroughly to get rid of the dust. Before painting, use a hose to spray down the walls and floor again. You want everything wet so any dust sticks to the floor, walls, etc. You probably need to set up some box fans to exhaust the overspray and fog from the hangar. Make sure the fans exhaust air. Blowing high speed air into the area will stir up dust, which you don't want. Of course, you should really make sure you have explosion proof lights and fans so you don't get a nasty surprise. You also need appropriate safety equipment - a reliable fresh air breathing source, and a tyvek suit, gloves, and mask to keep the paint from getting on your skin. The final issue (which would prevent me from spraying in a T-hangar) is keeping overspray from drifting into adjoining hangars. Get overspray on your neighbor's Bonanza and you'll end up with a real problem that costs real money to fix. KB |
On Mon, 22 Jan 2007 15:46:07 -0500, " jls" wrote:
How's about it? Do you paint in the hangar or in a paint shop booth? We have two more to do and want clean glossy finishes without flaws. TIA. Guy down at the airport painted his newly-restored classic in his hangar. Ended up paying few thousand bucks to de-paint the planes in the hangars next to him....turns out there were little gaps in the partitions, and the yellow paint drifted through them. The guy also was evicted, since the leasor bans painting in the hangars. Ron Wanttaja |
To help prevent static buildup, ground the airplane before painting.
I was wondering when someone would mention this. Nothing like ruining
the windows in the King Air next hangar over $$$$$. Be very careful of this. As to the paint, I stripped and painted my wings, using only a space outside with a tall building for shade late on a spring evening. I just got everything ready and waited a couple of days for calm winds, and used an HVLP and Imron. The actual spraying doesn't take that long. I was told and found out, that Imron can be wet sanded with 1500 grit and then buffed as long as you do it the first couple of days after you spray. I did the leading edges and they seemed to do fine. It came out very smooth. This approach can buff out almost any paint, as long as you put in the time to do it. THERE IS A LOT OF AREA TO BUFF ON AN AIRPLANE. You know this I hope. It could be more work than you're willing to do, and it won't look right unless you do. Bud Ron Wanttaja wrote: On Mon, 22 Jan 2007 15:46:07 -0500, " jls" wrote: How's about it? Do you paint in the hangar or in a paint shop booth? We have two more to do and want clean glossy finishes without flaws. TIA. Guy down at the airport painted his newly-restored classic in his hangar. Ended up paying few thousand bucks to de-paint the planes in the hangars next to him....turns out there were little gaps in the partitions, and the yellow paint drifted through them. The guy also was evicted, since the leasor bans painting in the hangars. Ron Wanttaja |
Rules on what can be in a hangar | Brett Justus | Owning | 13 | February 27th 04 05:35 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
