![]() "Danny Deger" wrote in message ... The key to the later stall recovery technique is to be very good at flying the airplane very close to the stall by using aircraft feel, i.e. practice slow flight a lot. The advantage is very little altitude lost in the recovery. Any glider pilot will know exactly what you are talking about. The best way to gain altitude in a thermal is usually to be in a tight turn (to remain in the core of the thermal) and remain just a couple knots over the stall. If you feel the stall start to happen, you just release some back pressure until things feel ok again. Vaughn Danny Deger |
Y'All,
I very much agree with Vaughn Simons approach to stall recognition. I found that I could greatly decrease a student's apprehension about the 'stall' by introducing them to the low power-on oscillating stall series in a C-150. From 'clean' level cruise we would reduce power to 1500 rpm and continue holding altitude at that power into the stall which usually shows with one wing or the other dropping. This is corrected not with the yoke but by using the rudder to raise the wing. We would work the rudder as needed to raise the wing and break the stall until it required lowering the nose. The series could be repeated over and over within a 100' altitude margin. Try it, you'll love it and never fear the intentional stall again. It is the unintentional stall that is the killer. Gene |
![]() wrote in message news ![]() Y'All, I very much agree with Vaughn Simons approach to stall recognition. I found that I could greatly decrease a student's apprehension about the 'stall' by introducing them to the low power-on oscillating stall series in a C-150. From 'clean' level cruise we would reduce power to 1500 rpm and continue holding altitude at that power into the stall which usually shows with one wing or the other dropping. This is corrected not with the yoke but by using the rudder to raise the wing. We would work the rudder as needed to raise the wing and break the stall until it required lowering the nose. The series could be repeated over and over within a 100' altitude margin. I agree with this 100%. Every pilot should be very good at using rudders to raise a dropped wing in a stall. I also think the stall should be "barely" broken and the plane recovered this way -- as opposed to a subtantial drop in the nose to recover. Danny Deger |
Cable break recovery spin entry... as previously discussed | [email protected] | Soaring | 26 | July 3rd 05 08:28 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Proper stall recovery technique | Chris OCallaghan | Soaring | 0 | February 2nd 04 10:33 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
