Strap-on headlamps and their ilk
Old January 25th 07, 10:54 PM posted to rec.aviation.piloting
Morgans
Default Strap-on headlamps and their ilk
"Casey Wilson" wrote
I did some unsuccessful Googling to see if I could find one that will
clip onto the side or top of the headset. Anybody seen something like
that? (I did find the one that will clip onto the bill of a cap, but it
didn't seem like it would work on the headset.)
You might want to look at a type that gives more flexibility that the ball
cap type, or the headband type. I always found that the ability to move the
aiming point up and down was about the most important ability in a light of
this type, to get the light in the place where it needed to be, according to
where my bifocals "wanted" my head to be tilted.
Do you wear glasses? If you do, there is a small led that hooks onto the
temple of your eye glasses. If you don't, there is another style that has
an upper frame of eyeglasses, and has a ball joint adjustable light on each
side of the frame, and gives great aiming flexibility.
They should be about the right brightness for night operations. I have not
tried wearing the fake frame with my glasses, but that might still be the
best way to go, because of the better aiming system. The clip on style do
not have a ball joint, and you would have to improvise to get the best
aiming. I slipped a small piece of model airplane fuel tube over the
clamping system, to make them stay where I aimed them.
I got these at Lowe's hardware and lumber stores.
Another unrelated point, is a new type of light just out, available at
Lowe's.
I recently got a replacement bulb for my 3-D cell Maglight, that is a 3 watt
LED bulb! All I can say, is WoW! The brightness and purity of light and
evenness of pattern is hard to believe. It would make night pre-flights
much more "revealing."
I saw a day or two ago, that there is now a 3 watt LED flashlight now
available in a 3-AA model. I've got to get one of these babies! 3 watts is
an amazing difference if what you have ever seen in a flashlight.
Jim in NC
Jim in NC
Old January 27th 07, 08:53 AM posted to rec.aviation.piloting
Dave S
I use a pelican LED light, usually green lens, velcro'd to the earcup.
it bathes the panel in a soft light. Uses 4 button batteries. A cop shop
or aviation supply house should have em for about 20 bux. The case is
the same width/circumference as a AAA pelican light, but the lengh is
much shorter.. maybe 1.5 inches at the most.
I have 3 of those. If my flight will include dusk or dark its on the
earcup before I start up. I have another around my neck. the back up is
in the bag along with a BRIGHT led torch and a luminous "electric chemlite"
The green doesnt wash out red/magenta on the charts like a red lamp does.
Dave
Casey Wilson wrote:
I'd like to revisit a topic bandied about on this newsgroup many moons ago.
At the time I wasn't in the market for one of those LED gizmos that straps
on the head -- now I am.
I vaguely recall there being some adverse criticism about the inability
to control what was perceived as "too bright." Is that still the case? Or
have the devices improved since then?
If you use one, do you strap it on before takeoff? Or wait until it is
needed to put it on? Do you put in on under or over your headset? In either
case, how long can you tolerate it?
clip onto the side or top of the headset. Anybody seen something like that?
(I did find the one that will clip onto the bill of a cap, but it didn't
Old January 27th 07, 07:10 PM posted to rec.aviation.piloting
Blueskies
"Casey Wilson" wrote in message news:Bj6uh.3184$R65.730@trnddc01...
: I'd like to revisit a topic bandied about on this newsgroup many moons ago.
: I did some unsuccessful Googling to see if I could find one that will
: clip onto the side or top of the headset. Anybody seen something like that?
: (I did find the one that will clip onto the bill of a cap, but it didn't
: seem like it would work on the headset.)
: Regards,
: Casey Wilson
: Freelance Writer
: and Photographer
I don't like the reflection back at me from the windshield and windows when I wear one of these head band type lights. I
prefer the little one that clips on the visor...
