#51
On Thu, 25 Jan 2007 17:07:06 -0500, in
, john smith wrote: The least expensive, resuable relief bottle I have found is a Rubbermaid 2-liter decanter with screw on lid. It has the largest opening of any container short of a paint can. I prefer the 3-liter plastic Coke bottles or the 64-oz Gatorade bottles... The Gatorade bottles at least have an acceptable size opening... The 3-liter Coke bottles require a bit more concentration... The 2-liter bottles should only be used with a funnel or condom type catheter... |
#52
On Wed, 24 Jan 2007 20:15:26 -0500, in
, TF wrote: snip http://www.aopa.org/asf/publications...m?article=4985 |
#53
Paul kgyy wrote:
And remember not to key the mike when you ask your copilot to pass the bag. LOL - also note that if you're IFR, use of the device will automatically trigger a course change request from ATC. "We have a new route for you, ready to copy" ATC shorthand for "spill the bottle". Gel Pacs rule. In tight cockpits, external catheters rule the rule. |
#54
Peter R. wrote:
One tip, though: Don't bother hooking up a funnel and hose to the jug. This will result in a most undesirable backflow. This is what Usenet is all about: learning from other people's mistakes. .... Alan -- Alan Gerber PP-ASEL gerber AT panix DOT com |
#55
Grumman-581 wrote:
I remember bitching about my expresso maker when it claimed that it made 6 cups... It made 2 at best and I'm not even sure they were a full 8 ounces... Well, espresso is served in those tiny little "cups", right? That's probably what they meant. I've got a four-cup coffee pot that makes two mugs of coffee. It's theoretically four six-ounce cups, but it's actually closer to five ounces each. I tried pouring water in from a measuring cup instead of using the pot one time, and it went all over the counter. .... Alan -- Alan Gerber PP-ASEL gerber AT panix DOT com |
#56
I spent a few months living in a rainforest. We slept in hammocks, and
it was a significant hassle to get up in the night and relieve oneself. At the end of each day we were typically a little dehydrated from the day's exertions. The method I used to get hydrated but not need to go for the 8 hours of night was as follows: Drink A LOT of water between around 4pm and 5pm - more than I wanted to. Then sip very small amounts for the next 4 hours. I found I needed to relieve myself quite a few times for the first 2-3 hours, then less and less so. Then go to bed. I reliably did not need to get up in the night. No doubt the physiology is different for night vs day, but I'm betting the same method would work for flying (although I haven't tried it). As some people have said, you need to avoid diuretics like caffeine. Tom On Jan 25, 7:41 pm, Alan Gerber wrote: Grumman-581 wrote: I remember bitching about my expresso maker when it claimed that it made 6 cups... It made 2 at best and I'm not even sure they were a full 8 ounces...Well, espresso is served in those tiny little "cups", right? That's probably what they meant. I've got a four-cup coffee pot that makes two mugs of coffee. It's theoretically four six-ounce cups, but it's actually closer to five ounces each. I tried pouring water in from a measuring cup instead of using the pot one time, and it went all over the counter. ... Alan -- Alan Gerber PP-ASEL gerber AT panix DOT com |
#57
![]() "Alan Gerber" wrote This is what Usenet is all about: learning from other people's mistakes. How true. If you were to use a small vent tube in addition to the flow tube, that would eliminate the backup problem. It is just another point of leakage, so to speak. -- Jim in NC |
#58
On Fri, 26 Jan 2007 00:41:57 +0000, in ,
Alan Gerber wrote: Well, espresso is served in those tiny little "cups", right? That's probably what they meant. OK, this got me a bit curious, so I did a bit of measuring... My normal coffee "cup" is basically cylinder shaped with approximately a 2-7/8" inside diameter and a 3-7/8" height... Leaving about 3/4" from being full so that I have room to add sugar and cream to it in addition to not spilling it while walking, I get 10 oz of coffee in it... The little wimpy "cup" that Grace uses turns out to give exactly 8 oz with the same basic space left at the top... Of course, if I'm seriously caffeine deprived, I have mugs that are considerably larger... They'll probably take the entire expresso pot and have quite a bit of room left over... I've got a four-cup coffee pot that makes two mugs of coffee. It's theoretically four six-ounce cups, but it's actually closer to five ounces each. I tried pouring water in from a measuring cup instead of using the pot one time, and it went all over the counter. Been there, done that... These damn companies need to learn that if they are going to use the word "cup", it means 8 oz... These little 2-3 oz espresso containers are not "cups"... |
#59
On Thu, 25 Jan 2007 22:40:23 -0500, in ,
Morgans wrote: If you were to use a small vent tube in addition to the flow tube, that would eliminate the backup problem. It is just another point of leakage, so to speak. Of course, some of have aircraft with canopies, so theoretically, all we need to do is slow to an acceptable speed, slide back the canopy, and pee off the side... grin Come to think of it, drilling a hole in the floor and running a tube through there for a relief tube is starting to sound a lot better... |
#60
Iran is preparing for an underground nuclear test with North Korean help before year's end | AirRaid Mach 2.5 | Naval Aviation | 19 | March 19th 07 04:21 AM |
MSC podcast with Gordon Boettger - Preparing for the Wave | [email protected] | Soaring | 9 | February 2nd 06 03:20 PM |
Israel Preparing For Military Action To Stop Iran's Nuclear Program... | [email protected] | Naval Aviation | 1 | January 23rd 06 04:57 AM |
Operation Brother's Keeper preparing for Rita | Jim Burns | Owning | 1 | September 23rd 05 12:59 AM |
Operation Brother's Keeper preparing for Rita | Jim Burns | Piloting | 1 | September 23rd 05 12:59 AM |
