"ArtKramr" wrote in message ... I ran into quite a few guys who flew P-39's. The all said the same thing. It had dangerous flat spin characteristics. . Benig bombardier I asked, "what the hell is .that?" They explained. I don't remember what they said so I can't explain it here. But I am sure guys like Ed and Dudley can. Flat spins are an aft cg scenario for the P39. Generally, in an airplane with positive stability , a flat spin has to be entered deliberately and HELD with power and aileron; the exact amounts of each differ with each type spun flat. The P39, had a problem with aft cg movement along a very narrow in range parameter with ammunition expenditure. If the airplane exceeded critical angle of attack when the ammo cans were at a certain level, the departure could easily cause an out of envelope spin mode that could go flatter as autorational velocities and moments of inertia changed as the spin progressed into ever increasing yaw rates. Departure in a P39 while in this configuration was a very difficult thing to handle. Pilots like Tex Johnston had little trouble with recoveries under controlled conditions, but a low time pilot on operational flying could find himself in a world of hurt if getting caught this way. It usually happened if the airplane went defensive and turning after an initial extended firing run air to air. If engaged and going defensive, as the speed bled due to radial g and the angle of attack increased, a departure was imminent if you went deep enough into the turn, especially if the turn was being forced down by an aircraft with a lighter WS and lower corner. You could easily be pulled into departure city in a situation like that, and this is indeed what nailed a lot of 39 drivers. If you departed and went flat in this airplane, recovery was NOT where the amateurs should be!!! I should say also that most of the 39 pilots I have talked to through the years liked the airplane after flying it for a protracted period...and that includes Yeager! The trick was to fly it right the first time through to the last time....and I could say THAT about every airplane I've ever flown at least!! :-))) Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/CFI Retired |
| Thread Tools | |
| Display Modes | |
| Wrinkly flat panels | [email protected] | Home Built | 27 | March 6th 04 03:12 PM |
| Accelerated spin questions | John Harper | Aerobatics | 7 | August 15th 03 08:08 PM |
