Subject: #1 Jet of World War II
From: Guy Alcala Date: 7/23/03 7:33 PM Pacific Daylight Time Message-id: bombs and dropping from higher up, but it's by no means certain that's the case (unlike some on the NG, I don't rule out the possibility, but the only way to find out for sure would have been to actually try it, and that didn't happen). I guess it is possible to destroy Berlin one house at a time, But that isn't the best way to get the job done. Arthur Kramer Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
ArtKramr wrote:
Subject: #1 Jet of World War II From: Guy Alcala Date: 7/23/03 7:33 PM Pacific Daylight Time Message-id: bombs and dropping from higher up, but it's by no means certain that's the case (unlike some on the NG, I don't rule out the possibility, but the only way to find out for sure would have been to actually try it, and that didn't happen). I guess it is possible to destroy Berlin one house at a time, But that isn't the best way to get the job done. That assumes that destroying German houses was our (the U.S.A.A.F.) avowed policy and doctrine. It wasn't, although as a practical matter the U.S. stopped worrying about doing area bombing with the heavies from the fall of 1943 on to the end of the war. If we could see to bomb visually, great; otherwise, we'd bomb by radar or other radio navaids with a 2 or 3 mile CEP, which is area bombing by anyone's standard. Of course, even when the heavies could bomb visually, 'precision' was relative. Here's Elmer Bendiner, a B-17 Nav. in the 379th BG(H), talking about the June '43 mission against the I.G. Farben synthetic rubber plant at Huls, in the Ruhr. Writing some 35 years later, he says: "Our losses, including those of the main and diversionary forces, amounted to 20 planes, two hundred men, roughly ten percent. Nevertheless, our superiors were pleased with us because we had dropped 422 tons bombs and, according to the reconnaissance photos, only 333.4 tons had been wasted on homes, streets, public parks, zoos, department stores and air-raid shelters. This passed for precision. "Actually Huls might have been put out of comission permanently if there had been a follow-up. After our mission the city went almost unscathed right to the end of the war. We had devastated buidlings and shaken morale, but tire production, although on a limited scale, was resumed within a month. Synthetic-rubber production suffered perhaps six months but soon was reaching new peaks. I have searched the records and find no explanation for our failure to return and finish the job. The Germans were astonished at the time. After the war American scholars of our air strategy were surprised, but nobody nitpicks a victory. A cold analysis of the balance sheet at Huls indicates that the lives lost that day -- American and German, in the air, on the ground, and in shelters underground -- had not brought closer the end of the war or of Hitler. But at the time we did not know the price and thought we had a bargain." As Bendiner writes, the Huls raid was considered by us at the time to have achieved excellent bombing results. IIRR, "Impact" devoted an article to the mission. Guy |
On Thu, 24 Jul 2003 02:33:56 GMT, Guy Alcala
wrote: [snip agreed points] The question is, what was the typical load actually carried by Lancs? In 1943, it was about 8,000 lb. (effective bombload was something like 7,450 lb. The difference represents aborts and a/c shot down before bombing ). Actually, that's valid for the Berlin raids, but shorter distance tonnages were higher, even before 1944-45. Middlebrook gives figures of 10,000 - 13,000 lbs bombloads for the Hamburg raids in 1943, against approximately 5,000 lbs for the B-17s which seems relatively constant regardless of the penetration (e.g. mentioned again for the first Berlin raid, according to Ethell & Price). The B-17s also had a reduction in percentage of bombload carried to target due to losses, even if the use of air spares reduced the abort percentage. [snip other agreed points] Another point is the actual numbers of bombs on target; daylight raids were preferable to both forces, when this was regarded as practicable, even with weather and visual constraints (smokes screens & dust). Gavin Bailey -- "...this level of misinformation suggests some Americans may be avoiding having an experience of cognitive dissonance." - 'Poll shows errors in beliefs on Iraq, 9/11' The Charlotte Observer, 20th June 2003 |
![]() "John Halliwell" wrote in message ... In article , Guy Alcala writes No, I'm saying that _if_ you followed US practises etc., the Lanc's performance would be within a few % either way of the B-17's. But why drag the performance of an aircraft down by using it in a way that is clearly inefficient? All this discussion has confirmed to me is how inefficient the big box formations actually were. Dragging the performance of a heavy bomber down to the point where it is carrying a similar load to a Mossie, whilst remaining considerably vulnerable (and with a crew of ten), doesn't make much sense to me. Its a good job they didnt do that then isnt it ? A couple of Mossies with a light load, perhaps 2,000lbs each start to sound more and more promising. Small, fast formations may have been very effective. In daylight they would have suffered excessive losses. The Mosquitoes of Bomber Command were excellent night bombers but unless you have long range fighter escorts they would not have survived over Germany in 1943. The Mosquito's that were used in daylight raids were mostly the FB variety typically carrying 1000lb bomb loads and making relatively shallow penetration raids into France and the low countries Nowhere did I say that you had to do so, but that is the variable that is always left out of the Lanc vs. B-17 threads, so that they wind up comparing apples and oranges. The B-17 bomb bay was not the best arrangement for carrying large loads. As such had it been used in night ops, the range/payload may not have been able to be improved to compensate for lighter fuel (or fewer guns/crew) loads. On that basis, it's easier to drag the Lanc down by hampering it with US practises than boost the B-17 by using RAF practises. Not really. Discarding the waist gunners and fairing over the positions would have saved several hundred pounds and cruising at 30,000 ft the B-17 would have been a tough target for German nightfighters. Indeed bomber command used Fortress III's (B-17G) in 214 squadron in the Radio countermeasures role. Their operational loss rate was 1.1% Keith |
John Halliwell wrote:
In article , Keith Willshaw keithNoSpa writes In daylight they would have suffered excessive losses. The Mosquitoes of Bomber Command were excellent night bombers but unless you have long range fighter escorts they would not have survived over Germany in 1943. I was assuming long range fighter escort as that was the only way daylight bombing was ever going to work. Without it, losses would be high as they were with all other types. Not really. Discarding the waist gunners and fairing over the positions would have saved several hundred pounds and cruising at 30,000 ft the B-17 would have been a tough target for German nightfighters. On that basis, removing the waste guns (of questionable use anyway) and fairing over might have been a better idea for daylight ops. No real need to fair over the waist hatches, as they either already have removable hatches (pre-B-17G) or fixed windows with the ball mount for the ..50 installed in it. As I noted in another post, removing the waist guns and/or gunners was done from mid-44 on in the ETO. ETO B-24s, about the same time, removed the ball turret and the gunners were sent to the MTO. the other advantage of removing guns/gunners aft of the wing was that it allowed the Cg to move back forward, closer to where it was supposed to be. Like most a/c, weight had been constantly added, and it usually seems to be added behind the Cg. This was a problem with both the B-17 and B-24, making them less stable and more difficult to fly in formation/on instruments. Guy |
Guy Alcala writes: John Halliwell wrote: In article , Guy Alcala writes In short, design and equip them to do the same job and they'll do it with payloads within a couple of hundred pounds (either way) of each other. The whole Lanc vs. B-17 argument is just ludicrous. The crucial point though, is that you're assuming the Lanc would have to follow US practises and fly in the big box formations. No, I'm saying that _if_ you followed US practises etc., the Lanc's performance would be within a few % either way of the B-17's. Nowhere did I say that you had to do so, but that is the variable that is always left out of the Lanc vs. B-17 threads, so that they wind up comparing apples and oranges. Whilst this may have suited the B-17 with machine guns sprouting everywhere (although I don't think it was appropriate before P-51D escorts were available), it may not have suited the Lanc. You simply can't enforce US practises on UK types in an attempt to 'equate' them with one another. I've just come across my notes from the Day Bomber Lanc thread, and here's some stuff that didn't make it into the thread that may be germane to this discussion. With reference to armor weight. Wartime Lancasters didn't have a whole lot of armor. The only armor, in fact, was the Pilot's seatback, and a bulkhead over the main wing spar, where it crosses the fuselage. Figure about 150# of armor. It did have self-sealing tanks. (I don't know if it was for all tanks, though. If not, you lose about 7% fuel capacity, and 3/4# for every gallon protected. U.S.A.A.F. day bombers carried armor at all crew positions, except Bombardier 9Can't se through armor, after all) and the rule of thumb was 100# per position, doubled in the case of the cockpit, which was armored both to the rear, and to the front. Each oil cooler or radiator that was armored cost 80#, Turret weights, less guns, are about the same. A .50 cal gun weights as much as 2 .30s, so the tail turret doesn't change, but the nose and top turrets gain 65#. A ball turret, with guns, or its equivalent in a remotely sighted turret, plus the extra crewman to operate it, is 1200#. So - added weight for a day-bomber Lanc. (This will have to come out of fuel or bombs), we'll assume similar ammunition wieghts Armor for nose, tail, and top turrets: 300# Armor for cockpit, pilot only 200# Addition of lower turret 1200# upgrade guns to .50 cal 130# Armored Oil Coolers 320# Armored Radiators 320# That's a total of 2470# Note that a co-pilot is a good thing if adding a copilot, add 370# (170# crewman, more armor) Total oe 2840# Note that that isn't adding stuff like waist guns. THere's another area of vulnerability. Liquid-cooled engines are much less tolerant of damage, even if teh cooling system is protected. A single substantial hit (.50 cal & up) on the blcok of a liquid cooled engine _will_ crack the block, causing coolant and oil leaks. The air-cooled radials are much more tolerant of this kind of damage. You can remove entire cylinders, and the engine may run well enough to get home. There's a substantial extra safety margin, there. One Halifax squadron removed the nose and mid-upper turrets, armour, flame dampers and various other bits, the lighter weight and less restricted engines flew higher, faster and their losses were reduced significantly. There's an old story we tell up here in the North Woods. Two friends are out hiling, and they spot a very angry Black Bear. (Black Bears, btw, while smaller than Grizzlies, are much better tree climbers.) One hiker immediately drops his pack, and pulls out a pair of sneakers. (Trainers, for you U.K. blokes) His companion inquires "What are you doing? You can't outrun that bear!" The reply was "Don't have to outrun the bear. I just have to outrun _you_!" The point is, you want to be faster and higher than somebody else, making _them_ the easier target. And so did B-17 and B-24 groups operating by day at various times and places, and that's my point - it's ludicrous to compare two aircraft designed and equipped for totally different missions and claim that one is "superior" to the other, by looking _only_ at the mission for which one of them is optimised. In the B-17 vs. Lanc argument, this method is routinely used to 'prove' that the Lanc had a better payload/radius than the B-17, by comparing the Lanc's performance operating singly at night, with the B-17's performance operating in formation by day at higher altitudes. Basing a conclusion on such an 'analysis' is a prime example of GIGO. Concur. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
Peter Stickney wrote:
snip I've just come across my notes from the Day Bomber Lanc thread, and here's some stuff that didn't make it into the thread that may be germane to this discussion. With reference to armor weight. Wartime Lancasters didn't have a whole lot of armor. The only armor, in fact, was the Pilot's seatback, and a bulkhead over the main wing spar, where it crosses the fuselage. Figure about 150# of armor. It did have self-sealing tanks. (I don't know if it was for all tanks, though. If not, you lose about 7% fuel capacity, and 3/4# for every gallon protected. U.S.A.A.F. day bombers carried armor at all crew positions, except Bombardier 9Can't se through armor, after all) and the rule of thumb was 100# per position, doubled in the case of the cockpit, which was armored both to the rear, and to the front. Later, they removed much of the crew armor and replaced it with flak curtains, as the latter was considerably lighter and only slightly less effective. Each oil cooler or radiator that was armored cost 80#, Turret weights, less guns, are about the same. A .50 cal gun weights as much as 2 .30s, so the tail turret doesn't change, but the nose and top turrets gain 65#. Mo 65 vs 24lb (some sources give 22, but that may be the fixed variety). A ball turret, with guns, or its equivalent in a remotely sighted turret, plus the extra crewman to operate it, is 1200#. So - added weight for a day-bomber Lanc. (This will have to come out of fuel or bombs), we'll assume similar ammunition wieghts Armor for nose, tail, and top turrets: 300# Armor for cockpit, pilot only 200# Addition of lower turret 1200# upgrade guns to .50 cal 130# Armored Oil Coolers 320# Armored Radiators 320# That's a total of 2470# Note that a co-pilot is a good thing if adding a copilot, add 370# (170# crewman, more armor) Total oe 2840# And then you can add all the extra fuel for formating, close formation, climbing higher, and hauling all of it there and back. I've read it somewhere that the single-pilot B-25s and B-26s saved about 300 lb., but ISTR that the inference was that this was due to the emoval of dual controls/instruments plus the armored seat, i.e. not counting the co-pilot's weight or any other armor. There's also some minor additional weight for the extra oxygen tanks/regulators/lines and the intercom lines for each additional crewman. And then there's the ammo weight. I've seen 'typical' loads quoted as 13,000 rounds for a Lanc, 6,500 rounds for a B-17. Belted .50 cal. weighs roughly three times as much as .30 cal. For long, deep daytime missions beyond fighter range in 1943, that 6,500 rounds might grow to 10 or even 12,000 depending on the crew's inclinations and what the pilot would allow (some crewmen were wont to build 'cocoons' for themselves out of extra flak vests; tail gunners who did this could cause serious Cg problems). BTW, I don't recall seeing a photo or reading that the Brit bomber crews wore flak vests and helmets, at least by night. I imagine they might have adopted them if they went over to day bombing, but does anyone know for a fact? Guy |
On Wed, 23 Jul 2003 11:40:46 GMT, Guy Alcala
wrote: [Lanc bombing height] The most common bombing heights (excluding exceptions like the Peenemunde raid) seem to have been around 18,000 feet. Odd that you should mention that, as Middlebrook ("The Nuremberg Raid") says that a/c of all the Groups on the mission (with the exception of No. 1 GP; see below), whether Lanc or Halifax, were evenly assigned to one of four cruise heights -- 20, 21, 22, or 23 thousand feet. This was common practice: although I was suprised to see 3 Group getting the lower height bands even as they started to re-equip with Lancasters in early 1944. The raids I researched may not be representative, however, and I think those might have included some late Stirling raids, which would explain it, although they were normally banded by Group and by type within that, just like the wave timings for TOT. As it happens, the bombing height for the crew in question varied from aircraft to aircraft, and seemingly independent of the assigned height bands. The highest bombing altitude recorded was 21,500 ft (30/31 Jan 44, Berlin) otherwise 20,000 -20,500 ft (27/28 Sep 43, Nuremburg; 3/4 Sep 43, Berlin) and a lot of 18,000 -19,000 ft (31 Aug/1 Sep 43, Berlin; Munchengladbach 30/31 Sep 43, etc, etc). In addition to the engine differences, there's the considerable difference in fixed weights (carried both to and from the target) due to extra crew, armor, guns, turrets etc., and the extra fuel required for formation assembly (an extra 1/2 to 2 hours before setting out), climb to higher cruise altitude and flying in formation (throttle jockeying). Yeah, I've just exhumed that one myself. [snipadoodledo] In short, design and equip them to do the same job and they'll do it with payloads within a couple of hundred pounds (either way) of each other. The whole Lanc vs. B-17 argument is just ludicrous. Agreed. Still, it beats doing the housework. Gavin Bailey -- "...this level of misinformation suggests some Americans may be avoiding having an experience of cognitive dissonance." - 'Poll shows errors in beliefs on Iraq, 9/11' The Charlotte Observer, 20th June 2003 |
The Revolution Will Not Be Televised wrote:
On Wed, 23 Jul 2003 11:40:46 GMT, Guy Alcala wrote: [Lanc bombing height] The most common bombing heights (excluding exceptions like the Peenemunde raid) seem to have been around 18,000 feet. Odd that you should mention that, as Middlebrook ("The Nuremberg Raid") says that a/c of all the Groups on the mission (with the exception of No. 1 GP; see below), whether Lanc or Halifax, were evenly assigned to one of four cruise heights -- 20, 21, 22, or 23 thousand feet. This was common practice: although I was suprised to see 3 Group getting the lower height bands even as they started to re-equip with Lancasters in early 1944. The raids I researched may not be representative, however, and I think those might have included some late Stirling raids, which would explain it, although they were normally banded by Group and by type within that, just like the wave timings for TOT. The other cause may be that 3 Group had a couple of Lanc Mk. II squadrons in roughly that period, 115 and 514. Come to think of it, 61 Squadron had a single Lanc Mk. II flight early in the a/c's career, but I don't know if the crew you were studying was flying Merlin or Hercules-engined a/c. The latter seem to have had a service ceiling a two or three thousand feet lower than the Merlin-engined a/c, so possibly that explains it. Guy |
FS: 1984 "Aces And Aircraft Of World War I" Harcover Edition Book | J.R. Sinclair | Aviation Marketplace | 0 | July 16th 04 05:27 AM |
FS: 1996 "Aircraft Of The World: A Complete Guide" Binder Sheet Singles | J.R. Sinclair | Aviation Marketplace | 0 | July 14th 04 07:34 AM |
FS: 1984 "Aces And Aircraft Of World War I" Harcover Edition Book | J.R. Sinclair | Aviation Marketplace | 0 | January 26th 04 05:33 AM |
FS: 1984 "Aces And Aircraft Of World War I" Harcover Edition Book | J.R. Sinclair | Aviation Marketplace | 0 | December 4th 03 05:40 AM |
FS: 1984 "Aces And Aircraft Of World War I" Harcover Edition Book | Jim Sinclair | Aviation Marketplace | 0 | September 11th 03 06:24 AM |
