Straight-ins at uncontrolled airports?
Old February 12th 07, 05:49 AM posted to rec.aviation.piloting
Mxsmanic
Default Straight-ins at uncontrolled airports?
chris writes:
Umm, that logic is faulty... The other senses may be unreliable, but
that doesn't mean they don't help you fly.
If they are unreliable without visual confirmation, they are practically
useless.
You can tell you are climbing by feeling it in the seat of your pants,
for instance.
How do you know that you are climbing and not turning? They feel the same.
Do you suggest we disregard every clue the aircraft give you except for
visual clues because they are unreliable??
No, but I suggest that people who cling desperately to physical sensations as
some sort of magic dividing line between flying in real life and flying in
simulation try to get a better grip.
You can tell a lot by the seat of your pants and by listening, and
that helps you fly.
As long as you can correlate it with other information, essentially visual.
Feeling something in the seat of your pants tells you that the status of the
aircraft has changed, but that's about it. To figure out exactly what has
happened, you need visual input, or instruments.
This is like your thread about
coordinated turns - we can feel the turn, so we should use that
feeling.
Unfortunately, it feels just like a climb.
Old February 12th 07, 08:45 AM posted to rec.aviation.piloting
Roger[_4_]
On 11 Feb 2007 17:04:05 -0800, "chris"
On Feb 12, 1:07 pm, Mxsmanic wrote:
Mike Young writes:
Do you mean, unlearn basic airmanship before you can get proficient on
instruments?
Basic airmanship is independent of sensation. The sensations pilots feel are
unreliable. They consider them reliable because they unconsciously reinforce
them with visual information, which usually _is_ reliable. Proof that
sensations are useless is easy to obtain, by depriving the pilot of visual
references. No matter how much experience he has, without instruments he
rapidly becomes disoriented. If sensations were reliable, that wouldn't
happen. And since in fact they are unreliable, learning about them isn't
really important, as they won't help you to fly.
that doesn't mean they don't help you fly. You can tell you are
climbing by feeling it in the seat of your pants, for instance. Do
So does the positive G when inverted while going over the top in a
loop.
visual clues because they are unreliable?? No.. That would be silly.
There is little the seat of your pants can tell you under instrument
contitions except the amount of G you are pulling and whether you need
to go to the bathroom.
that helps you fly.. So we shouldn't disregard those senses. And we
certainly should learn about them. This is like your thread about
feeling.
I can put you upside down and give you that same feeling and you will
never know you are inverted.
www.rogerhalstead.com
Old February 12th 07, 02:36 PM posted to rec.aviation.piloting
Mxsmanic
Roger writes:
And unfortunately some VFR pilots end up in exactly that position in real
life, once they are stuck in IMC. They only find out when the ground hits
them from above.
Southern California airports have worst runway safety records Larry Dighera Piloting 0 November 26th 05 04:48 PM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
Airports Rated Critical Unsatisfactory: Given Black Star Rating Michael Ravnitzky Piloting 0 February 3rd 05 03:34 AM
IFR hold short line at uncontrolled airports? Peter R. Instrument Flight Rules 30 June 9th 04 04:47 AM
fatal bird strike StellaStar Piloting 9 July 13th 03 09:41 PM
