Low fuel emergency in DFW
Old February 23rd 07, 12:14 PM posted to rec.aviation.piloting
Matt Whiting
Default Low fuel emergency in DFW
Jim Macklin wrote:
Not if that would take longer than what the controller can
do, which is to fit the plane into the sequence.
I would hope most controllers are trained for this and can handle it.
If not, then we need new controllers, but I suspect 98% would handle
this just fine.
Matt
Old February 22nd 07, 11:26 PM posted to rec.aviation.piloting
Matt Whiting
Jim Macklin wrote:
How many "outraged" posters have ever flown into DFW as a
pilot? For ATC to turn the airport around takes about half
an hour, even if all they do is tell all the other airplanes
to go away. ATC did fit the "emergency" into the traffic,
which seems to be the better solution.
And if the airliner had run out of fuel and crashed short of 31, do you
still like this better solution?
I actually can't believe you wrote the above. Did someone forge a post?
Matt
Old February 23rd 07, 01:27 AM posted to rec.aviation.piloting
Jim Macklin
It takes less time to fit the Tulsa to DFW flight into the
flow of traffic than it does to turn 12-30 airplanes out of
the way to turn the airport around. DFW, unlike many
smaller airports never has a slack time, there are always
long sequenced flights.
Departing Tulsa, by jet, to DFW is not a long flight...why
did they have a "fuel emergency," did they depart without
fuel, did they have a leak?
If the flight had insisted on landing 17, then it could
easily have taken 30 minutes to get them a clear shot at the
runway.
BTW, I have NEVER seen an accurate report on TV or in a
newspaper of any airline accident or incident. NEVER!
"Matt Whiting" wrote in message
a
half
airplanes
traffic,
of 31, do you
forge a post?
| Matt
Old February 23rd 07, 03:26 AM posted to rec.aviation.piloting
Mxsmanic
"Jim Macklin" writes:
The other 12-30 airplanes have not declared emergencies.
It's not up to the pilot to justify his emergency, nor is it the controller's
role to second-guess him.
runway.
If there is nobody on the runway, he has a clear shot. If he's out of fuel,
it doesn't really matter, as there may not be any other options.
Old February 23rd 07, 03:40 AM posted to rec.aviation.piloting
Steven P. McNicoll
"Jim Macklin" wrote in message
They didn't know how the situation developed, they mentioned a leak as a
possibility.
runway.
No it wouldn't. You simply move the other traffic.
The tapes were part of the report. ATC was wrong, no question about it.
Old February 23rd 07, 04:23 AM posted to rec.aviation.piloting
Jim Macklin
moving the other traffic is not simple when in the DFW area.
It takes time because you have to talk to each airplane and
have a place for it to go.
There will likely be an NTSB and or FAA report after an
investigation, into causes, remedies are determined. I'll
wait for that. But if the goal is to get on the ground
ASAP, consider the airplane declaring the emergency did land
safely. If a longer delay was needed to clear the airspace,
it might not have.
"Steven P. McNicoll" wrote in
message
nk.net...
| "Jim Macklin" wrote
in message
of
always
flight...why
without
| possibility.
| runway.
question about it.
Old February 23rd 07, 04:37 AM posted to rec.aviation.piloting
Steven P. McNicoll
It's easier than you think.
Old February 23rd 07, 05:57 AM posted to rec.aviation.piloting
Jim Macklin
Really, at DFW, easier than just fitting one airplane into
the stream and moving one airplane out, easier in your mind
to turn 10,20, 30 airplanes around?
message
k.net...
| "Jim Macklin" wrote
in message
area.
and
Old February 23rd 07, 12:24 PM posted to rec.aviation.piloting
Mxsmanic
Simple or not, it has to be done.
It takes only a few seconds.
it might not have.
If there is anyone on 17C, you have him clear the runway. If there is anyone
above decision height for landing, you have him go around. If he's below, you
have him land and get out of the way ASAP. Anyone taking off is similarly
vectored out of the way. Problem solved.
Everyone else is far enough away to be immediately moved out of the way. And
they'll be listening and waiting for instructions, which they will execute
instantly, you can be sure of that.
Old February 23rd 07, 11:16 PM posted to rec.aviation.piloting
Rich Ahrens
And for everyone speculating, here's the news report in question:
http://tinyurl.com/24jjaz
(There's a brief ad in front of the report.) The video includes audio
clips of the radio traffic. Interesting coincidence that the station's
call sign is WFAA.
Only egregious error I see in the reporting is the graphic at the
beginning that contains an arrow from Dallas to Tulsa, rather than the
reverse.
fuel leak or auxiliary fuel pump malfunction? [email protected] Owning 7 December 17th 06 12:57 PM
Fuel quality control standards for aircraft rental/fuel sales... [email protected] Owning 19 January 19th 05 04:12 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Home Built 0 January 26th 04 07:48 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Aviation Marketplace 0 January 26th 04 07:48 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Owning 0 January 26th 04 07:48 AM
