![]() "Mike Schumann" wrote If the pilot wants a straight in approach to a runway that is occupied by another aircraft that can't be moved in time, ATC can certainly suggest alternatives as well as point out the impossibility of the pilot's request. It has been reported here, that he asked for the emergency 17 straight in, 82 miles away. Plenty of time to vacate the runway and move any other aircraft in his path. -- Jim in NC |
![]() "Mike Schumann" wrote in message .. . If the pilot wants a straight in approach to a runway that is occupied by another aircraft that can't be moved in time, ATC can certainly suggest alternatives as well as point out the impossibility of the pilot's request. That wasn't the case here. |
On Fri, 23 Feb 2007 15:07:14 -0800, Mike Schumann wrote
(in article ): If the pilot wants a straight in approach to a runway that is occupied by another aircraft that can't be moved in time, ATC can certainly suggest alternatives as well as point out the impossibility of the pilot's request. This isn't a legal issue. This is a question of declaring an emergency and then having the pilot and ATC work together to safely get the aircraft down at an acceptable airport ASAP. There were no other aircraft on the runway that could not move in time. The argument is a red herring. ATC is required to comply with the pilot's emergency request. The time to settle whether that request was reasonable or not is on the ground. But ATC must comply. Rule #1 of aviation: The airplane has a Pilot in Command. The airplane is not flown by a committee or by an anonymous voice on the ground. It is not a democracy. It appears here that ATC wanted to avoid departure delays even if it meant killing people. The pilot has a responsibility to his passengers, not to complying with ATC stupidity. The pilot failed in that responsibility, but managed to live anyway. He might not be so lucky next time. ATC will kill you given half a chance. It is the pilot's responsibility to see to it that that does not happen. -- Waddling Eagle World Famous Flight Instructor |
ATC has admitted they screwed up.
On Feb 23, 4:57 pm, "Danny Deger" wrote: "Ross" wrote in message ... Steven P. McNicoll wrote: "Mike Schumann" wrote in message ... I'm not saying that ATC didn't have a problem, but by the same token, it is also unacceptable for the pilot to continue to his destination after he declared an emergency to avoid the delays and hassles of diverting to a closer airport. What closer airport? The Dallas news said McKinney (KTKI) and Addison (KADS) were other choices. As someone else said, the decent cruise to KDFW would have been just as quick. This brings up an interesting question. Maybe a straight-in to the south was not a problem for these other airports, but a straight-in to the south at DFW was a pain in the ass for DFW traffic. Does ATC have the right to decline a straight-in to DFW if they can give the pilot a reasonable alternative? I would say ATC should immediately provide the straight-in to DFW if they can not give the pilot a different option, but if a straight-in to another airport is offered maybe they can deny the straight in to DFW. Obviously, to the pilot, landing at a non-DFW airport will create quite a fuss for his carrier. There will cerainly be a lot of ****ed off passengers that are delayed in getting to DFW. Obviously the pilot can fly the straight-in to DFW regardless of ATC clearance, but the pilot will have to answer to the FAA after he lands (this is hint that a "certain somebody" does not need to repeat for the upteenth time on this thread that the pilot can do what he needs to do in the event of an emergency). BTW, I don't see a regulation that requires ATC to do exactly what the emergency pilot wants at exactly the time the pilot asks for it in the FARs. There is a reg that says the pilot can deviate, but I can't find the one that ATC must obey the pilot without question or offering alternatives. Danny Deger -- Regards, Ross C-172F 180HP KSWI- Hide quoted text - - Show quoted text -- Hide quoted text - - Show quoted text - |
fuel leak or auxiliary fuel pump malfunction? | [email protected] | Owning | 7 | December 17th 06 12:57 PM |
Fuel quality control standards for aircraft rental/fuel sales... | [email protected] | Owning | 19 | January 19th 05 04:12 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Home Built | 0 | January 26th 04 07:48 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Aviation Marketplace | 0 | January 26th 04 07:48 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Owning | 0 | January 26th 04 07:48 AM |
