Boarding with engines running
Old February 24th 07, 09:29 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Boarding with engines running
EridanMan writes:
Advisable? No.
Safe? Depends on too many factors to tell say outright... Front
engined aircraft that boards over the trailing edge of the wing?
Probably safe (although I'd imagine getting some doors open under even
an idle prop-stream would be a pain/might risk damage to the door...
light aircraft doors tend to be very flimsy) Twin which boards over
the wing? Not a chance... WAY to many other variables (how bright is
it (how visible is the prop disc), how much idle blast does the prop
throw?
Done anyways? Sure.
The scenario I have in mind is sitting waiting for a passenger to get on or
off, or helping a passenger get on or off. It's mainly just to have a more
realistic simulation. The aircraft I use in the sim is usually a Baron 58; if
I fly it online (VATSIM), it's important that stops at airports be of
realistic length (of the length that they would be if you stopped for some
specific purpose in real life, such as picking someone up or dropping someone
off).
Thus, I wanted to know if it's possible/safe/practical to sit with the engines
running while someone gets into or out of the plane, much as one would do with
a car when picking someone up. Maybe that is too farfetched for an aviation
context. I suppose the passenger would have to be able to get to the aircraft
on his own, and I don't know how tough that would be. And if the pilot had to
help him board or disembark, I assume it would be way too risky to leave the
aircraft running while he left his seat and got out of the plane.
Kinda a nonsensical question, how long until the next stiff wind
blows?
Not for me, as I don't have direct experience with this. I don't know how
easily small aircraft can be moved by the wind.
In all honesty, most chalks will
probably do no better than the wheel brakes alone at protecting from a
stiff gust... t takes quite a bit of wind to overcome the static
friction of the wheels. If the wind is strong enough to overpower a
brake, a chalk probably won't do much better- what you'll need is good
heavy chains, or better yet, a hangar.
A hangar would be great, but unfortunately the simulator doesn't support that
in most cases.
The flip-side is that in general, if your paying the MX bills, its
really not a good idea to leave the brake engaged, this is simply a
wear issue (Its better to store a hydrolic system unpressurized then
pressurized, If you have the choice). Wheel chalks are slightly more
reliable, and much cheaper, then a parking break, but no
"safer" (better at keeping an aircraft stationary)
OK.
when park your plane.... duh?
I meant, do pilots keep a set of chocks in the aircraft and position the
chocks themselves, or is there a lineman or someone who does this, or what?
With large airliners there are crews who handle all of this, but I don't know
how it is done with tiny airplanes.
Old February 24th 07, 12:31 PM posted to rec.aviation.piloting,rec.aviation.student
Little Endian
I just don't understand it, why do you need to go to such great
lengths in a simulator? Even in real life its the flying part that is
the most fun, the challenge to level off precisely and accurately with
the minimum of fuss, the thrill of taking off and landing within 100
ft of the numbers, handling stiff X-winds, using only pilotage to get
to a small airstrip etc. Of course taxing is fun too but its only
because of what comes after it or what came before it.
off).
If I were to fly in a simulator the only thing I would be doing would
be to fly, fly, fly and never do the mundane things like taxing and
especially never do something as silly as simulating waiting for a
passenger. I don't see why you do not go up with a flight instructor
for an hour or so if you are so interested in the real life aspects of
flying. Its like the saying that a picture is worth a thousand words,
similarly one real flight can be worth a thousand simulator flights.
It would save you a heck of a lot of time not having to ask these
questions and time is money.
Old February 24th 07, 04:09 PM posted to rec.aviation.piloting
Andreas Tschoeke
Because we, the simmers, like to simulate RL as closely as possible,
thatīs the reason why we simulate RL.
A friend of mine, who is a RL pilot, too, goes the other way; he
does things in the sim he wouldnīt think of doing in RL, which is
not the way I use MSFS. Therefore, I only fly with him in RL, not in the
sim, because only RL comes close to my experience in the sim.
Yes, I know, difficult to explain ...
:-) Andreas
Old February 24th 07, 08:04 PM posted to rec.aviation.piloting
Peter Dohm
He flew the sim Pitts through WHERE???????
Oh! No! Not the Baltimore Harbour Tunnell!!!!!
Peter
(Sorry, couldn't resist... :-))))
Old February 24th 07, 11:25 PM posted to rec.aviation.piloting
Andreas Tschoeke
Peter
Peter, ?
Old February 25th 07, 01:19 AM posted to rec.aviation.piloting
Blueskies
"Andreas Tschoeke" wrote in message ...
: Little Endian schrieb:
: I just don't understand it, why do you need to go to such great
: lengths in a simulator?
: Because we, the simmers, like to simulate RL as closely as possible,
: thatīs the reason why we simulate RL.
: A friend of mine, who is a RL pilot, too, goes the other way; he
: does things in the sim he wouldnīt think of doing in RL, which is
: not the way I use MSFS. Therefore, I only fly with him in RL, not in the
: sim, because only RL comes close to my experience in the sim.
: Yes, I know, difficult to explain ...
::-) Andreas
You folks need to go off somewhere else and simulate RAP also...
Old February 25th 07, 02:21 AM posted to rec.aviation.piloting
Mxsmanic
Andreas Tschoeke writes:
What sorts of things does he do in the sim?
I know that sims come in handy for trying all the things that would be too
dangerous or expensive in real life.
I took off from the tiny airport in Sedona a few days ago in a lightly loaded
747-400, just to see if it was possible (it is). That experiment would be
completely out of the question in real life, of course, even if you could tow
a 747-400 up onto the mesa to reach the airport. Granted, one could calculate
whether or not this would be possible by looking at the numbers, but it was
easier to just try it in a sim.
FWIW, I loaded 40,000 lbs of fuel and a few dozen of my closest friends, stood
on the brakes until I had take-off thrust, and took off without any
difficulty. With a full load the story would have been different.
Old February 25th 07, 02:56 AM posted to rec.aviation.piloting
TxSrv
on the brakes until I had take-off thrust....
This guy's insane.
F--
Old February 25th 07, 03:08 AM posted to rec.aviation.piloting
Mxsmanic
TxSrv writes:
This guy's insane.
Hardly. I flew down into Phoenix without incident, thus proving that it could
be done.
Old February 25th 07, 02:18 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Little Endian writes:
When flying online, it's important to have realistic delays for various
operations. Landing and then asking to taxi back out to the active thirty
seconds later isn't very realistic if you are supposedly letting off
passengers, having the cabin serviced, taking on new passengers, moving
luggage, and so on.
Knowing what operations must be performed in real life helps you simulate the
delay correctly.
The whole idea of simulation is to simulate real life. The only parts you
leave out are the ones that would ruin the advantage of simulation, such as
driving to and from the airport, dropping hundreds or thousands of dollars on
a flight, being stuck far from home waiting for weather to improve, and so on.
Agreed. But sometimes peripheral activities enhance the illusion of reality.
Most simmers draw the line at anything that happens outside the aircraft, such
as going to and from the airport, filling out reports, and so on. A few go a
bit further and have complete passenger and cargo manifests and flight
schedules to respect and so on. It's a personal choice. However, everyone is
expected to do all the in-cockpit stuff, from startup to shutdown, and
obviously including things like taxiing.
When flying offline, one tends to cut out some parts. When flying online,
everything is done by the book, so that everyone has a more realistic
experience. You don't just pop into existence at the airport lined up for
take-off, for example, because you have to taxi out from the gate or ramp.
passenger.
That's your choice.
Some people take it further, and consider even flying mundane. They are the
ones who like the combat games and the "missions" of MSFS. Obviously, they
usually aren't seriously interested in aviation if they don't like flying for
its own sake.
Incidentally, if you don't like the mundane things, that's all the more reason
to fly a simulator, where you can skip all the boring stuff.
flying.
In real life, you can't avoid the boring parts and just keep the interesting
parts. You blow several hours of your time in boring activity for a few
minutes in the air, and it costs a fortune. That's not very cost-effective
compared to simulation.
Or it can be a waste of time.
I have more time than money.
Medical running out? [email protected] Piloting 6 May 28th 06 02:19 PM
Running dry? Greg Copeland Piloting 257 August 26th 05 03:47 PM
Running runup? G. Burkhart Piloting 39 July 7th 04 11:25 AM
Running an 0-235 well beyond TBO Paul Folbrecht Owning 8 March 14th 04 12:30 AM
Leaving all engines running at the gate John Piloting 12 February 5th 04 03:46 AM
Copyright Đ2004-2025 AviationBanter.
