Flight planning software minimization algorithm
Old February 26th 07, 01:11 AM posted to rec.aviation.piloting,rec.aviation.ifr
Blanche
Default Flight planning software minimization algorithm
Peter wrote:
"Andrew Sarangan" wrote
Most of the software out there will compute a flight based on the
user's route, time of departure and altitude. This is a fairly
straight forward task which could be done without a computer, as has
been the case for decades.
What I am looking for is the reverse. Given a destination, aircraft
type and a window of travel time (which could be a couple of days),
the software should come up with the best altitude, route and time of
departure. It should consider forecasted winds aloft, frontal
positions, icing potentials, turbulence and thunderstorms. The user
should be able to attach numeric weights to indicate the level of
importance to each factor. In other words, it should be a minimization
software considering a variety of decision matrix. At present I do
this by recomputing the flight for each scenario. This does get very
cumbersome, and is best done with an automated algorithm. If such a
thing exists, I would like to hear opinions.
Don't the airlines use this kind of tool already, for working out the
best routes?
Jeppesen do a product called Jetplanner, which I understand (from
someone working in an airline flight planning department) does this -
at least the winds aloft part of it. It is not priced for the GA
market, and my experience is that they cut off email communication
with you as soon as you ask how much it costs.
It uses the same database updates as Jeppview 3; this is evident from
the readme files on the JV3 CDs.
You need detailed performance data (versus altitude) for the aircraft;
something which is not available for most GA types.
It's called JetPlan and is the engine underneath OpsControl, which is
what you're thinking of (and what I was referring to earlier). And it
can handle all sorts of conditions. And as Peter pointed out, if you
have to ask, you can't afford it. Target market are small to medium
size carriers (large carriers usually have their own), charters
and business flight departments. There are also various military
organizations using it, or variations provided by Jepp.
Old February 26th 07, 01:28 AM posted to rec.aviation.piloting,rec.aviation.ifr
Tony
Don't get too tangled up in trying to find some 'optimum'. This is
instructive: do a manual calculation of what you consider might be
three or four 'likely best' routes. When you get done cranking the
numbers, you'll likely find not an important difference in your
several results. It's that old thing when we learned calculus --
nothing very interesting happens near a maxima or minima.
If, on the other hand, you discover big differences between what you
considered to be two paths that you expected to be about the same,
(and you're sure the analysis is correct), you need to sharpen your
instincts (and that also would render moot all I've said earlier).
best routes?
organizations using it, or variations provided by Jepp.- Hide quoted text -
- Show quoted text -
Old February 26th 07, 01:36 AM posted to rec.aviation.piloting,rec.aviation.ifr
Roy Smith
In article .com,
Lots of curves have very interesting things happen at the maxima.
Coefficient of lift vs. angle of attack. Deflection vs. load factor for
the main wing spar. Leakage current vs. voltage for electrical insulation.
Old February 26th 07, 01:56 AM posted to rec.aviation.piloting,rec.aviation.ifr
Tony
You're quite right when the maxima or minima happens near a
discontinunity -- I was thinking of more gentle models.
On Feb 25, 7:36 pm, Roy Smith wrote:
In article .com,
Old February 26th 07, 03:04 AM posted to rec.aviation.piloting,rec.aviation.ifr
Andrew Sarangan
I normally do this stuff manually (using a computer nevertheless, but
manually entering the altitudes and ETDs), and it is a very cumbersome
process. The results are, like you say, are not dramatically
different, but I have found situations where moving the departure time
by a few hours, or planning a different fuel stop can shave off 30
minutes of flight time from a 500 mile trip. When the airplane cost is
$100/hr that could be an important consideration.
Also, in most flight planning situations we use a single cruising
altitude for the entire flight. Adjusting the cruising altitude on a
continuous basis is not handled by any software that I know of. If the
software can come up an ideal altitude profile, route profile and the
best time of departure, the pilot can then use this baseline
information from which to modify parameters to fit his specific
needs.
Old February 26th 07, 07:27 AM posted to rec.aviation.piloting,rec.aviation.ifr
Blanche
needs.
Destination Direct (destroyed, then killed by SAIC) had an option
where you could enter the winds and temps at various altitudes and
depending on the altitudes generated by the planner or altered by
the user, the flight plan was recomputed appropriately.
Jepp's low-end FliteStar can use winds but since I won't open my
firewall to allow it to access the Jepp weather server, I don't
know how well it works. But it also uses a variation of the
Djikstra algorithm - easy to identify it when you watch it attempt
to generate a flight path given certain conditions.
Kinda fun, too.
$10 Flight Planning Software [email protected] Aviation Marketplace 0 February 15th 07 07:55 PM
Best Flight Planning Software for a jet? CaptainCraig Piloting 2 September 8th 06 03:50 AM
Flight planning software Cetacea Instrument Flight Rules 2 May 14th 05 12:13 AM
Flight Planning Software Cetacea Piloting 2 May 13th 05 09:19 PM
flight planning software Russ Bird Piloting 1 November 22nd 04 03:08 AM
