On Thu, 22 Mar 2007 21:36:51 -0400, "Cox" wrote:
If you do manage to get out of a spinning aircraft, I wouls estimate close to a 100% better chance of survival if you have a chute on. I sure would hate to be the person who was able to get out of the so called "impossible aircraft to get out of" only to find they didn't have a chute on. Wear a chute, what can it hurt? Adam Then there's this: http://www.aero-news.net/index.cfm?C...-7233c1bb43f8& (Hope it's not a repost. It's about the 150 rudder bumpers jamming.) Don |
![]() Cox wrote: If you do manage to get out of a spinning aircraft, I wouls estimate close to a 100% better chance of survival if you have a chute on. I sure would hate to be the person who was able to get out of the so called "impossible aircraft to get out of" only to find they didn't have a chute on. Wear a chute, what can it hurt? Adam Adam Cope www.dcaerobatics.com 703-623-9445 I totally agree with this. The " you'll never get out of this airplane because of the door" routine is something I've heard repeated many times through my career teaching aerobatics. My standard answer and "lecture" on this issue is as follows; For spins, even if the regulations don't call for chutes, I always recommend wearing them. I always had chutes available for whatever aircraft we were using for spin training. A lot has been written and said about the difficulties involved in getting out of Aerobats, Citabrias, and Decathlons. There is no doubt that especially with a structural failure, exiting one of these aircraft could be iffy. That's why any good instructor not only supplies chutes for spin training, but as well performs a complete egress brief specific to aircraft type to the point where once the bail out call has been made, each occupant knows what the exit procedure will be. This is especially critical in tandem aircraft. I should mention that even with the most complete egress briefing, there is STILL an element of doubt that a successful exit from these airplanes can be executed in the time available under extreme g in a post structural failure. The factors involving a successful bail out are so diverse that there are just no guarantees. In the Pitts S2 for example, if the upper wing fails, the flying wires will most likely remain attached and the upper wing will beat the occupants to death before a bail out can be achieved. All this being considered, the use of chutes is not only recommended, but in my opinion a necessary part of every non- standard flight whether it be aerobatics or spin training. The bottom line is that wearing a chute gives you a fighting chance for survival. Not wearing a chute gives you no chance at all. Its a smart pilot who takes advantage of all available options! Dudley Henriques |
![]() "Dudley Henriques" wrote in message ... Cox wrote: If you do manage to get out of a spinning aircraft, I wouls estimate close to a 100% better chance of survival if you have a chute on. I sure would hate to be the person who was able to get out of the so called "impossible aircraft to get out of" only to find they didn't have a chute on. Wear a chute, what can it hurt? Adam Adam Cope www.dcaerobatics.com 703-623-9445 I totally agree with this. The " you'll never get out of this airplane because of the door" routine is something I've heard repeated many times through my career teaching aerobatics. My standard answer and "lecture" on this issue is as follows; For spins, even if the regulations don't call for chutes, I always recommend wearing them. I always had chutes available for whatever aircraft we were using for spin training. A lot has been written and said about the difficulties involved in getting out of Aerobats, Citabrias, and Decathlons. There is no doubt that especially with a structural failure, exiting one of these aircraft could be iffy. That's why any good instructor not only supplies chutes for spin training, but as well performs a complete egress brief specific to aircraft type to the point where once the bail out call has been made, each occupant knows what the exit procedure will be. This is especially critical in tandem aircraft. I should mention that even with the most complete egress briefing, there is STILL an element of doubt that a successful exit from these airplanes can be executed in the time available under extreme g in a post structural failure. The factors involving a successful bail out are so diverse that there are just no guarantees. In the Pitts S2 for example, if the upper wing fails, the flying wires will most likely remain attached and the upper wing will beat the occupants to death before a bail out can be achieved. All this being considered, the use of chutes is not only recommended, but in my opinion a necessary part of every non- standard flight whether it be aerobatics or spin training. The bottom line is that wearing a chute gives you a fighting chance for survival. Not wearing a chute gives you no chance at all. Its a smart pilot who takes advantage of all available options! Dudley Henriques Dudley, Could you give some specifics about exiting a citabria? I used to do aerobatics in one and always wore a chute. I never suspected that I would have trouble exiting if I pulled the door hinge pins, I thought the door would vanish and leave me a big hole to climb out. The only serious instructor I had was in a Stearman and he never discussed exiting in case of trouble. Obviously I was completely ignorant. Better to learn late than never. |
On Mar 23, 1:36 pm, "Cox" wrote:
If you do manage to get out of a spinning aircraft, I wouls estimate close to a 100% better chance of survival if you have a chute on. I sure would hate to be the person who was able to get out of the so called "impossible aircraft to get out of" only to find they didn't have a chute on. Wear a chute, what can it hurt? And have quick release pins on the doors with the handles -inside- |
A CFI may instruct spins to any level of pilot without
parachutes being worn. The spin is required for the CFI applicant, but since it is required for some level of certificate, it may be taught to any pilot. Of course no passengers may be aboard, just the CFI and the "student." 91.307 (c) Unless each occupant of the aircraft is wearing an approved parachute, no pilot of a civil aircraft carrying any person (other than a crewmember) may execute any intentional maneuver that exceeds- (1) A bank of 60 degrees relative to the horizon; or (2) A nose-up or nose-down attitude of 30 degrees relative to the horizon. (d) Paragraph (c) of this section does not apply to- (1) Flight tests for pilot certification or rating; or (2) Spins and other flight maneuvers required by the regulations for any certificate or rating when given by- (i) A certificated flight instructor; or (ii) An airline transport pilot instructing in accordance with §61.67 of this chapter "Tom Inglima" wrote in message .. . | Spins have NEVER been in the private pilot PTS. The PTS (Practical Test | Standard) only has been in existence for around 20 years or so. The last | time spins were required for a Private Certificate was back in the early | 1950's or maybe the late 1940's. Note that there is nothing that prevents | an instructor from teaching spins to a student pilot. However you would | have to wear parachutes to be legal since the regs only allow spins without | the wearing of parachutes for people training for a flight instructor | certificate. | | The predecessor for the PTS was the Flight Test Guides. These were slim | volumes of not more than 20 pages and about 2 or 3 inches wide and about 4 | inches high. In any case they were smaller than a 3 by 5 index card. they | had very broad descriptions of maneuvers' and gave examiners and inspectors | wide latitude in what and how they wanted you to perform various maneuvers. | Part 61 was actually a much better regulation then in that it clearly made | the CFI responsible for preparing a competent pilot that was able to show | good judgment. | | The predecessor regs and guidance was to list the actual maneuvers in the | reg. If you could get a monkey to somehow do the maneuver a certificate | would be issued. | | Tom Inglima | | "Chris G." nospam@noemail wrote in message | eenews.net... | Besides, spin training is NOT required for a private pilot certificate. | Spin AWARENESS (aka recognizing you're going to get into a spin) is | required. Spins are not part of the PTS anymore though. | | I don't necessarily think that omitting spins from the PTS is the best | move the FAA has made, but I don't know the whole story. I know I'm | having my instructor make sure he teaches me spins in the 150 I'm learning | in. I believe that training in spins and spin recovery is a very | important skills that could save my life one day. | | Chris | | | wrote: | On Wed, 27 Apr 2005 14:46:42 -0500, "Gig 601XL Builder" | wr.giacona@coxDOTnet wrote: | | | wrote in message | ... | | On 27 Apr 2005 09:43:30 -0700, "Noah Fiedel" | wrote: | | | In addition, were you & your instructor wearing parachutes | as required for aerobatic flight? | | | Not required, since spin training is required for a rating. | | Looked to me like a roll not a spin. | | | Oooops. | | Never mind. | | | | |
On Mon, 26 Feb 2007 23:41:47 -0500, "Tom Inglima"
wrote in : Note that there is nothing that prevents an instructor from teaching spins to a student pilot. If the aircraft is not certified for the maneuver, that would prevent that maneuver from being performed in that aircraft without violating federal regulation. [Newsgroups: trimmed] |
The last time spins were required for a Private Certificate was back in the early
1950's or maybe the late 1940's. I can verify that spins were required in 1947. vince norris |
Rolling a Non Aerobat 150 | Larry Dighera | Piloting | 98 | June 18th 05 12:28 AM |
Rolling a Non Aerobat 150 | Jose | Instrument Flight Rules | 1 | May 2nd 05 03:59 PM |
Rolling a Non Aerobat 150 | Jose | Piloting | 1 | May 2nd 05 03:59 PM |
Rolling a Non Aerobat 150 | Larry Dighera | Piloting | 1 | April 29th 05 07:31 PM |
Rolling a Non Aerobat 150 | kage | Owning | 0 | April 29th 05 04:26 AM |
