In article , "Paul J. Adam"
wrote: That is not he fault of the GPS. No, but it's a human mistake. It's a training issue to make sure that when the GPS bings off a waypoint, you check a few landmarks to make sure you're where the gadget says you should be. Currently, that doesn't reliably happen because people have too much faith in the GPS. the GPS acts up or the information it provides isn't used wisely. That goes for anything and everything. Not just GPS. Training is very important. To quote a friend, "You have to be smarter than what you're working on." The trouble is, GPS is too damn useful. Mike Marron wrote eloquently about how a working GPS can replace most of your flight instruments... as long as the GPS is working. But it's a low-powered signal from orbit and it's easily jammed. GPS jamming isn't a feature of civilian life, but it's a serious military problem. GPS offers much more than any other navaid I've heard of, no wonder people turn to it first. Oh Bo....ks. GPS is easy to TRY to jam. Well known signal processing techniques are all that's required to defeat jamming. -- Harry Andreas Engineering raconteur |
"Harry Andreas" wrote in message ... In article , "Paul J. Adam" wrote: The trouble is, GPS is too damn useful. Mike Marron wrote eloquently about how a working GPS can replace most of your flight instruments... as long as the GPS is working. But it's a low-powered signal from orbit and it's easily jammed. GPS jamming isn't a feature of civilian life, but it's a serious military problem. GPS offers much more than any other navaid I've heard of, no wonder people turn to it first. Oh Bo....ks. GPS is easy to TRY to jam. Well known signal processing techniques are all that's required to defeat jamming. GPS is neither "easy to jam", or an apropriate "replacement" for existing navigation systems. While Mike may have spread the snake oil in a manner pleasing to our ground pounder lune Paul, an instrument cross check is a necessity to maintain safe operations. Fused navigation sensors wisely take this instrument cross check and make it part of the automation; but as Ed points out, relying on only one instrument often results in errors. John P. Tarver, MS/PE |
In message ,
Harry Andreas writes In article , "Paul J. Adam" wrote: The trouble is, GPS is too damn useful. Mike Marron wrote eloquently about how a working GPS can replace most of your flight instruments... as long as the GPS is working. But it's a low-powered signal from orbit and it's easily jammed. GPS jamming isn't a feature of civilian life, but it's a serious military problem. GPS offers much more than any other navaid I've heard of, no wonder people turn to it first. Oh Bo....ks. GPS is easy to TRY to jam. Well known signal processing techniques are all that's required to defeat jamming. Harry, with GPS you're trying to not only detect a domestic light bulb in low earth orbit, but to pull useful signal out of it. Doesn't take much in-band noise to spoil that game, because there isn't much signal there to start with. Directional aerials, parking beam nulls on the jammers, games like that help but they also cost money and volume and weight. It's not the end of the world if the enemy whips out a few jammers, and it's harder to do well than some would have you believe, but it's still a genuine concern with fewer easy answers you suggest. If there's a cheap, quick, easy and reliable magic bullet to make GPS unjammable, then hasten down to your patent office at once. -- When you have to kill a man, it costs nothing to be polite. W S Churchill Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
as long as the GPS is working. But it's a low-powered signal from orbit and it's easily jammed. How true is this, really? In an aircraft, you are between the ground and the satellite. How does someone on the ground interfere with the signal? all the best -- Dan Ford email: www.danford.net/letters.htm#9 see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
Cub Driver wrote: as long as the GPS is working. But it's a low-powered signal from orbit and it's easily jammed. How true is this, really? In an aircraft, you are between the ground and the satellite. How does someone on the ground interfere with the signal? I don't believe that the antenna for the GPS is directional enough that someone off axis couldn't put a signal into your system- after all, a single antenna is used to pick up every satellite above the horizon. Mike Williamson |
Hey Art, did you guys have a drift meter? Curious.
Navy P2Vs did in 50s -- along with Loran, radar, DR, celestial, and a few other little helpers. Don't know about P3s, but I suspect they do. Handy. Don't forget you can measure your ground speed with the things as well as drift. Of course the navy tends to fly over water more than common sense should allow. Quent Quent |
Subject: Flight Lessons
From: "Les Matheson" Date: 8/7/03 3:17 PM Pacific Daylight Time Hey Art, did you guys have a drift meter? Curious. Les No, but we had better. The Norden bombsight was the world's best driftmeter. If you cranked out the drift by stopping the vertical hair, it would give you the angle needed to correct the drift and track driift free. We call it a bomb run. (grin). Can't beat that. Arthur Kramer Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
Same concept kill drift, compute crosswind, time, distance, heading for a DR
plot. Les "ArtKramr" wrote in message ... Subject: Flight Lessons From: "Les Matheson" Date: 8/7/03 3:17 PM Pacific Daylight Time Hey Art, did you guys have a drift meter? Curious. Les No, but we had better. The Norden bombsight was the world's best driftmeter. If you cranked out the drift by stopping the vertical hair, it would give you the angle needed to correct the drift and track driift free. We call it a bomb run. (grin). Can't beat that. Arthur Kramer Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
"Les Matheson" wrote in message news:PMFYa.9988$ug.1099@lakeread01... Same concept kill drift, compute crosswind, time, distance, heading for a DR plot. Then lock up the AP to TRK. Les "ArtKramr" wrote in message ... Subject: Flight Lessons From: "Les Matheson" Date: 8/7/03 3:17 PM Pacific Daylight Time Hey Art, did you guys have a drift meter? Curious. Les No, but we had better. The Norden bombsight was the world's best driftmeter. If you cranked out the drift by stopping the vertical hair, it would give you the angle needed to correct the drift and track driift free. We call it a bomb run. (grin). Can't beat that. Arthur Kramer Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
From: (OXMORON1) Date: 8/8/03 10:10 AM Pacific Daylight Time Message-id: Les asked: Hey Art, did you guys have a drift meter? Curious. Add on question, Anyone here ever fly a "Double Drift" leg after training? By 1965 it wasn't even taught in USAF Nav course except as a two minute discussion in the basic equipment ground course. It was like the intro to loran "This is the APN.9 (?).and you'll never see it again, we use the XXX now" The first "Shakey that I got on had the old set sigh and it didn't work double sigh Oxmoron1 Taking an entire group of 56 Marauders through a double drift when you could have gotten the same result in 15 seconds on the Norden, without even changing course, didn't make much sense (sigh) Arthur Kramer Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| new theory of flight released Sept 2004 | Mark Oliver | Aerobatics | 1 | October 5th 04 11:20 PM |
| Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Home Built | 0 | September 22nd 04 08:16 PM |
| FAA letter on flight into known icing | C J Campbell | Instrument Flight Rules | 78 | December 22nd 03 08:44 PM |
| Sim time loggable? | [email protected] | Instrument Flight Rules | 12 | December 6th 03 08:47 AM |
