![]() Tim wrote: "Holding Instructions If you arrive at your clearance limit before receiving clearance beyond the fix, ATC expects you to maintain the last assigned altitude and begin holding in accordance with the depicted holding pattern. If no holding pattern is depicted, you are expected to begin holding in a standard holding pattern on the course upon which you approached the fix. You should immediately request further clearance." You should immediately pick an approach and land so you stop gumming up the works. |
Newps wrote:
Tim wrote: "Holding Instructions If you arrive at your clearance limit before receiving clearance beyond the fix, ATC expects you to maintain the last assigned altitude and begin holding in accordance with the depicted holding pattern. If no holding pattern is depicted, you are expected to begin holding in a standard holding pattern on the course upon which you approached the fix. You should immediately request further clearance." You should immediately pick an approach and land so you stop gumming up the works. I agree - but the OP thinks that since his clearance limit is an airport that he is to fly to that airport, THEN navigate to an IAF to do an approach. He wanted to know what to do when arriving at a clearance limit when there are no published holds at that point. I could not believe someone flying IFR routinely does not know what to do. That is why I posted it. I hope you are not saying to do this at any airport. |
Tim writes:
If you don't believe that if your clearance limit is the airport and that you can pick any approach and IAF and execute it when lost coms, then you can try this: from "Instrument Flying Handbook" FAA H 8083 15 page 10-11 http://www.faa.gov/library/manuals/a...-8083-15-2.pdf "Holding Instructions If you arrive at your clearance limit before receiving clearance beyond the fix, ATC expects you to maintain the last assigned altitude and begin holding in accordance with the depicted holding pattern. If no holding pattern is depicted, you are expected to begin holding in a standard holding pattern on the course upon which you approached the fix. You should immediately request further clearance." That last part might be difficult without a radio. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Tim writes: If you don't believe that if your clearance limit is the airport and that you can pick any approach and IAF and execute it when lost coms, then you can try this: from "Instrument Flying Handbook" FAA H 8083 15 page 10-11 http://www.faa.gov/library/manuals/a...-8083-15-2.pdf "Holding Instructions If you arrive at your clearance limit before receiving clearance beyond the fix, ATC expects you to maintain the last assigned altitude and begin holding in accordance with the depicted holding pattern. If no holding pattern is depicted, you are expected to begin holding in a standard holding pattern on the course upon which you approached the fix. You should immediately request further clearance." That last part might be difficult without a radio. Huh? The OP was confused about what to do at a clearance limit - regardless of radio contact. He asserted that at that point he would have to improvise. That is not the case. Why did you even bother to reply to this? |
Tim writes:
I don't make stuff up when I fly an IFR plan. It doesn't lend itself to staying alive. So exactly how do you handle the situation under discussion? You still haven't answered that. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Ron Garret writes:
For the record, the weather was VFR the whole way (and I knew it) so I was a good deal more casual about it than I would have been if it had been IMC the whole way. If visual conditions prevailed, the regulations say you should fly as if you were under VFR. Which is all well and good, I suppose, but it doesn't provide much guidance. The real question is: What should you do such that ATC will be able to understand and anticipate your actions, so that they can continue to provide separation? Just flying as if you were VFR doesn't answer that question, because even VFR you'd normally be in communication with ATC in controlled airspace, and in this case you've lost that. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Real-world IFR currency | Paul Folbrecht | Instrument Flight Rules | 47 | March 23rd 05 04:19 PM |
Real World Problem in FS9 | The Real Cali Kid | Simulators | 12 | December 6th 03 11:15 AM |
Real World Weather (Isabelle) | [email protected] | Simulators | 1 | September 21st 03 09:53 PM |
Real-time real world air traffic in flight sims | Marty Ross | Simulators | 6 | September 1st 03 04:13 AM |
Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 09:25 AM |
