Alternator whine
Old March 11th 07, 10:30 PM posted to rec.aviation.owning
David Lesher
Default Alternator whine
Dave Anderer writes:
I'm looking for advice to help shorten the trouble-shooting process here.
My Arrow has developed an alternator whine over the past few hours. It
is *barely, barely" noticable on both radios when receiving, but loud
and obnoxious (both to me and other aircraft) when transmitting. No
doubt it is the alternator - switching the alternator off fixes the
problem.
So your first troubleshooting fork is this:
1) The alternator/charging system may be making more ripple than
before.
or
2) The ripple may be the same, but the comm system is doing a better
job hearing it.
For 1) two major suspects:
a) Bad grounds.
b) Bad diode{s}.
b) Is easy to {dis}prove with a o-scope; without it takes some
experience & judgement. One clue is it can't generate full current
when loaded. a) is usually diagnosed by inspection and cleaning the
connections; those being the battery ground, the alternator ground,
the engine-to-frame ground, etc...
2) Note that while the alternator IS the source; it may not be at
fault at all. The mike line should be grounded at one and ONLY
one place... An added, improper ground on a mike jack may make a
nasty ground loop.
That can be as simple as the insulating washers having slipped. Mike
jacks mounted in a metal panel may have insulating shoulder washers:
--|-- --|--- washer
\-- --/ w/shoulder
-- -- metal panel
The panel hole is bigger than the jack shaft. The shoulders sit in
the hole; holding the jack's shell centered away from ground.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
And the Faggot Left continues to whine and Snivel T Bird Naval Aviation 1 June 13th 05 08:31 PM
Alternator field cycling & alternator damage Nathan Young Owning 7 November 14th 04 09:02 PM
q alternator 152 Euromotors Piloting 2 July 16th 04 09:34 AM
Japanese Whine Over Enola Gay Display [email protected] Military Aviation 42 December 19th 03 11:32 PM
Electric whine in the light circuit - Help Victor J. Osborne, Jr. Owning 1 July 29th 03 11:36 PM
