Ron Garret wrote:
Again, I misunderstood then. I only quoted you and responded based on what you wrote. You must not be reading very carefully. I say right there in the part you quoted that I was talking about a different trip (AVX-FUL). I was trying to just use your examples. How does going to FUL require what you state? Cannot you pick which approach and IAF? It's a tangent, so if you really want to get into that you should start a new thread. Or look up the old one. Or look at the charts. How is that a tangent? Because it's a different route. The circumstances are different. What one does when flying to FUL may or may not apply when flying to VNY. I only brought up FUL because it's a data point where I've had occasion to ask controllers for their input, and they unequivocally told me NOT to follow the regs. (Yes, I know that what controllers say doesn't matter. Nonetheless, it's a data point.) So you are saying that one has to change operating rules based on the route of the flight. That is exactly why we are having difficulty understanding each other. The rules are in place to define what to do under all circumstances. Saying that something applies in one instance and not another is bad. What are the criteria then for defining which set of our own rules that deviate from the FARs is necessary? The ONLY one i am aware of the the one regarding emergencies. You can choose any IAF and any approach that you are able to do when the clearance ends in "direct" - and the airport is the clearance limit. Yes, but by the book you have to fly to the clearance limit first. 91.181(b) is quite clear about this. It is your clearance limit because that is where you filed to and where you want to land. You cannot commence your approach until your clearance limit time/time on your flight plan. Why do you choose the VOR procedure at FUL rather than the LOC/DME? In that case it is easy to pick the approach with nopt. Not as easy as you might think. The preferred routing (which is the one you will invariably be assigned) from AVX to FUL is V21 SLI Direct. Again, "direct" does not mean direct to the airport. That's news to me. Where in the regs does it say that? When you don't lose comms and you file and fly to an airport and do not get vectors, where do you go to? You go to an IAF, right? Or do you always go to the airport, then to a navaid that defines an IAF? Direct means you go to an IAF then get to the airport. How are you supposed to land? My reading of 91.185(c)(3)(ii) seems to imply that you have to fly to the airport first, then to an IAF. You can;t just go to the airport and circle down to land - that is the whole reason for having defined instrument approaches. If you're saying that it's stupid to fly to the airport first, I agree with you. Hence my question. Right. See above regarding what that last "direct" means. It does not mean go froom the penultimate fix to the airport. It means go to an IAF then fly the approach. I'm pretty sure you're wrong about that. My initial (and I guess overzealous) reaction to your post was that it seemed like you just didn;t care what "the book" said or what you are supposed to do based on part 91 regs for ifr flight. That is scary to me. Of course I care. But that doesn't mean that I blindly follow the rules without thinking. I misunderstood your initial question and I apologize for any demeaning statements. It appeared to me that you were not aware of what the FARs stated. Again, my apologies. rg |
Tim wrote: So you are saying that one has to change operating rules based on the route of the flight. No, I am not saying that. Why do you keep putting words in my mouth? It is your clearance limit because that is where you filed to and where you want to land. No, it was my clearance limit because that is where I was cleared to. I am beginning to suspect that MX is right and you don't actually have a clue. Again, "direct" does not mean direct to the airport. That's news to me. Where in the regs does it say that? When you don't lose comms and you file and fly to an airport and do not get vectors, where do you go to? You go to an IAF, right? Not usually. Usually I get vectors to the FAF. I fly in pretty congested airspace where full approaches are quite rare. I misunderstood your initial question and I apologize for any demeaning statements. It appeared to me that you were not aware of what the FARs stated. Again, my apologies. Well, it's possible I'm missing something. We seem to have a difference of opinion about what a direct clearance means. I'm still waiting for a citation to support your position. rg |
On 03/11/07 11:41, Ron Garret wrote:
[ snip ] First, the regs explicitly sanction "making up your own stuff" (as you put it) in emergency situations, which lost comm in IMC can easily give rise to. Well, *anything* can lead to an emergency situation. However, there are regulations written specifically for the case of lost communications. If you deem that lost communications is an emergency, and use that to justify doing whatever you want, you're in violation of the regs. Second, a lot of the regs were written before the advent of moving-map GPS. Many procedures that make sense if you're navigating on a VOR make less sense if you always know at a glance exactly where you are. Third, going by the book makes you do some overtly stupid things. The classic example is going NORDO while flying from AVX to FUL. Going by the book requires you to fly to SLI, reverse course, return to the exact spot you just came from (which is over water BTW), and reverse course again. I haven't looked at this particular approach, but I'll assume you're referring to the fact that your clearance limit is the airport, and that the regs require you to go to the clearance limit first? First of all, this is what the regulations tell you to do, and this is what you must do. Period. The fact that some controllers tell you that they would rather you do something different is irrelevant. They will not be defending you in a certificate action case. Incidentally, when I file an IFR flight plan, I select a fix which I can use to initiate my approach, and put a note in the remarks section which states: "In the event of lost communications, XYZ shall be treated as my clearance limit." This way, I don't have to do the back and forth - and it's legal (and expected by ATC). This procedure is manifestly more dangerous than just flying the approach straight in (because it involves more maneuvering, more time in the air, more time over water). Moreover, under normal conditions the approach is ALWAYS flown straight in (via vectors) and under NORDO conditions the controllers expect you to fly the approach straight in (I know because I asked them) notwithstanding that this technically violates the regs. And fourth, the regs leave a lot of stuff unspecified. If you go by the regs in the current situation, you end up over KVNY at 11,000 feet, at which point you're supposed to initiate your descent. But there's no published hold at KVNY (to say nothing of the fact that KVNY is not an IAF for any approach to KVNY) so you have no choice but to improvise at that point. Not really. According to the regs, you go to your clearance limit, then to a point where you can begin your approach. Once you're on a published leg of the approach, you fly it's altitudes. This means you can begin your descent once you're on the IAP. If you need to hold at the fix to lose altitude, you do that. rg -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
Mark Hansen wrote: I haven't looked at this particular approach, but I'll assume you're referring to the fact that your clearance limit is the airport, and that the regs require you to go to the clearance limit first? Correct. First of all, this is what the regulations tell you to do, and this is what you must do. Period. I'm not asking what is the required course of action. I am asking what is the wisest course of action. The fact that some controllers tell you that they would rather you do something different is irrelevant. They will not be defending you in a certificate action case. Quite so, but keeping my ticket is not my only consideration. There is also the safety of the flight to consider. Following the regs requires more time in the air, more maneuvering, more fuel consumption, and unnecessary traversal of extremely crowded airspace in IMC. All this entails additional risk. If I'm faced with a choice of risking my ticket or risking my safety I'll take the former. Incidentally, when I file an IFR flight plan, I select a fix which I can use to initiate my approach, and put a note in the remarks section which states: "In the event of lost communications, XYZ shall be treated as my clearance limit." This way, I don't have to do the back and forth - and it's legal (and expected by ATC). That seems like a sensible idea. I think I'll try that. This procedure is manifestly more dangerous than just flying the approach straight in (because it involves more maneuvering, more time in the air, more time over water). Moreover, under normal conditions the approach is ALWAYS flown straight in (via vectors) and under NORDO conditions the controllers expect you to fly the approach straight in (I know because I asked them) notwithstanding that this technically violates the regs. And fourth, the regs leave a lot of stuff unspecified. If you go by the regs in the current situation, you end up over KVNY at 11,000 feet, at which point you're supposed to initiate your descent. But there's no published hold at KVNY (to say nothing of the fact that KVNY is not an IAF for any approach to KVNY) so you have no choice but to improvise at that point. Not really. According to the regs, you go to your clearance limit, then to a point where you can begin your approach. Once you're on a published leg of the approach, you fly it's altitudes. This means you can begin your descent once you're on the IAP. If you need to hold at the fix to lose altitude, you do that. And what if there is no published hold (as is the case in the current situation)? rg |
Ron Garret writes:
Quite so, but keeping my ticket is not my only consideration. There is also the safety of the flight to consider. Following the regs requires more time in the air, more maneuvering, more fuel consumption, and unnecessary traversal of extremely crowded airspace in IMC. All this entails additional risk. If I'm faced with a choice of risking my ticket or risking my safety I'll take the former. If you declare an emergency, there is no regulatory problem with this. You don't put your license at risk simply because you do something that you deem essential for the safety of your flight. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mark Hansen writes:
If you deem that lost communications is an emergency, and use that to justify doing whatever you want, you're in violation of the regs. You're never in violation of regulations if you deem a situation to be an emergency. As the pilot in command, your decision on whether or not a situation is an emergency is final (FAR 91.3). Two-way communication by radio is required in controlled airspaces because it is dangerous to have aircraft flying around in them without it. Therefore a loss of radio communication is a potentially dangerous situation, and a pilot may well condider it an emergency. The AIM makes this clear (6-4-1(b)). The determination is made by the pilot alone. Pilots with emergencies are still expected to adhere to the standard IFR lost-communications procedures to the extent possible given the nature of their emergencies. The AIM goes into more detail than the regulations from which it is derived, but it still does not cover every situation, and explicitly says so. -- Transpose mxsmanic and gmail to reach me by e-mail. |
snip
And fourth, the regs leave a lot of stuff unspecified. If you go by the regs in the current situation, you end up over KVNY at 11,000 feet, at which point you're supposed to initiate your descent. But there's no published hold at KVNY (to say nothing of the fact that KVNY is not an IAF for any approach to KVNY) so you have no choice but to improvise at that point. If you don't believe that if your clearance limit is the airport and that you can pick any approach and IAF and execute it when lost coms, then you can try this: from "Instrument Flying Handbook" FAA H 8083 15 page 10-11 http://www.faa.gov/library/manuals/a...-8083-15-2.pdf "Holding Instructions If you arrive at your clearance limit before receiving clearance beyond the fix, ATC expects you to maintain the last assigned altitude and begin holding in accordance with the depicted holding pattern. If no holding pattern is depicted, you are expected to begin holding in a standard holding pattern on the course upon which you approached the fix. You should immediately request further clearance." |
![]() Tim wrote: "Holding Instructions If you arrive at your clearance limit before receiving clearance beyond the fix, ATC expects you to maintain the last assigned altitude and begin holding in accordance with the depicted holding pattern. If no holding pattern is depicted, you are expected to begin holding in a standard holding pattern on the course upon which you approached the fix. You should immediately request further clearance." You should immediately pick an approach and land so you stop gumming up the works. |
Newps wrote:
Tim wrote: "Holding Instructions If you arrive at your clearance limit before receiving clearance beyond the fix, ATC expects you to maintain the last assigned altitude and begin holding in accordance with the depicted holding pattern. If no holding pattern is depicted, you are expected to begin holding in a standard holding pattern on the course upon which you approached the fix. You should immediately request further clearance." You should immediately pick an approach and land so you stop gumming up the works. I agree - but the OP thinks that since his clearance limit is an airport that he is to fly to that airport, THEN navigate to an IAF to do an approach. He wanted to know what to do when arriving at a clearance limit when there are no published holds at that point. I could not believe someone flying IFR routinely does not know what to do. That is why I posted it. I hope you are not saying to do this at any airport. |
In article , Tim
wrote: Newps wrote: Tim wrote: "Holding Instructions If you arrive at your clearance limit before receiving clearance beyond the fix, ATC expects you to maintain the last assigned altitude and begin holding in accordance with the depicted holding pattern. If no holding pattern is depicted, you are expected to begin holding in a standard holding pattern on the course upon which you approached the fix. You should immediately request further clearance." You should immediately pick an approach and land so you stop gumming up the works. I agree - but the OP thinks that since his clearance limit is an airport This is not a matter of opinion. My clearance limit was an airport (KVNY to be precise). that he is to fly to that airport, THEN navigate to an IAF to do an approach. That is what the regs say to do. He wanted to know what to do when arriving at a clearance limit when there are no published holds at that point. I could not believe someone flying IFR routinely does not know what to do. Believe it. I fly IFR routinely. (But I don't lose comm routinely.) rg |
Real-world IFR currency | Paul Folbrecht | Instrument Flight Rules | 47 | March 23rd 05 04:19 PM |
Real World Problem in FS9 | The Real Cali Kid | Simulators | 12 | December 6th 03 11:15 AM |
Real World Weather (Isabelle) | [email protected] | Simulators | 1 | September 21st 03 09:53 PM |
Real-time real world air traffic in flight sims | Marty Ross | Simulators | 6 | September 1st 03 04:13 AM |
Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 09:25 AM |
