Soooo..
How come he (MX) was able to give a rather complete and correct answer to the poster's question? Care to give it a try? Dave On Tue, 13 Mar 2007 22:44:15 -0700, C J Campbell wrote: On 2007-03-13 17:43:50 -0700, megaMAX said: On Wed, 14 Mar 2007 01:18:33 +0100, Mxsmanic wrote: Most commercial flights are flown on autopilot for the vast majority of the trip. Thus you would have seen autopilot corrections, not pilot corrections. Just so you know, Msxmanic does not know any more about flight than you do. He is not a pilot. He is just some nut who hangs out here and pretends to know what he is talking about. |
![]() I was flying in an Air Jamaica jet many years ago and while cruising noticed large reddish flames from the exhaust of the Rolls Royce engine. How "normal" would that be? -- Joe Leikhim K4SAT "The RFI-EMI-GUY"© "Treason doth never prosper: what's the reason? For if it prosper, none dare call it treason." "Follow The Money" ;-P |
**THE-RFI-EMI-GUY** writes:
I was flying in an Air Jamaica jet many years ago and while cruising noticed large reddish flames from the exhaust of the Rolls Royce engine. How "normal" would that be? It depends on the exact conditions. Were you cruising? Climbing? Descending? What altitude? How did the engine sound? How long did the flames last, and what did they look like, exactly? Normally visible flames don't extend beyond the engine, although if you look directly into the exhaust of a jet engine you may well be able to see glowing internal parts. High-performance engines may glow externally as well. And of course afterburners can produce long flames that extend well beyond the engine. And so on. There is jet fuel burning inside a running jet engine all the time, so a visible flame isn't necessarily a cause for panic or concern. -- Transpose mxsmanic and gmail to reach me by e-mail. |
On Mar 15, 11:59 am, Dave wrote:
Soooo.. How come he (MX) was able to give a rather complete and correct answer to the poster's question? Care to give it a try? More than possible that the poster had a middle ear infection. Not having instruments and the training to use them while back among the self loading cargo how could any-one tell what the aircraft was doing? |
george writes:
More than possible that the poster had a middle ear infection. I don't see the connection between a middle-ear infection and what he saw or believed. Not having instruments and the training to use them while back among the self loading cargo how could any-one tell what the aircraft was doing? One can estimate visually, but with limited visibility this is difficult. Even pilots cannot depend on visual cues alone, which is why they have instruments. -- Transpose mxsmanic and gmail to reach me by e-mail. |
instruments. Yes, they can. But what do I know, I only fly tiny planes. -Kees |
Mxsmanic wrote in
: george writes: More than possible that the poster had a middle ear infection. I don't see the connection between a middle-ear infection and what he saw or believed. of course you don't, but it's the first thing I thought of.. wonder why? bertie |
On Mar 14, 3:59 pm, Dave wrote:
Soooo.. How come he (MX) was able to give a rather complete and correct answer to the poster's question? Care to give it a try? Dave On Tue, 13 Mar 2007 22:44:15 -0700, C J Campbell wrote: On 2007-03-13 17:43:50 -0700, megaMAX said: On Wed, 14 Mar 2007 01:18:33 +0100, Mxsmanic wrote: Most commercial flights are flown on autopilot for the vast majority of the trip. Thus you would have seen autopilot corrections, not pilot corrections. Just so you know, Msxmanic does not know any more about flight than you do. He is not a pilot. He is just some nut who hangs out here and pretends to know what he is talking about. MX's knowledge is very sophomoric, and heavily stilted towards biases introduced by inaccuracies in his simulations. As in this case. Minor Harmonic oscillations in flights are a natural byproduct of the dynamic stability of modern aircraft. The Autopilot has no part in it. When the oscillations are on the Longitudinal axis, they are called phugoid oscillations, I'm not sure if there is a similar term for the roll equivolents, but it is the same deal- Essentially what is happening is a battle between the aircraft's substantial momentum, and the aerodynamic forces which keep it pointed into the wind... Large out-of-trim deflections (both roll and pitch) are damped quickly, but there is a threshold at which the amplitude of the oscillations falls below the aerodynamics ability to produce large enough forces to damp the behavior... The period and amplitude of these harmonic functions are directly related to the configuration and chord of the aerodynamic surfaces vs. The aircraft's distribution of mass. In general, thinner aerodynamic surfaces create stronger off-center aerodynamic forces and hence better damping, and lighter aircraft produce weaker momentum forces and again, fewer oscillations. Granted, 'fewer' in this case is a matter of perception... the oscillations you were seeing were really very minor (less than a degree), its just that the solid horizon combined with the long arm of the wing made them more obvious than the same fraction of a degree roll oscillation would be in a smaller aircraft. No MX... it has nothing to do with the autopilot... FWIW, I remember reading somewhere that the 747 prototype actually had a problem on its first few flights - the engineers had designed the aerodynamic surfaces to damp the phugoid (longitudinal) harmonics based on a theoretical perfectly rigid aircraft, however, in reality, it turned out that the fuselage had a natural bending resonance frequency which matched the aerodynamic harmonic frequency, and they amplified eachother to produce an in flight longitudinal harmonic that was actually quite substantial... the result, IIRC, was a very sick planeload of journalists on the aircraft's first publicity flight. For more information, read up on both Phugoid oscillations and Roll stability via using wing dihedral. |
EridanMan writes:
Minor Harmonic oscillations in flights are a natural byproduct of the dynamic stability of modern aircraft. The Autopilot has no part in it. Do these oscillations cause control surfaces to move by themselves? Are they asymmetrical? When the oscillations are on the Longitudinal axis, they are called phugoid oscillations, I'm not sure if there is a similar term for the roll equivolents ... Dutch roll and spiral come to mind, although they are not limited exclusively to the roll axis. No MX... it has nothing to do with the autopilot... If the control surfaces are moving, either the pilot or the autopilot is acting upon them. If the corrections are asymmetrical, this would tend to exclude the hypothesis of harmonic oscillations. Also, roll harmonics often extend over periods of minutes in large aircraft and would not be obvious just by watching the wing outside the window. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Commercial 250nm VFR flight - all 3 landings on the same day? | Jim Macklin | Instrument Flight Rules | 39 | December 20th 06 12:11 PM |
Mooney Engine Problems in Flight | Paul Smedshammer | Piloting | 45 | December 18th 04 09:40 AM |
Looping during a commercial flight | LordAvalon | Aerobatics | 10 | October 23rd 04 04:05 PM |
Nixon on Commercial Flight | Flyin'[email protected] | Piloting | 1 | June 16th 04 05:51 PM |
Flight Unlimited 2 on Windows Xp .- any known problems? | tw | Simulators | 2 | April 25th 04 05:05 PM |
