Today we experienced a new first, when the tower controller at
Jefferson City, Missouri decided to cut a Cessa 172 in front of me on a short right base, *after* clearing me to land on Rwy 30. Incredulous, I slowed as much as possible, and watched as the 172 (who was several hundred feet above us) struggled to lose enough altitude to land safely. We were both bucking a 30 knot gusty headwind, which -- although it allowed me to slow waaaay down -- did nothing but make the poor, hapless Skyhawk keep flying, and flying, and flying.... Eventually he put it in a steep slip, and managed to touch down about 25% down the runway -- at which point he nearly stopped! Instead of the tower telling the guy to land long and exit immediately -- the runway is 6000 feet long -- the controller remained silent, as I ground my way down final at minimum approach speed, way behind the power curve, with a ground speed of maybe 50 knots. Having landed at OSH and SNF a few times, I knew I was spaced just fine -- IF the 172 would only get off the danged runway. Unfortunately, he was in no hurry to do so, and the controller blithely told me to "go around" in his most bored "controller voice" -- as if he does this all day long. Having just endured 20 minutes of fairly severe clear-air turbulence during our descent from 7500 feet, I was *not* amused -- but bit my tongue as I dutifully went around. The guys in the FBO were all talking about it when we walked in. Apparently the 172 pilot was a student (in which case he did a damned good job getting that thing down), and the controller was...well, no one would say what the controller was. However, I'm pretty sure we know why he's been assigned to the deadest control tower in the Midwest. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
Today we experienced a new first, when the tower controller at Jefferson City, Missouri decided to cut a Cessa 172 in front of me on a short right base, *after* clearing me to land on Rwy 30. Incredulous, I slowed as much as possible, and watched as the 172 (who was several hundred feet above us) struggled to lose enough altitude to land safely. You should have told the controller to, excuse my limited French, le pousser oł le soleil ne brille pas. Then you should have quoted him the right-of way rules (planes below have right over those above, planes on approach have right over those in the pattern), and told him that you were taking your CLEARANCE and using the RUNWAY. If he was routing other traffic, he should have indicated that in your clearance. If he expected to land the Cessna before you, again it should be indicated in your clearance (or the clearance NOT given in the first place). He should NOT expect to route higher, slower traffic ahead of lower, faster traffic, and he certainly should have enough time on his hands such that he need not issue go-arounds. I'd get me a-hold of whomever signs his paychecks, because he's not doing his job, but YMMV. ![]() TheSmokingGnu |
On the other hand, here was a student pilot trying to land on a windy
day, and we don't know how many approaches he aborted. It wasn't done correctly, but he assumed you had the skill to do what was needed, and you did. Besides, flying a miss from time to time when not expected is good for you (I read that once -- or maybe it was something MX said). On Mar 17, 12:09 am, TheSmokingGnu wrote: Jay Honeck wrote: Today we experienced a new first, when the tower controller at Jefferson City, Missouri decided to cut a Cessa 172 in front of me on a short right base, *after* clearing me to land on Rwy 30. Incredulous, I slowed as much as possible, and watched as the 172 (who was several hundred feet above us) struggled to lose enough altitude to land safely. You should have told the controller to, excuse my limited French, le pousser oł le soleil ne brille pas. Then you should have quoted him the right-of way rules (planes below have right over those above, planes on approach have right over those in the pattern), and told him that you were taking your CLEARANCE and using the RUNWAY. If he was routing other traffic, he should have indicated that in your clearance. If he expected to land the Cessna before you, again it should be indicated in your clearance (or the clearance NOT given in the first place). He should NOT expect to route higher, slower traffic ahead of lower, faster traffic, and he certainly should have enough time on his hands such that he need not issue go-arounds. I'd get me a-hold of whomever signs his paychecks, because he's not doing his job, but YMMV. ![]() TheSmokingGnu |
On Mar 16, 9:09 pm, TheSmokingGnu
wrote: Jay Honeck wrote: Today we experienced a new first, when the tower controller at Jefferson City, Missouri decided to cut a Cessa 172 in front of me on a short right base, *after* clearing me to land on Rwy 30. Incredulous, I slowed as much as possible, and watched as the 172 (who was several hundred feet above us) struggled to lose enough altitude to land safely. You should have told the controller to, excuse my limited French, le pousser oł le soleil ne brille pas. Then you should have quoted him the right-of way rules (planes below have right over those above, planes on approach have right over those in the pattern), and told him that you were taking your CLEARANCE and using the RUNWAY. If he was routing other traffic, he should have indicated that in your clearance. If he expected to land the Cessna before you, again it should be indicated in your clearance (or the clearance NOT given in the first place). He should NOT expect to route higher, slower traffic ahead of lower, faster traffic, and he certainly should have enough time on his hands such that he need not issue go-arounds. I'd get me a-hold of whomever signs his paychecks, because he's not doing his job, but YMMV. ![]() TheSmokingGnu I can't agree. Don't try telling anyone anything over the air. Land, and have a polite discussion with the person. Leave the airways clear. |
Then you should have quoted him the right-of way rules (planes below have right over those above, planes on approach have right over those in the pattern), and told him that you were taking your CLEARANCE and using the RUNWAY. Really? Student pilot, clear air turbulence, 30kt gusty headwind . . . -- Tony Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
On Mar 16, 7:58 pm, "Jay Honeck" wrote:
Today we experienced a new first, when the tower controller at Jefferson City, Missouri decided to cut a Cessa 172 in front of me on a short right base, *after* clearing me to land on Rwy 30. Incredulous, I slowed as much as possible, and watched as the 172 (who was several hundred feet above us) struggled to lose enough altitude to land safely. We were both bucking a 30 knot gusty headwind, which -- although it allowed me to slow waaaay down -- did nothing but make the poor, hapless Skyhawk keep flying, and flying, and flying.... Eventually he put it in a steep slip, and managed to touch down about 25% down the runway -- at which point he nearly stopped! Instead of the tower telling the guy to land long and exit immediately -- the runway is 6000 feet long -- the controller remained silent, as I ground my way down final at minimum approach speed, way behind the power curve, with a ground speed of maybe 50 knots. Having landed at OSH and SNF a few times, I knew I was spaced just fine -- IF the 172 would only get off the danged runway. Unfortunately, he was in no hurry to do so, and the controller blithely told me to "go around" in his most bored "controller voice" -- as if he does this all day long. Having just endured 20 minutes of fairly severe clear-air turbulence during our descent from 7500 feet, I was *not* amused -- but bit my tongue as I dutifully went around. The guys in the FBO were all talking about it when we walked in. Apparently the 172 pilot was a student (in which case he did a damned good job getting that thing down), and the controller was...well, no one would say what the controller was. However, I'm pretty sure we know why he's been assigned to the deadest control tower in the Midwest. -- Jay Honeck Iowa City, IA Pathfinder N56993www.AlexisParkInn.com "Your Aviation Destination" I am not sure I would have gotten " behind the power curve" in gusty conditions. A sooner bailout on your determination would have been prudent. A 360 for spacing while still on final seems better then dragging it in. After all you are PIC and responsible for the safety of the flight. Glad you got home safely.. Ben |
On 16 Mar 2007 18:58:53 -0700, "Jay Honeck"
wrote: Today we experienced a new first, when the tower controller at Jefferson City, Missouri decided to cut a Cessa 172 in front of me on a short right base, *after* clearing me to land on Rwy 30 snipped a bunch of good stuff What type of aircraft were you flying? -- Jim in Houston osPAm Nurse's creed: Fill what's empty, empty what's full, and scratch where it itches!! RN does NOT mean Real Nerd! -- Posted via a free Usenet account from http://www.teranews.com |
Jay Honeck wrote: Today we experienced a new first, when the tower controller at Jefferson City, Missouri decided to cut a Cessa 172 in front of me on a short right base, *after* clearing me to land on Rwy 30. Incredulous, I slowed as much as possible, and watched as the 172 (who was several hundred feet above us) struggled to lose enough altitude to land safely. You should have told the controller to, excuse my limited French, le pousser oł le soleil ne brille pas. Then you should have quoted him the right-of way rules (planes below have right over those above, planes on approach have right over those in the pattern), and told him that you were taking your CLEARANCE and using the RUNWAY. If he was routing other traffic, he should have indicated that in your clearance. If he expected to land the Cessna before you, again it should be indicated in your clearance (or the clearance NOT given in the first place). He should NOT expect to route higher, slower traffic ahead of lower, faster traffic, and he certainly should have enough time on his hands such that he need not issue go-arounds. I'd get me a-hold of whomever signs his paychecks, because he's not doing his job, but YMMV. ![]() TheSmokingGnu Ah bull****. If the person was a student he had every right to make modifications. He made a mistake probably. It happens all the time. Just deal with it and keep flying. I wish all the complaints I had about the controllers in this area were as benign as that. |
Jay Honeck wrote: Today we experienced a new first, when the tower controller at Jefferson City, Missouri decided to cut a Cessa 172 in front of me on a short right base, *after* clearing me to land on Rwy 30. Incredulous, I slowed as much as possible, and watched as the 172 (who was several hundred feet above us) struggled to lose enough altitude to land safely. You should have told the controller to, excuse my limited French, le pousser oł le soleil ne brille pas. Then you should have quoted him the right-of way rules (planes below have right over those above, planes on approach have right over those in the pattern), and told him that you were taking your CLEARANCE and using the RUNWAY. Why make a big deal out of a minor issue? Anyway, after a tirade like you suggest all the controller would have had to do was tell you that your landing clearance was now canceled and to go around. BDS |
conditions. A sooner bailout on your determination would have been prudent. A 360 for spacing while still on final seems better then dragging it in. After all you are PIC and responsible for the safety of the flight. Glad you got home safely.. Yeah, I thought about doing a 360, but it was so danged gusty that turning at low altitude was very uncomfortable. (More for the family than for me, of course.) It was one of those days where, if you kept the wind on your nose, it wasn't bad, but as soon as you turned and had the relative gusts hitting you from the side, things got rolly-polly pretty quickly. Nothing more uncomfortable (for me, anyway) than having turbulence trying to lift the high wing to vertical in a turn. Having landed at OSH and SNF a bunch of times, I'm pretty used to slow flight and close spacing. Everything would have worked out, if the controller had told the 172 to land long and exit immediately -- but it wasn't to be. No big deal, but at the end of a very long flight it was more work than I needed. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
| Round Engines | john smith | Piloting | 20 | February 15th 07 04:31 AM |
| induced airflow | buttman | Piloting | 3 | February 19th 06 05:36 AM |
| Round Engines | Voxpopuli | Naval Aviation | 16 | May 31st 05 07:48 PM |
| Source of Induced Drag | Ken Kochanski | Soaring | 2 | January 10th 04 01:18 AM |
| Predicting ground effects on induced power | Marc Shorten | Soaring | 0 | October 28th 03 12:18 PM |
