OLC broken ?
Old March 26th 07, 05:33 PM posted to rec.aviation.soaring
Default 2K7 OLC Tutorial for the masses?
On Mar 23, 7:01 pm, Greg Arnold wrote:
Doug Haluza wrote:
On Mar 20, 5:53 am, "Doug Haluza" wrote:
You should always use the latest version of your software. As problems
are discovered, the vendors make updates, and there is no sense having
problems that are already solved. SeeYou is also testing a beta
version to deal with a strange data transmission issue with the new
OLC interface where "+" signs get corrupted in transmission, causing
validation to fail. This affects C302+ users, but could also randomly
affect anyone if there is a "+" sign in the digital signature.
SeeYou just released version 3.65 today, presumably with the fix for
the C302 OLC upload from the beta version. Be sure to download it if
you are a SeeYou user with current upgrade support. The web site shows
this as V3.62 on the download page, but will show v3.65 when you
install it.
Doug Haluza
SSA-OLC Admin
SeeYou still appears to be doing the OLC optimization different from the
OLC software. For purposes of the 1000 meter rule between the start and
end of the flight, OLC appears to take the height between the start and
end of the scored flight, while SeeYou appears to take it between
release from tow and the end of scored flight. Most of the time, this
doesn't matter.
However, it does matter under the right conditions. I had a flight
about a month ago (February 16) where the OLC score (direct upload) was
more than 20 points less than the SeeYou optimization. And today, the
OLC score (direct upload) was slightly higher than the SeeYou optimization.
Neither software appears to be consistent with the OLC rules:
The minimal finish altitude is 1000 metre below the start altitude.
The start altitude the lowest altitude after the begin of free flight
and before reaching the start point.
The start time is the time at which the start altitude is reached.
The finish altitude is the highest altitude after reaching the finish
point and before end of free flight.
The finish time is the time at which the finish altitude is reached
after the finish point is reached.
Where the OLC and SeeYou programs differ, I believe the "more correct"
score will be whichever is the higher. But it appears that both
softwares can give a score that is lower than what the OLC rules require
-- this will happen if the 1000 meter rule affects the result, and if
there is a point after release from tow and prior to start that is lower
than both tow release and start height (or if there is a point after
finish that is above the finish height).- Hide quoted text -
- Show quoted text -
Below is a link to my flight on Saturday. I flew for over 4 hours,
but my OLC scorable time was around 14 minutes. I'm pretty sure I
know what caused it (me messing with the iPAQ) to cut off, but I don't
have any software to analyze what it did to the .igc file in the
Cambridge 302A datalogger. The entire 4 hour flight is shown, just
not scored. My flight on Sunday had no issues, so I know it's not an
OLC issue, it's an operator/user interface problem.
Also, where can I find a "legend" for the graph that appears below
the flight trace? I see some bits of yellow here and there.
http://www.onlinecontest.org/olc-2.0...Id=-2034543116
Thanks for any help!
Old March 26th 07, 05:52 PM posted to rec.aviation.soaring
Greg Arnold
You did the direct upload to OLC? The OLC software guessed wrong about
the end of your flight. You need to click Edit Flight, then change the
ending time on the screen that comes up.
Old March 26th 07, 07:57 PM posted to rec.aviation.soaring
http://www.onlinecontest.org/olc-2.0....html?flightId...
ending time on the screen that comes up.- Hide quoted text -
That was it!! I knew it cut my flight off, I DIDN'T know I could
change it so easily! Thanks.
Also, thanks for the info about the yellow on the graph.
Old March 26th 07, 05:56 PM posted to rec.aviation.soaring
Greg Arnold
The green is the terrain, and the yellow is the noise recorded by the
ENL sensor.
Old April 1st 07, 09:48 AM posted to rec.aviation.soaring
Ramy
One thing I miss in the new OLC is the map details. The only waypoint
now is the takeoff airport. What happened to all the waypoints? It is
very hard to figure where and how far one flew from looking at the
map. Any chance we can have the waypoints back?
Ramy
Old April 1st 07, 02:53 PM posted to rec.aviation.soaring
Airjunkie
Ramy
Waypoints???? Hell, I'd be happy if they'd just figure out how to get
my WinPilot flights posted! It's only been since February. In the
last week my flights have gone from a yellow V to a red V for no
apparent reason....
Bill
Broken P lead? Jim Burns Piloting 16 October 27th 06 08:06 PM
surviving a broken wing Kyler Laird General Aviation 0 August 3rd 06 04:31 PM
Broken window in jet plane Eduardo K. Piloting 17 April 13th 06 10:19 PM
Broken wing Stubby Piloting 27 January 1st 06 03:04 AM
Looking for broken Garmin Larry Goddard Soaring 3 July 5th 04 12:46 PM
