A tower-induced go-round
Old March 24th 07, 02:45 PM posted to rec.aviation.piloting
Steven P. McNicoll
Default A tower-induced go-round
"TheSmokingGnu" wrote in message
French Valley (F70), we were using 18 that day for winds. The "standard"
crosswind takes you away from the sizable (and expensive, and influential)
housing developments some wonderful person decided needed to be direct off
the end of a GA airport.
The A/FD says:
"All departures.noise sensitive areas to N and S, best rate of climb to TPA
before departing the pattern. Calm wind.use Rwy 18."
Nothing there about crosswind being the "standard" departure.
Besides of which, everyone else was departing crosswind, and maintaining a
civil and orderly line of traffic is almost always preferable to flying
off the handle and doing your own thing, especially if you aren't going to
tell anyone first.
So he leaves the area in a different direction than everyone else. Why is
that a problem?
Old March 24th 07, 05:20 PM posted to rec.aviation.piloting
TheSmokingGnu
Note the use of quotation marks to denote the fact that it is not an
established, official procedure, but an agreed-upon and accepted modus
of operation while at the airport.
that a problem?
It's a problem when he tries to leave by going through me. It's a
problem when he doesn't announce his departure vector. It's a problem
when he doesn't respond or acknowledge position reports. It's a problem
when he disrupts the nominally formed traffic pattern. It's a problem
when he flies directly opposite the approach and likely descent vectors
(following the Paradise VOR) of other aircraft. It's a REAL problem when
he does it at 140 knots.
Did you not actually read my responses? It seems likely, after the way
you treated Jay.
TheSmokingGnu
Old March 24th 07, 10:00 PM posted to rec.aviation.piloting
Jay Honeck
that a problem?
These are probably the same guys who come blasting into a full pattern
on a long straight-in approach, expecting everyone else to move aside
because they're "charter captains".
I know most of the charter pilots in our area, and they are invariably
good about announcing their intentions (some even apologize for
barging in) -- but there are always those select few SOBs who have
just been handed off from approach and simply can't be bothered with
such mundane duties as making position reports on Unicom. They are
truly menaces of the air, in my humble opinion.
you treated Jay.
You *do* realize that you're wasting your time arguing with Steven,
right? Understanding and properly reacting to subtle or nuanced
prose is simply not in his nature.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old March 25th 07, 03:07 AM posted to rec.aviation.piloting
Larry Dighera
On 24 Mar 2007 15:00:43 -0700, "Jay Honeck" wrote
in .com:
The issue of reacting to implied, as opposed to stated, prose is that
the reader has no positive way of knowing if his own subjective
inference is that intended by the author.
While it such may be marginally useful in affairs of the heart, they
have little place in aviation, IMO.
Old March 25th 07, 04:36 AM posted to rec.aviation.piloting
Jay Honeck
I have dealt with folks like Steven my whole life; the world is full
of them. You are very much like Steven, but -- on occasion -- seem to
have breakthroughs into understanding. I guess that makes you a
savant?
As but one example of the phenomenon that plagues guys like Steven, he
did not understand that my phrase about "having flown into Oshkosh, I
knew we had plenty of room" meant that we had damned little spacing
between us, in the normal world of controlled airspace. Any Oshkosh-
experienced pilot would have immediately understood that subtle
remark, and pilots with any knowledge of Oshkosh arrival procedures
might have picked up on it as well.
Without understanding this nuanced prose, Steven launched into a
diatribe about how "You said you had plenty of room." It's simply
not in him to understand this sort of thing, because he's neither
experienced enough as a pilot, nor is he capable of anything but
linear thought. Colored prose and creative writing are anathema to
guys like Steven, because it "clouds the issue" for them. If it's not
in black and white, it's wrong.
That's why guys like him are so good at quoting chapter and verse of
the rules. The codification becomes an end in itself, lending
structure and meaning to their lives, without which nothing makes
sense.
This trait probably makes him a good controller, by the way.
In the end, though, I believe this is why Steven continually butts
heads with many of us here. Pilots tend to be non-linear thinkers.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old March 26th 07, 02:36 AM posted to rec.aviation.piloting
Jon Woellhaf
Jay Honeck wrote [about operations at uncontrolled fields]
Does this happen often at Class-D airports?
Old March 28th 07, 02:04 PM posted to rec.aviation.piloting
Jay Honeck
Worse. At Class D they report that they're on a 3-mile final, when
they're still 10 miles out...
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old March 28th 07, 11:30 AM posted to rec.aviation.piloting
Steven P. McNicoll
"Jay Honeck" wrote in message
How foolish of them to expect pattern traffic to abide by the FARs.
Interesting how a misstatement becomes "subtle or nuanced prose" after
you're called on it.
Old March 28th 07, 11:12 AM posted to rec.aviation.piloting
Steven P. McNicoll
established, official procedure, but an agreed-upon and accepted modus of
Agreed upon by whom?
Wouldn't that be true regardless which way he left the area? Wouldn't
leaving the area in a different direction make it less likely that he'd go
through you?
It's a problem
Why?
What's the benefit in acknowledging position reports?
How does departing via the upwind disrupt the pattern?
flies directly opposite the approach and likely descent vectors (following
the Paradise VOR) of other aircraft. It's a REAL problem when he does it
at 140 knots.
What's a descent vector?
I read all of them. I ask questions in order to make sense of them?
It seems likely, after the way you
treated Jay.
I asked him questions too.
Old March 28th 07, 06:55 PM posted to rec.aviation.piloting
TheSmokingGnu
You're just trolling, now.
The pilots in the pattern and on the tarmac. Duh.
through you?
Yes, and to the second, no. Not in this particular instance.
Why?
BECAUSE I HAVE NO BLOODY ****ING IDEA WHERE HE IS OR WHERE HE'S GOING.
My god, are you dense.
Acknowledging a report involves making your own report, ergo someone
could have figured out where he is.
Because after departing crosswind and climbing south, most traffic
leaves by turning back north and following a radial along the mountain
ridge. Now, they have non-announcing traffic from an unexpected
direction, flying much faster than they do.
Alternately, aircraft are approaching the area in the same manner (but
at different altitudes). Now _THEY_ have traffic in unexpected
directions without knowledge of location or intention.
If you have to ask, you haven't used one.
No, you ask questions like a two-year-old asks "Why"; to annoy and
frustrate.
You accosted him and then used ad hominem attacks on his intelligence
and piloting skill.
**** off, dear.
TheSmokingGnu
Round Engines john smith Piloting 20 February 15th 07 03:31 AM
induced airflow buttman Piloting 3 February 19th 06 04:36 AM
Round Engines Voxpopuli Naval Aviation 16 May 31st 05 06:48 PM
Source of Induced Drag Ken Kochanski Soaring 2 January 10th 04 12:18 AM
Predicting ground effects on induced power Marc Shorten Soaring 0 October 28th 03 11:18 AM
