On Apr 4, 10:23 pm, Mxsmanic wrote:
That's one reason why I often like to fly big aircraft. You don't fly big aircraft. You don't flyany aircraft. The closest you come is playing with an entry-level simulator game. there's a lower threshold below which I don't bother. Lower threshold? Playing with MSFS is a first baby step into aviation--there is nothing lower. And your upper threshold excludes anything actually capable of flight. |
Mxsmanic wrote:
That's one reason why I often like to fly big aircraft. No you like to fly simulations of big aircraft. Not all real airplanes have electrical systems. True, and some are powered by rubber bands as well, but there's a lower threshold below which I don't bother. Yes, but you come here arguing that any outside your willingness to simulate don't exist. This is makes you look pathetically stupid and is the main reason that most people on this forum are hostile to you. |
![]() "Mxsmanic" wrote in message ... writes: INS is too big and expensive for GA aircraft. That's one reason why I often like to fly big aircraft. Just how big is your desk???? Not all real airplanes have electrical systems. True, and some are powered by rubber bands as well, but there's a lower threshold below which I don't bother. Then how can you be bothered by playing a sim???? |
![]() "Ron Natalie" wrote in message m... Huh? What does the wind have to do with VOR's. If the needle is centered, you're within the tolerance of the VOR. The tolerance is primarily 4-6 degrees. This keeps you inside the airway at moderate distances from the VORs. What about at more than moderate distances from the VOR? At 40 miles from the VOR 6 degrees is 4 miles. |
On Wed, 04 Apr 2007 16:28:41 GMT, "Steven P. McNicoll"
wrote: "Ron Natalie" wrote in message om... Huh? What does the wind have to do with VOR's. If the needle is centered, you're within the tolerance of the VOR. The tolerance is primarily 4-6 degrees. This keeps you inside the airway at moderate distances from the VORs. What about at more than moderate distances from the VOR? At 40 miles from the VOR 6 degrees is 4 miles. Under the heading of "Enquiring Minds Want to Know: In defining an intersection, what's the maximum distance from a VOR that's allowed? Does an intersection in a GPS database represent the actual intersection of VOR radials, or is it defined in LAT/LON terms? (I.e., can there be two locations for an intersection, depending on whether you're using VORs or GPS? Apart from shifting declination, what is the mechanism by which VORs drift out of calibration? Isn't the phase shift for each antenna in the array set by the length of coax between it and the transmitter? Does Velocity Factor change significantly as the coax ages? If it is a matter of aging cable, does that mean the error is uniform and the pattern is shifted consistently around the compass rose, or are the longer cables affected more? And in the latter case, how would that affect the error? (I would think that the higher the radial, the greater the error, if this were the case.) (Or do I not understand how a VOR array is phased?) Don |
![]() "Don Tuite" wrote in message ... Under the heading of "Enquiring Minds Want to Know: In defining an intersection, what's the maximum distance from a VOR that's allowed? I guess the simple answer is 135 miles. The limiting factor is the minimum divergence angle. The minimum divergence angle (smaller angle of the two crossing radials) is one degree per NM up to 45 miles, beyond 45 miles it's 1/2 degree per NM. Since the mimimum divergence can't exceed 90 degrees, the furthest you can get is 135 miles. Does an intersection in a GPS database represent the actual intersection of VOR radials, or is it defined in LAT/LON terms? (I.e., can there be two locations for an intersection, depending on whether you're using VORs or GPS? There can be many locations for a given fix. For example, a fix identified by intersecting radials as well as radial/DME from either navaid. The exact position varies with altitude and which navaid you choose to determinr position. |
Steven P. McNicoll wrote:
"Ron Natalie" wrote in message m... Huh? What does the wind have to do with VOR's. If the needle is centered, you're within the tolerance of the VOR. The tolerance is primarily 4-6 degrees. This keeps you inside the airway at moderate distances from the VORs. What about at more than moderate distances from the VOR? At 40 miles from the VOR 6 degrees is 4 miles. At 51 miles, 4.5 degrees gives you 4 miles. 6 degrees gives you about 6. Theres' 2 miles of protected area outside the airway. Statistically you're within it, but even in the worst case you're safe. |
In rec.aviation.piloting Ron Natalie wrote:
wrote: If the drift is sufficient ( 2 or 3 degrees, I forget the number; it's in the AIM ) they are supposed to be recalibrated. The uncertainty in the wind drift angle is usually a lot more than that. Huh? What does the wind have to do with VOR's. If the needle is centered, you're within the tolerance of the VOR. The tolerance is primarily 4-6 degrees. This keeps you inside the airway at moderate distances from the VORs. The uncertainty in the wind correction angle is greater than the total error in a VOR radial. So you plan the flight given the winds aloft forcast, crank in a wind correction angle, and come up with a heading. The heading you wind up flying to keep the needle centered will seldom be the heading on your planning sheet. That's all I'm saying. -- Jim Pennino Remove .spam.sux to reply. |
EridanMan wrote:
Are VOR's all MH based? Because all of the pilot's navigational faculties are magnetic, too. most VOR's around here have long since fallen behind Magnetic drift... By how much, and where is "here", if you don't mind my asking? you have to flightplan in True Heading, convert to Mag Heading to get your vectors, THEN you have to get the corrective factor for each of the VOR's your using for navigation and note that as well? huh? But why do that if the winds you get in a preflight are already in MH? Wouldn't it be simpler to calc your MH's, and then use the corrective factors you need to find the "real" radial you should follow? TheSmokingGnu PS: Don't worry, I still do things by hand, too. |
RANT! | wise purchaser | Owning | 2 | March 27th 07 10:04 PM |
Random thoughts 2 | Bill Daniels | Soaring | 6 | September 1st 06 05:37 AM |
A Jeppesen rant | Peter R. | Piloting | 4 | January 17th 05 03:54 AM |
Why didn't GWB [insert rant] | Jack | Military Aviation | 1 | July 15th 04 11:30 PM |
Random Hold Generator... | Tina Marie | Instrument Flight Rules | 0 | November 5th 03 04:21 PM |
