Peter Dohm writes:
Some of you guys are a *lot* more trusting than I am. I was really hoping for some of the current airmen to say this, but most have only nibbled around the edges--so here goes: The magnetic compass has exactly one thing in its favor, and that is just plain old Brute Reliability. It requires no power from the aircraft's systems, it is not subject to happenstance or whim concerning any transmitting stations, and wide spread interference with (the) signal is unimaginable. It's already so inaccurate without interference that that's bad enough. There are plenty of spots on charts where the compass will be 6-8 degrees off even from the already irrgular declination over larger areas. Anyway, if you push this concept to its limit, you should be able to complete a trip without an engine, since engines are not 100% reliable. Obviously, that's not a practical reality, and at some point you have to recognize that a compass alone, no matter how reliable in the sense of always working to some extent, may simply not be enough to get you home. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Peter Dohm wrote:
The magnetic compass has exactly one thing in its favor, and that is just plain old Brute Reliability. I like the mag compass too. While they don't rely on any aircraft systems to work, there are things that can cause them to be innacurate. The earths magnetic field varies in strength and isn't all that constant in all locations (and it's getting worse). I was reading Lindbergh's book about his transatlantic flight and at one point, both his whiskey compass and Earth Inductor Compass were just wobbling around uselessly. Eventually, they both started working again on their own, but he was guessing at his heading for nearly an hour. I can relate. I have a video that I took on a cross country flight, of my mag compass doing rapid 360s. It lasted about 5 min. and there were no magnetic anomolies listed on the chart in that area. There were also no UFO sightings reported that day :-)) John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200704/1 |
![]() "Kev" wrote in message ups.com... VORs are allowed to get +/- 6 degrees off. Seems a lot, but it's only a handful of miles off-course over most VORs' ranges. Anyway, see: http://www.naco.faa.gov/index.asp?xml=naco/faq#q2h "The magnetic variation of the earth changes at a rate of 50.27 seconds of arc per year." That seems a bit low to me. At that rate six degrees of change would take 430 years. |
Steven P. McNicoll writes:
"The magnetic variation of the earth changes at a rate of 50.27 seconds of arc per year." That seems a bit low to me. At that rate six degrees of change would take 430 years. It changes at a variable rate, and once it approaches a degree, charts and navaids have to change. It's a tremendous amount of extra work, an additional source of error, and an imprecise and fickle basis for navigation. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "Mxsmanic" wrote It changes at a variable rate, and once it approaches a degree, charts and navaids have to change. It's a tremendous amount of extra work, an additional source of error, and an imprecise and fickle basis for navigation. I came to aviation from boats. In that field of navigation, in my part of the world we mostly use true north as reference, but I've seen charts using magnetic north, e.g. in the Caribbean where the magnetic variation is considerable (around 15 degrees). Also, all boat GPSes can be set to show either true or magnetic north, so using magnetic north is obviously a viable method also at sea. So, let me give some arguments why using magnetic north on aviation charts is not as stupid as it may sound. 1. A GPS does not show a reliable heading unless the aircraft is moving (unless the GPS is of a very advanced type with dual antennas, not widely used in aircraft). Before every takeoff the DG needs to be set, and the magnetic compass enables this also when the aircraft is stationary. 2. The extra work referred to by Mx above is the same as would otherwise have to be done in-flight in each aircraft, adding to the crew's workload and introducing many possibilities for errors. (Mariners actually do this en-route, but they have much more time to do the calculations than pilots have.) For aviation, it's safer to do the calculations and corresponding changes to charts and navaid data at a central source where they can be quality-controlled much more extensively than what the co-pilot can do in an aircraft in-flight. Charts need to be updated frequently anyway, regardless of changes in magnetic variation, so it's not a big deal. 3. Even though electronic or inertial systems would allow navigation without any reference to magnetic north, making the above mentioned calculations unnecessary, experience and tradition so far points to the conclusion that a magnetic compass and the corresponding magnetic designations on charts are still useful. Note that when the magnetic compass is most critically needed, i.e. in case of a failure of the electronic navigation systems, that's also the time when the pilots have least time and opportunity to perform the extra calculations that would be required if the chart data were given in true north. 4. The magnetic compass system gives a simple foolproof method to ensure the aircraft is lined up on the correct runway, anywhere in the world. Last August, 49 real people died at KLEX in an accident that might have been prevented by this simple check. 5. Omitting the magnetic compass would make the aircraft totally dependent on external sources for all navigation other than chart-based VFR (unless it has an inertial navigation system, which is obviously a much more expensive solution viable only for large aircaft). This is so far not considered acceptable. |
On Apr 4, 12:22 pm, "Steven P. McNicoll"
wrote: "Kev" wrote in message ups.com... VORs are allowed to get +/- 6 degrees off. [..] http://www.naco.faa.gov/index.asp?xml=naco/faq#q2h "The magnetic variation of the earth changes at a rate of 50.27secondsof arc peryear." That seems a bit low to me. At that rate six degrees of change would take 430 years. Yeah, weird, eh? So I ran across this section of a site explaining that it's often really a lot faster than that (2-25 years per degree). http://www.geocities.com/magnetic_declination/#FACTORS The "Local magnetic anomalies" section mentions the Ramapo area by me. The "Where were/are/will be the magnetic poles? " talks about the movement. And the section about the "reversing Earth" theory is just plain terrifying :-) (Not just reversal of the poles... but the entire crust rotating upside down in a matter of days... ouch!!) Kev |
terrifying :-) (Not just reversal of the poles... but the entire crust rotating upside down in a matter of days... ouch!!) "It must be true - I found it on the internet" Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
On Apr 4, 9:06 am, "Kev" wrote:
On Apr 4, 2:32 am, Tauno Voipio wrote: It's a nuisance for maintenance, but it frees the pilot from calculating the variation at the operative time. Just to off-load the pilot. A good answer. Same for winds in flight, etc. Everything is based on the magnetic to make it easier for the pilot. [..] Oops! I can't believe I wrote that about winds in flight. Of course they're true, so they can be used over a wider area. Winds at the _airport_ are magnetic, is what I meant to say... so the pilot doesn't have to convert while landing. Hmm. So if we switched to true North navigation, then runways would all need repainting... but at least they and the VORs wouldn't have to be changed ever again ;-) Seems like something the government would come up with to save money! Kev |
the pilot from calculating the variation at the operative time. Just to off-load the pilot. A good answer. Same for winds in flight, etc. Everything is based on the magnetic to make it easier for the pilot. [..] Oops! I can't believe I wrote that about winds in flight. Of course they're true, so they can be used over a wider area. Winds at the _airport_ are magnetic, is what I meant to say... so the pilot doesn't have to convert while landing. Hmm. So if we switched to true North navigation, then runways would all need repainting... but at least they and the VORs wouldn't have to be changed ever again ;-) Seems like something the government would come up with to save money! Kev I was wondering whether to mention something about the probable long term causes of drift in variation--and then I finally noticed the smiley. Thanks :-))) Peter |
RANT! | wise purchaser | Owning | 2 | March 27th 07 10:04 PM |
Random thoughts 2 | Bill Daniels | Soaring | 6 | September 1st 06 05:37 AM |
A Jeppesen rant | Peter R. | Piloting | 4 | January 17th 05 03:54 AM |
Why didn't GWB [insert rant] | Jack | Military Aviation | 1 | July 15th 04 11:30 PM |
Random Hold Generator... | Tina Marie | Instrument Flight Rules | 0 | November 5th 03 04:21 PM |
