Mxsmanic wrote:
GPS finds true north. And, just incidentally, you can find true north by looking at the sky. LOL! How do _you_ do that exactly? Cheers |
DR writes:
LOL! How do _you_ do that exactly? I don't. I know the direction of true north at my location, and I don't go anywhere else. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
DR writes: LOL! How do _you_ do that exactly? I don't. I know the direction of true north at my location, and I don't go anywhere else. This is perhaps not only the truth, but the telling story of your problem. You don't go anywhere else. |
Mxsmanic wrote:
writes: A sensor to find true north in an airplane in flight doesn't exist. GPS finds true north. Nope, GPS finds a 3-d position based on the relative distances between sets of satellites in geosynchronous orbit. It knows no more about true north than magnetic without elaborate conversion between where the satellites are at any given instant and where the earth is. And, just incidentally, you can find true north by looking at the sky. ANS will do that, and people can do it, too. Funny, I'm looking at the sky today and all I see are clouds. My compass still works. The isogonic lines on a chart take care of all the problems of where the actual north/south magnetic poles are. Documenting them doesn't really eliminate them. It gives you the tool, just like your beloved GPS knows how to find the real north pole between the combination of the downloaded data on where the satellites are and a substantial amount of information on the shape of the earth inside it's internal database. Unless the airplane is a glider, you have power. You are clueless aren't you. The engine in just about every airplane out there runs just freaking fine without any electrical power consumed nor delivered to the rest of the aircraft. One third correct: it requires power, but engines provide power. It doesn't have to be set up against anything else to find true north. It doesn't need to be constantly updated; the whole idea is to be fairly autonomous. You are clueless. Your GPS is constantly updated or it won't work. You put the thing in a box for a week or so or power it up in an undisclosed location and it will DO NOTHING for you until it downloads enough information to continue. |
Ron Natalie writes:
Nope, GPS finds a 3-d position based on the relative distances between sets of satellites in geosynchronous orbit. Roughly, yes. It knows no more about true north than magnetic without elaborate conversion between where the satellites are at any given instant and where the earth is. With two fixes, it has true north. If it's moving, it has at least two fixes. Funny, I'm looking at the sky today and all I see are clouds. My compass still works. There are lots of places on Earth where your compass won't work, but an ANS will. You are clueless aren't you. The engine in just about every airplane out there runs just freaking fine without any electrical power consumed nor delivered to the rest of the aircraft. Are they all Diesels? -- Transpose mxsmanic and gmail to reach me by e-mail. |
In rec.aviation.piloting Mxsmanic wrote:
Ron Natalie writes: Nope, GPS finds a 3-d position based on the relative distances between sets of satellites in geosynchronous orbit. Roughly, yes. It knows no more about true north than magnetic without elaborate conversion between where the satellites are at any given instant and where the earth is. With two fixes, it has true north. If it's moving, it has at least two fixes. And that tells you your course, not which direction the nose is pointed. There is no GPS instrument available that will tell you which way your nose is pointed. Funny, I'm looking at the sky today and all I see are clouds. My compass still works. There are lots of places on Earth where your compass won't work, but an ANS will. The only two places on Earth a magnetic compass doesn't work in an airplane are over the north and south magnetic poles. You really are ignorant, aren't you? You are clueless aren't you. The engine in just about every airplane out there runs just freaking fine without any electrical power consumed nor delivered to the rest of the aircraft. Are they all Diesels? Good lord. Ignorant doesn't even begin to describe how totally, utterly, and completely clueless you are. Piston engines have magnetos which generate the spark plug firing voltage, and only the spark plug voltage. The engine has no other need for electrical power and doesn't generate electrical power to run things like GPS unless it has a generator or an alternator installed. Many airplanes have neither a generator or an alternator. Turbine engines only require electrical power to start. Once they are running, they are self sustaining. If you are going to be a pretend pilot, at least go learn some basics so you don't look like a complete fool. -- Jim Pennino Remove .spam.sux to reply. |
In rec.aviation.piloting Maxwell wrote:
"Mxsmanic" wrote in message ... writes: And that tells you your course, not which direction the nose is pointed. For navigation, your ground track is more important. There is no GPS instrument available that will tell you which way your nose is pointed. As I've said, you just use two. The only two places on Earth a magnetic compass doesn't work in an airplane are over the north and south magnetic poles. No. There are thousands of local magnetic anomalies that can make a compass useless. Piston engines have magnetos which generate the spark plug firing voltage, and only the spark plug voltage. Last time I checked, sparks counted as electricity. Then hook up a spark plug wire to your GPS. Better to his forehead; electroshock therapy sounds like it is called for in his case. -- Jim Pennino Remove .spam.sux to reply. |
RANT! | wise purchaser | Owning | 2 | March 27th 07 10:04 PM |
Random thoughts 2 | Bill Daniels | Soaring | 6 | September 1st 06 05:37 AM |
A Jeppesen rant | Peter R. | Piloting | 4 | January 17th 05 03:54 AM |
Why didn't GWB [insert rant] | Jack | Military Aviation | 1 | July 15th 04 11:30 PM |
Random Hold Generator... | Tina Marie | Instrument Flight Rules | 0 | November 5th 03 04:21 PM |
