I for one would try to use numbers derived from sound data. My
glider's VNE was derived from something, and it's a number I heed religiously. 2NO |
![]() "Kilo Charlie" wrote in message ... "Gary Nuttall" wrote in message ... And keep a note of how much fuel the tug has on board. How heavy the glider pilot is. How clean the glider wings are. What time of day it was. Outside Air Temperature, pressure and moisture content. Local CAPE and Lifted Index. Length of rope (and its elasticity). Power setting of tug. What mood each of the pilots were in. Stick position on ground run. Local thermal and wave activity. All can have an effect on take-off distance and climb rate. There's so many variables that I'd be dubious of any metrics developed beyond the fact that high altitude, high temperature and heavy gliders do not make a good combination. Anybody who comes up with a set of explicit numbers and sticks to them is likely to discover how often theory doesn't work in practice! Happy soaring Gary Nuttall Continues to amaze me at how much disdain glider pilots have for quantitation. I suppose that may be what draws some of them into the soaring in the first place. I also enjoy that aspect but think that attitude has gotten many powered pilots into bad situations. To think that we are immune to it because we don't have engines is naive. Casey I agree, Casy It would be a big safety factor if we had takeoff performance charts available. I've been involved in some extremely hazardous high density altitude takeoffs where the tug was unable to provide adequate climb performance. Having enough information to decline the tow might save a few lives. It seems like a major safety oversight that we don't have hard information on this. If the STC for a tow hook doesn't require new performance charts, it should. The glider tow chart should add glider gross weight and L/D to the tugs TO performance chart and make 300FPM the minimum acceptable climb rate. I have flown light airplanes in the high and hot western US all my life and ALWAYS looked at the performance chart before takeoff. Many who didn't left crumpled aluminum on mountainsides. I think charts would have to be developed empirically from tests on a specific tug but once there were a few data points, interpolation should be possible. I also agree with the poster who selects a go-no-go point on the runway for release if not airborne. Keep in mind that gliders have a high L/D in ground effect and usually poor wheel brakes so leave a generous safety margin for getting stopped after an aborted TO. Bill Daniels |
Also remember that density altitude will affect your height for a 180
back to runway. i.e. two large men in a Grob, field elevation 3,700 ft msl, air temp 107F, rope break at 220 ft above field. It was not enough altitude for at least one such senario. They plowed into trees short of the runway. Wayne Walker |
FreeFlight107 wrote:
Also remember that density altitude will affect your height for a 180 back to runway. i.e. two large men in a Grob, field elevation 3,700 ft msl, air temp 107F, rope break at 220 ft above field. It was not enough altitude for at least one such senario. They plowed into trees short of the runway... ....having executed the 180 degree turn immediately, with optimum bank, g-load, and airspeed control -- as always? Do you have enough information to make that claim, that it was simply a matter of density altitude? If you do, then perhaps we, or at least you, already have all the metrics that are needed. Perhaps you can share them with us, for future use? Jack |
On Apr 13, 11:00 am, "Bill Daniels" bildan@comcast-dot-net wrote:
snip If the STC for a tow hook doesn't require new performance charts, it should. I don't believe that there would ever be another tow hook approved in the US, if this was required by the FAA. The amount of testing and analysis that would be required would break any club's budget. I think charts would have to be developed empirically from tests on a specific tug but once there were a few data points, interpolation should be possible. Interpolation (between data points ) or extrapolation (beyond the data set ) ? Interpolation to a different tug ? or to a different glider ? You might be able to extrapolate to different gliders, but different tugs could be vastly different, even if they were similar in major specifications ( ie same horsepower, weight and wing loading). A different prop size or having a constant speed prop would make a great difference, for example. If I had a specific tug in mind, I might come up with different tables for single seat glass (with and without water), 2 seat glass and 2 seat trainer. But I think it would take many-many flights to gather the data. Todd Smith 3S |
All airplanes already have performance charts in the POH. These charts
aren't custom developed for each serial number but for the test airplane and copys provided for all identical production airplanes. If the airplane is subsequently modified with a different engine or prop, modified performance charts are always required as part of the STC. Tugs are no different. For a tug, all that's needed is additional inputs for glider weight and L/D (Both highly quantifiable). With these data, the tow combinations takeoff distance and rate of climb can be accurately predicted. It's a bit of work to develop these performance charts but the payoff is saved lives and tugs. I can't see a rational reason not to do it. It's a responsible thing to do. I've developed expanded charts for airplanes I've owned. Piper, for example, seems to think nobody flies their singles above 6000 feet since no data are provided above that altitude. I extended my ROC charts to 18,000 feet by noting the performance over a dozen flight or so. I also noted the takeoff distances on each takeoff and added that to the charts. For a tug, all you have to do is keep notes on each tows performance and plot the date later. Soon you have the needed chart. Bill Daniels "toad" wrote in message oups.com... On Apr 13, 11:00 am, "Bill Daniels" bildan@comcast-dot-net wrote: snip If the STC for a tow hook doesn't require new performance charts, it should. I don't believe that there would ever be another tow hook approved in the US, if this was required by the FAA. The amount of testing and analysis that would be required would break any club's budget. I think charts would have to be developed empirically from tests on a specific tug but once there were a few data points, interpolation should be possible. Interpolation (between data points ) or extrapolation (beyond the data set ) ? Interpolation to a different tug ? or to a different glider ? You might be able to extrapolate to different gliders, but different tugs could be vastly different, even if they were similar in major specifications ( ie same horsepower, weight and wing loading). A different prop size or having a constant speed prop would make a great difference, for example. If I had a specific tug in mind, I might come up with different tables for single seat glass (with and without water), 2 seat glass and 2 seat trainer. But I think it would take many-many flights to gather the data. Todd Smith 3S |
On Apr 13, 10:32 am, "Kilo Charlie" wrote:
Continues to amaze me at how much disdain glider pilots have for quantitation. I suppose that may be what draws some of them into the soaring in the first place. Well, there's not much in glider flying that CAN be quantified with any confidence. For example, you can quantify your still air L/D, but on final glide, you have to estimate the lift/sink potential and that is qualitative estimation (inspired guesswork). Todd Smith 3S |
Not as much as it disturbs me that there might be people
out there who will stake their lives against a set of numbers in a book. The margins of safety are so much tighter in a glider/sailplane than a powered aircraft and a minor change in any one part of the equation could have dramatic results. Let's be clear here.....Some numbers you can be confident in becuase they've been measured in a certain, calibrated and controlled environment and as such I 'trust' them - e.g. VNE/VDF are tested in still air with a new airframe. Even then, I'm not going to fly right up to the limits! The problem I have with calculating a takeoff run is that there are just so many variables involved that you cannot consistently and safely rely on the results. As Todd's post suggests, work out a go/no go point and if you're not airborne, release. As a glider pilot I act within both my and the glider's limits. I trust my instincts that if something doesn't feel right, I abandon the launch while it's still safe to do so. Maybe it's a US vs UK thing but here in the UK we take personal responsibility for our actions. If you're not sure that you have sufficient distance to take-off then why would you trust a set of numbers that say otherwise ? I think the concept of calculating takeoff runs is actually quite interesting but the sheer number of variables involved make it an impracticable exercise. Gary At 14:36 13 April 2007, Kilo Charlie wrote: 'Gary Nuttall' wrote in message ... And keep a note of how much fuel the tug has on board. How heavy the glider pilot is. How clean the glider wings are. What time of day it was. Outside Air Temperature, pressure and moisture content. Local CAPE and Lifted Index. Length of rope (and its elasticity). Power setting of tug. What mood each of the pilots were in. Stick position on ground run. Local thermal and wave activity. All can have an effect on take-off distance and climb rate. There's so many variables that I'd be dubious of any metrics developed beyond the fact that high altitude, high temperature and heavy gliders do not make a good combination. Anybody who comes up with a set of explicit numbers and sticks to them is likely to discover how often theory doesn't work in practice! Happy soaring Gary Nuttall Continues to amaze me at how much disdain glider pilots have for quantitation. I suppose that may be what draws some of them into the soaring in the first place. I also enjoy that aspect but think that attitude has gotten many powered pilots into bad situations. To think that we are immune to it because we don't have engines is naive. Casey |
On Apr 13, 2:09 pm, Gary Nuttall
wrote: Not as much as it disturbs me that there might be people out there who will stake their lives against a set of numbers in a book. The margins of safety are so much tighter in a glider/sailplane than a powered aircraft and a minor change in any one part of the equation could have dramatic results. Let's be clear here.....Some numbers you can be confident in becuase they've been measured in a certain, calibrated and controlled environment and as such I 'trust' them - e.g. VNE/VDF are tested in still air with a new airframe. Even then, I'm not going to fly right up to the limits! The problem I have with calculating a takeoff run is that there are just so many variables involved that you cannot consistently and safely rely on the results. As Todd's post suggests, work out a go/no go point and if you're not airborne, release. As a glider pilot I act within both my and the glider's limits. I trust my instincts that if something doesn't feel right, I abandon the launch while it's still safe to do so. Maybe it's a US vs UK thing but here in the UK we take personal responsibility for our actions. If you're not sure that you have sufficient distance to take-off then why would you trust a set of numbers that say otherwise ? I think the concept of calculating takeoff runs is actually quite interesting but the sheer number of variables involved make it an impracticable exercise. Gary At 14:36 13 April 2007, Kilo Charlie wrote: 'Gary Nuttall' wrote in message ... And keep a note of how much fuel the tug has on board. How heavy the glider pilot is. How clean the glider wings are. What time of day it was. Outside Air Temperature, pressure and moisture content. Local CAPE and Lifted Index. Length of rope (and its elasticity). Power setting of tug. What mood each of the pilots were in. Stick position on ground run. Local thermal and wave activity. All can have an effect on take-off distance and climb rate. There's so many variables that I'd be dubious of any metrics developed beyond the fact that high altitude, high temperature and heavy gliders do not make a good combination. Anybody who comes up with a set of explicit numbers and sticks to them is likely to discover how often theory doesn't work in practice! Happy soaring Gary Nuttall Continues to amaze me at how much disdain glider pilots have for quantitation. I suppose that may be what draws some of them into the soaring in the first place. I also enjoy that aspect but think that attitude has gotten many powered pilots into bad situations. To think that we are immune to it because we don't have engines is naive. Casey- Hide quoted text - - Show quoted text - The process of acquiring and analyzing the data will establish if it is reliable or not. If it is not reliable there will be a large scatter for the same set of conditions. The fundamental set of parameters include, but are not limited to: 1. Tow plane POH take-off distance (this takes into account density altitude and type of runway) 2. Glider total weight 3. Glider L/D 4. Wind All of the other things mentioned are very minor compared to the above factors, and will be represented as a scatter in the predicted take- off distance. This can be accounted for with a safety margin, which MUST be added to any POH calculation anyway. Exactly what are you proposing as an alternative, launching without regard to available data? This task is not on the level of a molecular chemical reaction dynamics calculation. Personally, I would feel much more comfortable having the data if I were the one being towed. If someone will collect the data I would be happy to help them analyze it, something I do for a living. Tom |
![]() "Gary Nuttall" wrote in message ... Not as much as it disturbs me that there might be people out there who will stake their lives against a set of numbers in a book. The margins of safety are so much tighter in a glider/sailplane than a powered aircraft and a minor change in any one part of the equation could have dramatic results. Let's be clear here.....Some numbers you can be confident in becuase they've been measured in a certain, calibrated and controlled environment and as such I 'trust' them - e.g. VNE/VDF are tested in still air with a new airframe. Even then, I'm not going to fly right up to the limits! The problem I have with calculating a takeoff run is that there are just so many variables involved that you cannot consistently and safely rely on the results. As Todd's post suggests, work out a go/no go point and if you're not airborne, release. As a glider pilot I act within both my and the glider's limits. I trust my instincts that if something doesn't feel right, I abandon the launch while it's still safe to do so. Maybe it's a US vs UK thing but here in the UK we take personal responsibility for our actions. If you're not sure that you have sufficient distance to take-off then why would you trust a set of numbers that say otherwise ? I think the concept of calculating takeoff runs is actually quite interesting but the sheer number of variables involved make it an impracticable exercise. Gary Wow....I certainly didn't think that this question would degenerate into a US bashing exercise but ya just never know on ras! You clearly have a bug up your patoot re quantitation Gary. I think that Bill, Tuno and I are on the same page though. I would challenge Gary's remark that "The margins of safety are so much tighter in a glider/sailplane than a powered aircraft". In fact I think that the opposite is true but then that is for another discussion. I'll only say that the glider on tow is always in better shape than the towplane if the engine quits. Nowhere did I say that this is a matter of inches and would choose to "push to the limits" based upon an equation without the usual margin of safety added to it. Currently we have no place to begin the discussion based upon facts so that is what I'd like to see happen. And also who said anything about the FAA getting involved??? Whether any of you like to admit it or not you are all using data on each glider flight....esp if you go XC. If L/D is worthless then why not try to make that field far off in the distance in your 1-26? So I would surmise that some of you would choose to head up to a high altitude site on a hot day, take a tow then while rolling make a decision as to whether you feel safe continuing. That would seem like a big waste of time to me. And Gary.....I love you guys in the UK......great sense of humor, great beers and some awesome racing pilots......but lets face it......you ain't got no high altitude soaring sites....at least not in Great Britain. ;-) Cheers, Casey Lenox KC Phoenix |
measuring arm distances | Heino & Deanne Weisberg | Home Built | 1 | October 21st 05 05:49 PM |
Stuck at work--need takeoff/landing distances for a 172 please | Yossarian | Piloting | 12 | July 14th 05 01:12 PM |
Edge distances in steel | Ed Wischmeyer | Home Built | 3 | August 24th 04 10:53 PM |
Are sectional paths correct across "long" distances? | vincent p. norris | General Aviation | 32 | March 25th 04 02:32 PM |
Are sectional paths correct across "long" distances? | vincent p. norris | Piloting | 36 | March 25th 04 02:32 PM |
