Takeoff distances
Old April 14th 07, 02:02 AM posted to rec.aviation.soaring
Default Takeoff distances
Hmmmm,
I don't see consulting charts as the solution...rather just another
data point. I choose to fly where most days the density altitude at
launch is somewhere between 10k'-12k'(Salida, Buena Vista, Leadville,
Telluride). I have never considered constructing a graph....not that
it might not help. I try to launch by 11am, downhill if possible, no
water if behind a Cub, plenty of water if behind a 260Pawnee, no mid
afternoon launches into strong thermal conditions. I like at least
7500' of runway. Pawnees are not great climbers at 70 knots, and I
have done my share of fence inspection tours grinding around low. I
accept the risk/reward by refusing to fly with water if I have any
doubts...and just a couple of degrees of temperature can make a huge
difference IMVHO.
Having flown in these conditions for the last 9 years, piloting and
fuel load affect the safety of the launch as much as POH climb
prediction. Ever towed behind a pilot who had not set the fuel
mixture correctly? Or did not stay down in ground effect to
accelerate? Or with a big guy at the stick who just topped off the
tanks?
I would be curious what the predicted climb rate for the Cessna
150/180 based at Telluride would be on a hot day...not sure I really
would want to know
Old April 14th 07, 02:59 AM posted to rec.aviation.soaring
Bill Daniels
Stu has a lot of experience flying in the colorado high country so I respect
his views. However. I'd like to make a few comments below.
Hmmmm,
difference IMVHO.
All reasonable precautions.
tanks?
Unfortunately, I have seen all this happen - it is the mark of a very poor
pilot. I try not to get to know them since I don't want to be invited to
their funeral.
ANY properly trained airplane pilot knows how to use takeoff charts which
includes knowing the takeoff weight including fuel and pilot weights as well
as density altitude and wind. Adding glider weight and L/D doesn't add that
much work. Properly done, the results will be very accurate. I've never
seen actual takeoff performance differ from the POH by more than 5% - most
often it's dead on.
Pilots of airplanes with fixed pitch propellers can set the mixture simply
by adjusting for max RPM. This is, by definition, max power which is about
100 degrees rich of peak EGT. You can't hurt an engine at high density
altitudes doing this so set it for max power for every takeoff. If you can
hold constant airspeed, this works while climbing too so max power can be
maintained througout the climb.
would want to know
Actually, I would want to know so I can exercise my PIC and perhaps decline
the tow if I deem the performance too low.
Bill Daniels
Old April 14th 07, 03:04 AM posted to rec.aviation.soaring
Eric Greenwell
Gary Nuttall wrote:
As a glider pilot I act within both my and the glider's
limits. I trust my instincts that if something doesn't
feel right, I abandon the launch while it's still safe
to do so. Maybe it's a US vs UK thing
Very likely - how often does a pilot in the UK have to decide if an
airport at a 10,000 foot density altitude that has never seen a towplane
is safe to use? Here in the USA, I"ll bet we have this problem much more
frequently.
but here in
the UK we take personal responsibility for our actions.
I think it's the same here, too. After all, the tow can go bad for
several reasons besides a high density altitude tow at an airport that's
never been used for towing! And, of course, it's not dependent only on
the glider pilot: the towpilot should notice HE'S not off the ground
early enough, and let the glider go so the towplane pilot can deal with
the towplane's problem. In fact, the combination can still be in trouble
even if the glider has taken off "in time", because the critical element
is the towplane taking off in time. It's hard for the glider pilot to
assess this.
What I think Kilo Charlie and the others are trying to determine is if
it's even worth taking a towplane to this potential site. Without
experience at a similar site, looking for pertinent numbers seems like a
better idea than just showing up and trying it.
If you're not sure that you have sufficient distance
to take-off then why would you trust a set of numbers
that say otherwise?
Perhaps because you've verified the table or equation in other
situations, and added a margin for safety, and because you are using a
towplane, towplane pilot, and glider pilot you trust to handle the
situation, even if things go wrong.
I think the concept of calculating
takeoff runs is actually quite interesting but the
sheer number of variables involved make it an impracticable
exercise.
Nonsense. You aren't trying to precisely determine takeoff runs, but
decide if the situation is "safe enough". They know how the towplane
operates compared to it's POH values, and the addition of the glider can
be calculated (it's just drag and weight, not a huge number of
variables), so a sensible estimate can be determined.
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
Old April 16th 07, 04:07 PM posted to rec.aviation.soaring
Andy[_1_]
if
a
No, ASA has flown at the site (Clark Memorial, Williams, AZ ) before
but for our next contest there the organizers have decided that water
ballast will not be allowed. Some members have questioned that rule
on the basis that some pilots used water ballast last time they were
there and thought the risk was acceptable.
I think limiting the discussion to takeoff distance misses the point.
I like to know if I can expect a climb rate that will allow me to
return to the airport, or other known safe landing area, from any
point in the tow.
Andy
Old April 16th 07, 04:32 PM posted to rec.aviation.soaring
Jack
point in the tow.
This sounds to me like an absolutely essential point for a safe
operation anywhere, anytime.
Jack
Old April 16th 07, 05:25 PM posted to rec.aviation.soaring
Bert Willing
Then you probably don't want to fly out of quite a number of places in
Europe :-(
"Jack" wrote in message
et...
point in the tow.
This sounds to me like an absolutely essential point for a safe operation
anywhere, anytime.
Jack
Old April 17th 07, 04:17 AM posted to rec.aviation.soaring
Kilo Charlie
"Andy" wrote in message
if
a
point in the tow.
Andy
Eric has hit it on the head. Andy is a very knowlegable pilot but at least
last year did not fly out of Williams in his glider (he came to visit in his
airplane with a broken arm) just as a matter of full disclosure which seems
to be where he was attempting to head.
I honestly don't care which parameter you choose.....takeoff distance, climb
rate, etc. I would think that it all will have a decent correlation wrt
density altitude.....but then I'm just a stupid doctor and not an engineer
like Andy.
We have NO airports with safe bailout fields anymore....not that we ever did
but Turf had a potential spot at least. So its a totally moot point re
that. I have towed at gross weight out of Ely (6200'), Parowan (5900') and
Moriarty (6200') and yes the takeoff rolls were long and the climb rates
were low but by the end of the runway or just beyond was at 200 feet and the
experienced tow pilots did a slow low bank turn back over the airport until
we were at a high enough altitude to look for lift elsewhere. I never felt
that my life was in more danger there than on a 110 degree day at 2000'
towing uphill with no wind at El Tiro which we do all of the time. The ASA
is also now towing out of a 3900' length runway uphill on the lee side of
some hills. So where do we draw the line?
So I do think that Eric is correct in that I do wish to have the best
numbers we can generate wrt takeoff distances (or climb rate!) so that we
have a starting point to evaluate a go, no-go situation whether it be
heading to a high site on a very hot AZ weekend or whether or how much water
we may put in.
The data would be helpful....period. If the naysayers wish to ignore that
its their choice. I for one believe my POH and along with some common sense
will be following it for my Columbia on hot days and would like to be able
to use it for my LS-8/Pawnee combo too.
Casey
Old April 14th 07, 09:47 PM posted to rec.aviation.soaring
Gary Nuttall
My concern was based on the principle that somebody
was developing an 'absolute' model which was based
on a limited number of parameters without considering
the wide range of factors that influencing launch distances
and climb rates.
If you're simply trying to establish a guideline of
height vs density vs temperature vs wind strength/direction
vs glider performance vs tug power to develop a minimum
runway length required, then fair enough - andI agree
that high temp and high altitiude is something that
we don't have an issue with in the UK. Nonetheless
we do have situations where runway length, tug power
and weight of glider are sometimes at a limit that
needs to be considered by the tug and glider pilot.
This comes down to a simple calculation.....if in
doubt, don't!
Gary
safe
to decide if an
is safe to use? Here in the USA, I'll bet we have this
problem much more
frequently.
but here in
can go bad for
dependent only on
off the ground
pilot can deal with
still be in trouble
even if the glider has taken off 'in time', because
glider pilot to
assess this.
to determine is if
site. Without
that say otherwise?
in other
you are using a
to handle the
exercise.
takeoff runs, but
decide if the situation is 'safe enough'. They know
how the towplane
of the glider can
number of
* Change 'netto' to 'net' to email me directly
* 'Transponders in Sailplanes' http://tinyurl.com/y739x4
* 'A Guide to Self-launching Sailplane Operation' at
www.motorglider.org
Old April 15th 07, 12:05 AM posted to rec.aviation.soaring
And don't forget to pump up those tires on the tug and glider.....
Old April 18th 07, 08:43 PM posted to rec.aviation.soaring
Mike the Strike
Casey started this thread in response to the decision of the ASA
Contest Committee to disallow the use of water ballast at the field
discussed above for competitors in a club contest. I am one of the
three ASA Contest Committee members who reached this unanimous vote.
Our decision was based mostly on safety issues (a towplane will
produce only about half the thrust at a density altitude of 10,000
feet compared to standard sea level) and at last year's event there
were several tows that pilots there described as "scary". Although
the majority of our experienced pilots could probably launch safely,
we do have a number of newcomers racing with us. We will also only
have one towplane, so the turn-around time will also be shortened by
restricting take-off mass. Water is also not available on airport, so
will have to be brought in by contestants.
Based on these factors, the decision seemed a no-brainer to me, but a
couple of pilots accused us of being over-protective and demanded the
right to determine the risk for themselves.
It is indisputable that take-off runs will be longer and rates of
climb slower at this site, but the controversy seems to have been
whether or not the Committee was too conservative in introducing this
rule (accusations of "nannying" were flying on the ASA web site!).
In mediation, I have suggested that we ask the tow pilot in question
(an excellent and very experienced one) for his take on the problem,
but I doubt that we will change our opinion.
Mike
measuring arm distances Heino & Deanne Weisberg Home Built 1 October 21st 05 05:49 PM
Stuck at work--need takeoff/landing distances for a 172 please Yossarian Piloting 12 July 14th 05 01:12 PM
Edge distances in steel Ed Wischmeyer Home Built 3 August 24th 04 10:53 PM
Are sectional paths correct across "long" distances? vincent p. norris General Aviation 32 March 25th 04 02:32 PM
Are sectional paths correct across "long" distances? vincent p. norris Piloting 36 March 25th 04 02:32 PM
