Our decision was based mostly on safety issues (a towplane will produce only about half the thrust at a density altitude of 10,000 feet compared to standard sea level) and at last year's event there were several tows that pilots there described as "scary". Although the majority of our experienced pilots could probably launch safely, we do have a number of newcomers racing with us. We will also only have one towplane, so the turn-around time will also be shortened by restricting take-off mass. Water is also not available on airport, so will have to be brought in by contestants. Based on these factors, the decision seemed a no-brainer to me, but a couple of pilots accused us of being over-protective and demanded the right to determine the risk for themselves. It seems only right that the organizers took the prudent course. With a single tug to protect, and an experienced tow pilot to make the unilateral final decision, there won't be any meaningful argument. Truly, I find that most glider pilots won't bother to actually "figure things out", unless the soaring weather is garbage and they want entertainment while swilling beverages. So, since our weather was chilly and vile today, I figured I would toss ras the only published reference of which I am aware on the topic. http://www.eaa1000.av.org/technicl/takeoff/topaper.htm It's been on the web for awhile. Don't know why it wasn't found by the many contributors to this thread. Despite all the pretty equations, they ended up by saying they didn't have enough consistent data, and that changes in weight and wind made a pot load of difference. Duh. Any time it feels hinky .... fly dry, or find a longer, lower runway. Racing be stuffed. I'd rather have my friends around for another season. Cindy B |
"CindyB" wrote in message ups.com... contributors to this thread. Despite all the pretty equations, they ended up by saying they didn't have enough consistent data, and that changes in weight and wind made a pot load of difference. Duh. Any time it feels hinky .... fly dry, or find a longer, lower runway. Racing be stuffed. I'd rather have my friends around for another season. Cindy B Thanks for this link Cindy.....it does appear to be the only study available to try to answer this question. Your conclusions are, as we say in the scientific field, not supported by the data however. I didn't see this on a google search prior to posting this question but maybe you're a more experienced "googler" than I. First of all re the weight....this is a quote from the study: "The lines in Figure 11 seem to imply that the takeoff ground roll data were not a function of weight, which is an absurd conclusion. This conclusion further points to the danger of quick conclusions from data with lots of scatter." So this would mean that the data are suspect to begin with.....large amount of scatter and not enough points to be able to make firm conclusions. Re the wind this is another quote from the study: "These lines should not be given a lot of weight, given the poor correlation shown in Table 2." Again not a reliable set of data. Having said this I may just have to agree with the post that said that there are too many variables to be able to make firm conclusions other than to rely upon experience. Too bad but thanks again for the article! So how about some of those high density altitude pilots out there....any "scary" tows? Do folks that routinely fly out of high DA fields always tow dry? What kind of towplanes are being used? Casey |
| measuring arm distances | Heino & Deanne Weisberg | Home Built | 1 | October 21st 05 06:49 PM |
| Stuck at work--need takeoff/landing distances for a 172 please | Yossarian | Piloting | 12 | July 14th 05 02:12 PM |
| Edge distances in steel | Ed Wischmeyer | Home Built | 3 | August 24th 04 11:53 PM |
| Are sectional paths correct across "long" distances? | vincent p. norris | General Aviation | 32 | March 25th 04 03:32 PM |
| Are sectional paths correct across "long" distances? | vincent p. norris | Piloting | 36 | March 25th 04 03:32 PM |
