So There I Was...
Old April 11th 07, 02:57 PM posted to rec.aviation.piloting
Jules
Default So There I Was...
Well don't feel bad, he was being an idiot. He thinks he can do that
because he is watching traffic on his tcas. He is just assuming
everybody has a working transponder. If he is such a good pilot he can
try joining the vfr circuit.
If you mentioned a nordo plane, that would get his attention.
Good thing you spoke up.
Kyle Boatright wrote:
...on my first post-engine inspection flight. The plan was to stay within
gliding distance of the field, "just in case", so I launched, made a wide
circle of the field, while climbing to 3,000' AGL. When on what was more or
less an extended crosswind, I made a descending 135 degree left turn and
called "Cartersville traffic, Experimental NXXX 2 miles southeast, inbound
on the 45 into the downwind for 19" (or something like that).
And the guy who'd been giving position reports from a different zip code
"NXXYY 30 miles North, inbound" responds on the radio and says "NXXYY is on
a 9 mile straight in, doing 180 knots". I look down and am clipping along
at 170 knots and am a mile from entering the downwind. That's very fast for
me in that relative position to the field, but I was dumping the altitude
I'd held in reserve since it was a post-maintenance flight. As I turn
downwind and announce, a C-172, which I know to be an instructor with
several students announces that he's departing and dawdles onto the runway.
So I extend for spacing from him and call my base turn.
Of course, the guy who was on the 180 knot straight in comes back with "You
understand there is an aircraft on short final"... I'd been looking for him,
and there he was, above my visual horizon, and on the other side of the 300'
hills that are a couple of miles North of the field. So I say "Yep", turn
final, and as I'm crossing the threshold, he announces "Meridian NXXYY is
going around".
Which leads to the age old question... Was there a better approach I should
have taken? My sense is that per the FAR's (altitude being the key factor),
I had precedence for landing. Also, my sense is that he was the one who was
smoking along all the way to short final and he could have meshed with the
existing traffic (me) if he'd pulled the throttle back a bit. Instead, he
probably burned an extra 5 gallons of Jet A on his go-around...
Yeah, I know... I'm hard headed too, but I don't see where flying a faster
airplane and calling a long, long, straight in approach means the other
aircraft in and around the field need to defer to you... Heck, my airplane
is faster than 90% of the GA fleet, and I'd never do that intentionally.
Oh, yeah. The post-maintenance flight went well. I had a surprising
experience once and that has made me pretty cautious on post-maintenance
flights.
KB
Old April 11th 07, 04:36 PM posted to rec.aviation.piloting
Jay Honeck
At this point did you know he was a Meridian?
If so, I'm with you. That guy can fly a 90 knot final, so for him to
be calling out a final approach at 180 knots is just absurd.
If, on the other hand, you didn't know what type of airplane it was
(and your narrative, above, doesn't specify) I'd have extended my
downwind. Just in case it was a Gulfstream or some other fast jet.
Either way, the other guy was wrong, and you were right. But there's
"right", and then there's "dead right"....
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old April 11th 07, 11:12 PM posted to rec.aviation.piloting
Kyle Boatright
"Jay Honeck" wrote in message
on
No, I didn't. I actually *thought* he was a Bonanza because of
transmissions from a nearby field. I'm not sure, but he may not have
mentioned his aircraft type until the go-around.
Ain't that the truth.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old April 12th 07, 04:25 PM posted to rec.aviation.piloting
bdl
Similar experience at my home field (1H0), im on a left downwind,
there's another guy rolling down 34. I turn base, and just catch a
flicker of something out of my peripheral vision. I look to the right
and there is a small white jet on a long final (probably 5-6 miles).
A half second later comes the call, "Beechjet final straight in 34".
It's obvious from his tone that STL Approach just dropped him off to
the CTAF frequency. I make a call telling him where I am, and that I
would be abort my landing and instead side step to the upwind and go-
around. He landed behind me.
So I went around again, taxied in, put the bird away in the hangar,
and then while driving back, drive over to give the guy a wave. He
thanked me several times over for not making him go around, we
exchanged some discussion about how approach can sometmies do that to
you, etc. All in all a nice experience.
I figured he's probably a transient, and being a jet, its harder for
him to go around than me (especially in the tight class B airspace
confines around 1H0. Plus he's burning more $$$'s per minute than I
am.
So for the $3 it cost me to go around, I hoped I spread some goodwill
and made the pilot feel better about visiting 1H0 (instead of the
pricier SUS).
'Course what I really wanted was a tour of the plane, but he was
loading up the rental car by the time we were talking and the plane
was already buttoned up.
As an aside, anybody ever build 2 push to talk's in their aircraft
yokes (experimental or otherwise) I don't know how many times I'd
love to have a second PTT to talk on COM2 while im monitoring both
frequencies. Without having to turn the "transmit" dial on my
intercom.
On GPS practice appraoches into uncontrolled fields I usually make a
call or two as im navigating the approach (without being with
approach) just to let other airplanes in the area know im out there.
It would be helpful to do this on actual IFR approaches into
uncontrolled fields.
I would think it would be a function of the intercom system more than
anything else. Anybody ever done it? Seems like it would be a neat
thing for the experimental crowd.
Brian
Old April 13th 07, 05:16 AM posted to rec.aviation.piloting
Dave[_5_]
There are those among us who seem to think that they somehow have
priority over other traffic. I have noticed that those who drive
bigger/faster airplanes tend to have such an attitude. However, they
are not the only ones. An incident that I found particularly
irritating was to have a yo yo decide to shoot a practice IFR approach
(downwind) on a busy Saturday morning.
There was an announcement - but it was delivered so fast as to be
unintelligible. Of course it ended in a missed approach - but it sure
messed up the flow of traffic for a few minutes. There is nothing
wrong with straight in approaches - provided that
they do not interfere with the current flow of traffic (if any).
Personally, I only do it when there is no other traffic.
David Johnson
