Bad landings
Old April 12th 07, 12:39 AM posted to rec.aviation.piloting
EridanMan
Default Bad landings
When the aircraft's attitude
is nose-high, after the slip into the cross wind on approach must
necessarily be terminated for fear of dragging a wing on the ground,
the pilot has no good means of controlling lateral drift. If the
wheels can be planted on the runway before sufficient lateral velocity
and its inertia mount to unacceptable magnitude, all is well.
Purely sophomoric quip, it strikes me that any crosswind landing
attempt where the crosswind is so strong that the aircraft risks a
wing-strike would already be far beyond the capacity of the rudder to
maintain the slip (and WAY beyond the aircraft's demonstrated X-wind
component).
It is of course always possible that a gusty crosswind might 'send the
plane over the edge' at the worse possible moment... but then I would
question the judgement of the pilot to even think of getting so close
to the ground in a drag-heavy deep slip configuration... The
windshear risk alone would make that a dangerous proposition.
The situation you describe strikes me as being a very clear diversion
scenario. In the absence of that option, my instructor suggested that
(at least in my stout-legged PA-28) in an emergency, during a heavy,
gusty crosswind beyond the aircraft's rudder capacity, your best bet
is simply to go with the "crab-plant' approach, and associated repair
bills.
I in no way vouch for this approach, I'm just relaying what I was told.
Old April 13th 07, 12:23 AM posted to rec.aviation.piloting
JGalban via AviationKB.com
bills.
That's probably a good thing, because the bills associated with such an
approach could very well be a large part of the aircraft's total value. The
PA-28 may have stout legs, but they are not designed to handle a large
sideloads. I have seen this attempted in another stout legged Piper and the
result was a main gear leg that departed and ripped off the horizontal
stabilzer on it's way.
Even Cessnas, with their sturdier spring steel gear, can get in trouble
with sideloads on the main gear. Go to this page and scroll to the bottom
for an illustration:
http://members.cox.net/jgalban/id60.htm
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200704/1
Old April 13th 07, 12:29 AM posted to rec.aviation.piloting
Hehe, please note I said 'exhausted all other options', as in, your
out of fuel and you need to get on the ground now, this runway, this
attempt
In that case, the associated repairs bills of ripping the gear off but
almost assuredly living are a probably a better bet than trying some
uber-crosswind landing, and either stalling out due to windshear, wing
striking, or otherwise loosing control on short final. At least
planting in a crab, you're on the ground when the **** hits the fan
Old April 13th 07, 12:30 AM posted to rec.aviation.piloting
EridanMan
Whoops, wrong account - the above was me.
Old April 13th 07, 05:09 PM posted to rec.aviation.piloting
Tri-Pacer
") in an emergency, during a heavy,
bills.
Lots of people bad mouth the Ercoupe as a sissy airplane. Yet it is landed
in a crab. Makes any crosswind landing a no brainer. I owned one for a
number of years and only checked the windsock to make sure I wasn't landing
against the traffic flow. :-)
Now I have to check the wind sock again.
Cheers:
Paul
N1431A
Old April 13th 07, 06:46 PM posted to rec.aviation.piloting
Morgans[_2_]
landing against the traffic flow. :-)
Does the main gear caster on those? I think I heard that it does, but I
have no confirmation of that.
Jim in NC
Old April 12th 07, 06:49 PM posted to rec.aviation.piloting
Gregg Germain
Jim Jones wrote:
I went up today to practice crosswind landings. The wind was about down
runway at my home airport so I went to Sky Manor (N40). This airport has
a
2500x50 foot runway and requires vigilence in gusty winds. I did 2
landings and 1 go around (due to the gusty wind) using runway 25 at Sky
Manor with a
90 degree crosswind of about 12-15 knots gusting to about 18-20kt. The
landings here were pretty good.
What aircraft were you flying? What is its max crosswind component?
Congratulations on taking on crosswinds for practice; on handling the scary
situation back home. Well done.
++NEW++3 DVD SET 'ON LANDINGS' +Much More Pilot Publications Products 0 June 26th 04 03:42 PM
++NEW++3 DVD SET 'ON LANDINGS' +Much More Pilot Publications General Aviation 0 June 26th 04 03:42 PM
++NEW++3 DVD SET 'ON LANDINGS' +Much More Pilot Publications Aviation Marketplace 0 June 26th 04 03:42 PM
Night landings vs. day landings Gerald Sylvester Piloting 15 February 12th 04 06:38 AM
off airport landings Stan Gosnell Rotorcraft 8 September 13th 03 04:49 PM
