Actually, he doesn't.
mike "rq3" wrote in message . net... Anthony, you've got the issue of compressibility precisely backwards. No surprise. Rip |
Tom L. writes:
The big question is "why does the wake turbulence descend?" Because it's the downwash from the aircraft's wings. Aircraft stay in the air by pushing air downward. As the wings pass through still air, they twist the air downward as they pass. The force required to do this engenders an equal and opposite force that raises the wings--lift, in other words. No downwash = no lift. Turbulence is mostly from wingtip vortices. The vortices exist because air is twisting over to the top of the wings from the bottom. The vortices are necessary in order to accommodate the swath of downwash behind the aircraft, which is descending in relation to the still air on either side of the aircraft's path. Is the air volume inside the vortices denser than surrounding air? Density has nothing to do with it. The air has been pushed downward by the wings. Probably not. So the descent is probably not due to gravitational force. No, it's not gravity. The air descends because the wings pushed it down. I am no expert on fluid dynamics and have no access to texts that answer the question (if there are any), but figure 7-3-5 in AIM is interesting - it shows a wake sinking at several hundred fpm immediately after an aircraft, but than stabilizing at several hunderd feet below the flightpath, i.e. no further sink. This might indicate that the sink is due to wing downwash. It is. If that is the case, than 1. Wake turbulence in steep turns will not move just downward, but down and out, that is: opposite lift. Yes. 2. The speed at which it moves will depend on downwash - it's speed, intensity, strength (?) I don't know which term would be appropriate here. Whatever it is, it might be much smaller for GA aircraft than for large aircraft. The product of air mass times downwash acceleration has to be the same as the product of aircraft weight times gravity. So a larger and heavier aircraft produces a larger downwash, albeit not necessarily a faster one. -- Transpose mxsmanic and gmail to reach me by e-mail. |
On Apr 16, 3:59 pm, Tom L. wrote:
The big question is "why does the wake turbulence descend?" Is the air volume inside the vortices denser than surrounding air? Whoa, good guess. I just read a reference that said the vortex descends until it meets air of its own density and then dissipates. It was surprising to read. Let me see if I can find that site again... Kev |
The big question is "why does the wake turbulence descend?" Is the air volume inside the vortices denser than surrounding air? Found it, Tom. Ref: http://www.airpower.maxwell.af.mil/a...ug/carten.html "Cruise altitude vortices usually level off at about 1000 feet below the altitude of the aircraft as their density comes into equilibrium with that of the surrounding air. Decay processes then take over. " Regards, Kev |
![]() "Kev" wrote in message ups.com... On Apr 16, 3:59 pm, Tom L. wrote: The big question is "why does the wake turbulence descend?" Is the air volume inside the vortices denser than surrounding air? Found it, Tom. Ref: http://www.airpower.maxwell.af.mil/a...ug/carten.html "Cruise altitude vortices usually level off at about 1000 feet below the altitude of the aircraft as their density comes into equilibrium with that of the surrounding air. Decay processes then take over. " Don't underestimate the value of the words "usually" and "about" in that sentence. You are still trying to absolutely describe something that is very dynamic. |
On Apr 17, 12:24 am, "Maxwell" wrote:
"Kev" wrote in message http://www.airpower.maxwell.af.mil/a...ew/1971/jul-au... "Cruise altitude vortices usually level off at about 1000 feet below the altitude of the aircraft as their density comes into equilibrium with that of the surrounding air. Decay processes then take over. " Don't underestimate the value of the words "usually" and "about" in that sentence. You are still trying to absolutely describe something that is very dynamic. True. So I guess we could all agree that where the wake goes, depends on the surrounding atmosphere and aircraft profile... Still... if it stayed at the same altitude most of the time (contrary to NASA reports), or was over 100' tall (as some tried to claim at first), then EVERY student pilot could hit their own wake all the time grin. Kev |
![]() "Kev" wrote in message ups.com... On Apr 17, 12:24 am, "Maxwell" wrote: "Kev" wrote in message http://www.airpower.maxwell.af.mil/a...ew/1971/jul-au... "Cruise altitude vortices usually level off at about 1000 feet below the altitude of the aircraft as their density comes into equilibrium with that of the surrounding air. Decay processes then take over. " Don't underestimate the value of the words "usually" and "about" in that sentence. You are still trying to absolutely describe something that is very dynamic. True. So I guess we could all agree that where the wake goes, depends on the surrounding atmosphere and aircraft profile... Still... if it stayed at the same altitude most of the time (contrary to NASA reports), or was over 100' tall (as some tried to claim at first), then EVERY student pilot could hit their own wake all the time grin. But if "ifs" and "buts" were candy and nuts, it would be Christimas every day. If you can hit your own wake doing 60/360s and holding altitude, keep practacing. You are more than likely doing something wrong. |
![]() "Maxwell" wrote in message ... If you can hit your own wake doing 60/360s and holding altitude, keep practacing. You are more than likely doing something wrong. Correction, if you CAN'T hit your own wake |
On 16 Apr 2007 19:26:17 -0700, Kev wrote:
On Apr 16, 3:59 pm, Tom L. wrote: The big question is "why does the wake turbulence descend?" Is the air volume inside the vortices denser than surrounding air? Found it, Tom. Ref: http://www.airpower.maxwell.af.mil/a...ug/carten.html "Cruise altitude vortices usually level off at about 1000 feet below the altitude of the aircraft as their density comes into equilibrium with that of the surrounding air. Decay processes then take over. " Regards, Kev Great! Thanks for the effort. Now I have a new question -- where is this extra air coming from, and how? The vortices grab some additional air molecules and then take them down. Theere is now a volume of air with missing molecules (if I'm allowed to speak in K-grade language). These molecules have to be replaced, and the only source is lower -- in the more dense air that is in addition getting the extra particles. So there must exist an additional upward moving air flow outside the vortices. The pictures showing jets right on top of clouds do seem to indicate this. The vortices seem to suck in clouds from below and then spin them. So there is this secondary air movement starting at 1000' below an aircraft, moving upwards on both sides of the aircraft and filling the low density areas left by the vortices and wing downwash. Interesting. - Tom |
Yes, they do. I just asked a friend with 26,000 hours. He confirmed that
DC-8's and 707's do get a bump as they cross their own wake in a 360 degree constant altitude turn. He also said that some Category D simulators include this effect in their motion repertoire. Rip Tom L. wrote: On 16 Apr 2007 06:37:13 -0700, "Kev" wrote: On Apr 14, 4:27 pm, "george" wrote: I always maintained altitude and rate of turn in steep turns with the end result being hitting my own slipstream. As have we all on nice days, and students like to brag about it. Yet Mx is correct, in theory we should not be able to do this. I seem to recall recent magazine (web?) articles where the idea that you can hit your own wake while actually holding altitude, should be downplayed nowadays. You _have_ to descend a little bit to do so, which means that, while you might be within the +/- 100' test scenario, you are NOT holding the same exact altitude. Hmm. Or else it means that the wake doesn't necessarily descend as we're taught. On a warm clear day (which is when I've hit my own wake), I betcha that the wake is being held upward a tiny bit by the heat from the ground. Cheers, Kev The big question is "why does the wake turbulence descend?" Is the air volume inside the vortices denser than surrounding air? Probably not. So the descent is probably not due to gravitational force. I am no expert on fluid dynamics and have no access to texts that answer the question (if there are any), but figure 7-3-5 in AIM is interesting - it shows a wake sinking at several hundred fpm immediately after an aircraft, but than stabilizing at several hunderd feet below the flightpath, i.e. no further sink. This might indicate that the sink is due to wing downwash. If that is the case, than 1. Wake turbulence in steep turns will not move just downward, but down and out, that is: opposite lift. 2. The speed at which it moves will depend on downwash - it's speed, intensity, strength (?) I don't know which term would be appropriate here. Whatever it is, it might be much smaller for GA aircraft than for large aircraft. It would be interesting to do the following flight test: On a nice day (meaning: perfectly still air) fly turns at different bank angles and speeds and note when you do and don't experience the bump at the end of the turn. Do this in different aircraft - low/high wing, small/large/... Does anyone know whether big aircraft experience the bump at the conclusion of their steep 360s? - Tom |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
