Maxwell writes:
As someone else mentioned, the vortex that started as a very small column at the wing tip, can grow very large by the time you complete a 360 turn at even 60 degrees of bank. And it will be so weak that you won't feel it even if you run into it, which you won't do unless you descend. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "Mxsmanic" wrote in message ... Maxwell writes: As someone else mentioned, the vortex that started as a very small column at the wing tip, can grow very large by the time you complete a 360 turn at even 60 degrees of bank. And it will be so weak that you won't feel it even if you run into it, which you won't do unless you descend. Thank you. I just love it when you prove your ignorance and inexperience in a single statement. The really is thoughtful. Save the band width. |
Wrong.
mike "Mxsmanic" wrote in message ... And it will be so weak that you won't feel it even if you run into it, which you won't do unless you descend. -- Transpose mxsmanic and gmail to reach me by e-mail. |
On Apr 16, 11:15 am, "Maxwell" wrote:
"Kev" wrote in message It's going to take about 30 seconds to fly a 360 steep turn at 100kts. My wake _should_ descend about 150' during that time (300 fpm). I can't imagine a C172 wake being tall enough to stay in my way unless something else is ocurring (me descending, or the wake staying up). I am certainly no expert on the subject, but I think most of the data on wake turbulence comes from studies held at or very near the ground. My searches on the web show the opposite... or at least that there's studies both at altitude and near the ground. For examples: http://www.nasa.gov/centers/dryden/a...4-14-DFRC.html "NASA research has shown that as large aircraft move through the air, trailing vortices tend to remain spaced less than a wingspan apart while sinking at a rate of several hundred feet per minute. Over time, the sink rate will slow and their strength will taper off. Research has shown, however, that vortices can also rise during conditions of ambient thermal lifting." "Aircraft Accident Reconstruction and Litigation" By M. P. Papadakis, Barnes Warnock MacCormick, states that vortices descend 5-10 fps (30-600 fpm). Based on the numbers I recall, they did indeed teach that the wake from a landing heavy would NORMALLY travel both down and away from the aircraft a 5 kts or so. But they were also quick to mention that a simple 5 kt or so crosswind componet could leave the vortex in the middle of the runway for quite some time. Yes, we were all taught that part. The problem with trying to use this information at altitude is that you don't have the ground to help stablize the vertical movement of the vortex. Here is information taken at altitude: Vortices are 14-36 feet in diameter, approx the wingspan apart, and sink 160 - 1100 fpm. http://www.airpower.maxwell.af.mil/a...ug/carten.html I just think it's an interesting question, because we've all had it happen, but no one here can give a definitive reason for it (beyond "yo stupid of course it does" which is pretty lame even for the usual Mx bashers ;-) I think I've convinced myself that since I don't always hit my wake on a perfect steep turn, and because it mostly seems to happen over areas of rising air, that the explanation is simple. Unless someone can post better research. Thanks, Kev |
![]() "Kev" wrote in message oups.com... I think I've convinced myself that since I don't always hit my wake on a perfect steep turn, and because it mostly seems to happen over areas of rising air, that the explanation is simple. Unless someone can post better research. Great, now what do you intend to do with the imformation? |
In rec.aviation.piloting Kev wrote:
On Apr 16, 11:15 am, "Maxwell" wrote: "Kev" wrote in message It's going to take about 30 seconds to fly a 360 steep turn at 100kts. My wake _should_ descend about 150' during that time (300 fpm). I can't imagine a C172 wake being tall enough to stay in my way unless something else is ocurring (me descending, or the wake staying up). I am certainly no expert on the subject, but I think most of the data on wake turbulence comes from studies held at or very near the ground. My searches on the web show the opposite... or at least that there's studies both at altitude and near the ground. For examples: http://www.nasa.gov/centers/dryden/a...4-14-DFRC.html ||||| "NASA research has shown that as large aircraft move through the air, ||||| trailing vortices tend to remain spaced less than a wingspan apart while sinking at a rate of several hundred feet per minute. Over time, the sink rate will slow and their strength will taper off. Research has shown, however, that vortices can also rise during conditions of ambient thermal lifting." "Aircraft Accident Reconstruction and Litigation" By M. P. Papadakis, Barnes Warnock MacCormick, states that vortices descend 5-10 fps (30-600 fpm). Where's the data for C172 sized aircraft? People are assuming numbers for a specific type of aircraft are applicable to very different aircraft. I see no justification for this. snip rest -- Jim Pennino Remove .spam.sux to reply. |
![]() "Mxsmanic" wrote in message ... writes: Where's the data for C172 sized aircraft? Small aircraft work the same way, since they have wings that work the same way. People are assuming numbers for a specific type of aircraft are applicable to very different aircraft. These facts are applicable to all fixed-wing aircraft. I see no justification for this. You're assuming a difference where no evidence for a difference exists. Priceless!!! You are dead wrong again. |
In rec.aviation.piloting Mxsmanic wrote:
writes: Where's the data for C172 sized aircraft? Small aircraft work the same way, since they have wings that work the same way. People are assuming numbers for a specific type of aircraft are applicable to very different aircraft. These facts are applicable to all fixed-wing aircraft. I see no justification for this. You're assuming a difference where no evidence for a difference exists. Yes, you are quite correct; there is no differece between a 747 and a C172 in the Microsoft Flight Simulator game. -- Jim Pennino Remove .spam.sux to reply. |
What is the vertical component of the vector if you have the wake traveling
outward perpindicular to the wings? It will be 150' from the original path, but at an angle to vertical. mike "Kev" wrote in message ups.com... On Apr 16, 9:41 am, Jose wrote: I seem to recall recent magazine (web?) articles where the idea that you can hit your own wake while actually holding altitude, should be downplayed nowadays. You _have_ to descend a little bit to do so, How tall is the wake? Good point. Still, using the calculator at: http://www.csgnetwork.com/aircraftturninfocalc.html It's going to take about 30 seconds to fly a 360 steep turn at 100kts. My wake _should_ descend about 150' during that time (300 fpm). I can't imagine a C172 wake being tall enough to stay in my way unless something else is ocurring (me descending, or the wake staying up). Would love to hear a decent explanation. Kev |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
