RomeoMike wrote:
I don't know if he "cannot" or will not or just wants to get under everyone's skin. What you say in this post is correct. But why do people keep responding and arguing ad nauseum with someone who can't or won't get it? What's the dynamic? I doubt that there has ever been a pilot who has not flown into his own wake in a constant altitude 360. So this is not a topic that one pilot needs to prove to another pilot with a different opinion. The only dynamic is between the pilots on the group, certainly not with MX. But, as I mentioned, the thread forced me to ask myself just what it was I am "running over" when I hit my own wake turbulence. Does it matter? Probably not, but this enquiring mind wants to know. I still don't have the answer. Rising wingtip vortices in warm air? Prop wash? "Burbles" from the passage of non-lifting surfaces like the fuselage? We all know it happens. I'm just one of those weirdos that wants to know WHY it happens. As a result of this thread, it appears that nobody knows. It's an unstudied regime of flight. I find THAT interesting! Perhaps it could lead to some super-terrific drag reduction technique, like surfing on your own wake? After all, that's why geese fly in "V" formation. Rip |
![]() "Rip" wrote ... We all know it happens. I'm just one of those weirdos that wants to know WHY it happens. As a result of this thread, it appears that nobody knows. It's an unstudied regime of flight. I find THAT interesting! Me too ;-) I actually tried yesterday... with poor results for the connect ;( But the GPS track provided an explanation. It showed my 360s were not proper full circles, i.e. at the exit I crossed the previous flight path at an angle (more than 45 degrees in fact) instead of actually flying in the same circle track as the entry of the 360. Not so easy to explain, but the result was that the airplane was only in the potential wake area for a fraction of a second. I guess you need to fly so that the flightpath is well aligned with the original circle, in order to catch the wake. Back to the theory: I read some interesting basic aerodynamics of drag. According to the book, at low speeds the induced drag (which is a side effect of the lift force) is larger than the parasite drag (caused by frontal area, landing gear etc). But at higher speeds (above 70 mph in the example case, a light plane) parasite drag becomes the dominant drag component. Now, the induced drag is creating the tip vortices, which presumably descend, but parasite drag has no vertical component, so in theory it should stay in place. So according to this, the higher the airplane's relative speed, the slower the wake will descend (if at all). I look forward to the results of the group's experiments ;-) |
![]() "Snowbird" wrote: I actually tried yesterday... with poor results for the connect ;( But the GPS track provided an explanation. It showed my 360s were not proper full circles, i.e. at the exit I crossed the previous flight path at an angle (more than 45 degrees in fact) instead of actually flying in the same circle track as the entry of the 360. That's probably because there was wind aloft. GPS shows your track over the ground, not your track WRT the moving air mass. In perfectly calm conditions, GPS track would show a circle if you flew one properly. -- Dan C-172RG at BFM |
Snowbird writes:
Now, the induced drag is creating the tip vortices, which presumably descend, but parasite drag has no vertical component, so in theory it should stay in place. So according to this, the higher the airplane's relative speed, the slower the wake will descend (if at all). The entire air mass behind the aircraft is descending. The downwash descends, and air from above moves down to replace it. While parasitic drag is not associated with lift and thus has no vertical component of its own, any turbulence it creates will still drift downward with the downwash, although perhaps less quickly than the downwash itself, depending on where the turbulence leaves the aircraft. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() The only dynamic is between the pilots on the group, certainly not with MX. But, as I mentioned, the thread forced me to ask myself just what it was I am "running over" when I hit my own wake turbulence. Does it matter? Probably not, but this enquiring mind wants to know. I still don't have the answer. Rising wingtip vortices in warm air? Prop wash? "Burbles" from the passage of non-lifting surfaces like the fuselage? We all know it happens. I'm just one of those weirdos that wants to know WHY it happens. As a result of this thread, it appears that nobody knows. It's an unstudied regime of flight. I find THAT interesting! Perhaps it could lead to some super-terrific drag reduction technique, like surfing on your own wake? After all, that's why geese fly in "V" formation. Rip As you correctly point out, we all know that it happens because we have all done it; and when we flew eights around pilons, we hit our own wake quite decisively each time we crossed the center point. Thus, clearly, it doesn't matter whether we might have found a more impressive bump lower down; the salient point is that a portion of the wake was above the flight path when we returned to that place in the atmosphere. Actually, most of the writings about wakes and sinking air, insofar as I can tell, only discuss the motion of the central portion of the wake. Additional writings, regarding the (very reall) potential for upset discuss the central area of the vorticies--which settle at a lesser rate and expand as they settle. Our actual experience strongly implies that the vortices expand at least as rapidly as they settle. I see that Snowbird has already posted links to my favorite illustration of this, plus quite a few more, so I'll stop. Peter |
![]() "Rip" wrote ... Oh well. The entire thread has forced me to ask myself just what the wake behind an aircraft looks like. Like every other pilot, I know you can intercept your own wake during a constant altitude turn, but it would be neat to be able to SEE all of the air masses at work. Thanks for your smoke insights ;-) There are some great photos depicting the tip vortices he http://www.airliners.net/open.file/1091105/M/ http://www.airliners.net/open.file/1008033/M/ Here are some real masterpieces : http://www.airtoair.net/gallery/gallery-vortices.htm I guess Mxmanic uses the FAA AIM as his main source in his "research". Section 7.3.1 is about wake turbulence. A couple of interesting quotes from that section, that Mx has not seen fit to share with us: a) "Flight tests have shown that the vortices from larger (transport category) aircraft sink at a rate of several hundred feet per minute, slowing their descent and diminishing in strength with time and distance behind the generating aircraft." Note the explicit reference to large aircraft. In fact, it seems all actual wake turbulence safety studies have involved large aircraft, i.e. B707 and larger. This is in fact quite natural, as there was no real safety issue before the large jetliners appeared. b) "Test data have shown that vortices can rise with the air mass in which they are embedded." There you are, official proof to the statements of several of our contributors. c) "The greatest vortex strength occurs when the generating aircraft is HEAVY, CLEAN, and SLOW." In contrast, a light aircraft doing a 360 is usually LIGHT, CLEAN and (relatively speaking) FAST. Very different conditions, especially regarding two major sources of wake: the AoA of the wing (which affects the tip vortices) and the power setting (which affects the propwash strength). The interesting study question here, for the light airplane case, would be the relation between the tip vortices (which presumably sink, as for large aircraft) and the propwash (which is basically horizontal). I think glider pilots can testify that the propwash is the dominant one, at least close behind the tug airplane - any soarers out there who can comment? But realistically, as the wake behind a light aircraft is no real safety hazard, there is no compelling reason to study this case. So unless someone can produce a reference, let's rely on the observational data from countless pilots. |
Beautiful, Snowbird. I've seen the effect in reality, but those are some
magnificent photos! Rip |
Snowbird writes:
I guess Mxmanic uses the FAA AIM as his main source in his "research". That is only one of many sources. They all say the same thing. a) "Flight tests have shown that the vortices from larger (transport category) aircraft sink at a rate of several hundred feet per minute, slowing their descent and diminishing in strength with time and distance behind the generating aircraft." Note the explicit reference to large aircraft. In fact, it seems all actual wake turbulence safety studies have involved large aircraft, i.e. B707 and larger. This is in fact quite natural, as there was no real safety issue before the large jetliners appeared. The wakes of smaller aircraft descend as well. b) "Test data have shown that vortices can rise with the air mass in which they are embedded." There you are, official proof to the statements of several of our contributors. Including myself. c) "The greatest vortex strength occurs when the generating aircraft is HEAVY, CLEAN, and SLOW." Yes. Although the downwash itself should be strongest when the aircraft is dirty and slow. The reason clean and slow produces stronger _vortices_ is that it only produces one pair, whereas flaps and other control surfaces can produce multiple vortices of smaller size that tend to interfere with each other and reduce overall turbulence. In contrast, a light aircraft doing a 360 is usually LIGHT, CLEAN and (relatively speaking) FAST. Very different conditions, especially regarding two major sources of wake: the AoA of the wing (which affects the tip vortices) and the power setting (which affects the propwash strength). Which makes it all the more difficult to understand how a pilot could feel his own wake in a level 360-degree turn. The interesting study question here, for the light airplane case, would be the relation between the tip vortices (which presumably sink, as for large aircraft) and the propwash (which is basically horizontal). I think glider pilots can testify that the propwash is the dominant one, at least close behind the tug airplane - any soarers out there who can comment? You're neglecting the downwash, which is present in all aircraft. Downwash tends to pull all turbulence behind the aircraft down with it. But realistically, as the wake behind a light aircraft is no real safety hazard, there is no compelling reason to study this case. So unless someone can produce a reference, let's rely on the observational data from countless pilots. And ignore the factual data from countless resources? What makes pilots more reliable? Most pilots barely understand how lift works to begin with. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote in
news ![]() Snowbird writes: I guess Mxmanic uses the FAA AIM as his main source in his "research". That is only one of many sources. They all say the same thing. a) "Flight tests have shown that the vortices from larger (transport category) aircraft sink at a rate of several hundred feet per minute, slowing their descent and diminishing in strength with time and distance behind the generating aircraft." Note the explicit reference to large aircraft. In fact, it seems all actual wake turbulence safety studies have involved large aircraft, i.e. B707 and larger. This is in fact quite natural, as there was no real safety issue before the large jetliners appeared. The wakes of smaller aircraft descend as well. b) "Test data have shown that vortices can rise with the air mass in which they are embedded." There you are, official proof to the statements of several of our contributors. Including myself. c) "The greatest vortex strength occurs when the generating aircraft is HEAVY, CLEAN, and SLOW." Yes. Although the downwash itself should be strongest when the aircraft is dirty and slow. The reason clean and slow produces stronger _vortices_ is that it only produces one pair, whereas flaps and other control surfaces can produce multiple vortices of smaller size that tend to interfere with each other and reduce overall turbulence. In contrast, a light aircraft doing a 360 is usually LIGHT, CLEAN and (relatively speaking) FAST. Very different conditions, especially regarding two major sources of wake: the AoA of the wing (which affects the tip vortices) and the power setting (which affects the propwash strength). Which makes it all the more difficult to understand how a pilot could feel his own wake in a level 360-degree turn. The interesting study question here, for the light airplane case, would be the relation between the tip vortices (which presumably sink, as for large aircraft) and the propwash (which is basically horizontal). I think glider pilots can testify that the propwash is the dominant one, at least close behind the tug airplane - any soarers out there who can comment? You're neglecting the downwash, which is present in all aircraft. Downwash tends to pull all turbulence behind the aircraft down with it. No, it doesn't, fjukkwit. Only most of it. Send me fifty bucks and I'll explain why to you bertie |
On Apr 16, 3:47 pm, "Snowbird" wrote:
I guess Mxmanic uses the FAA AIM as his main source in his "research". Section 7.3.1 is about wake turbulence. A couple of interesting quotes from that section, that Mx has not seen fit to share with us: Heh. Many of his responders seem to have done even less "research". Instead they substitute insults for information, hoping they'll look smarter than him. They don't seem to realize that it just makes them look dumber. c) "The greatest vortex strength occurs when the generating aircraft is HEAVY, CLEAN, and SLOW." In contrast, a light aircraft doing a 360 is usually LIGHT, CLEAN and (relatively speaking) FAST. Very different conditions, especially regarding two major sources of wake: the AoA of the wing (which affects the tip vortices) and the power setting (which affects the propwash strength). Of course, LIGHT does not mean "light aircraft". Some 152s are vortex HEAVY in the case of big instructors and students ;-) For vortex strength, the term HEAVY is used in a relative manner. A small plane that is lightly loaded will create less vortex strength than the same small plane that is heavily loaded, because the actual AOA is larger in the latter case. The actual AOA is the key for (HEAVY) more load, (CLEAN) less flaps and (SLOW) less speed. It's greater in all those cases. Auugh. Four year old calling me. Later.. Best, Kev |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
