Question to Mxmanic
Old April 18th 07, 03:58 AM posted to rec.aviation.piloting,rec.aviation.student
Tim[_4_]
Default Question to Mxmanic
"Mxsmanic" wrote...
Tim writes:
Yes, it will. Try it - if you're good enough you will see it happen. If
not, you have to practice your 360s.
It doesn't happen. I did try it, in perfect weather, at 2500' MSL over
Southwest Oregon Regional Airport, using the autopilot to make a perfect
turn
with a constant altitude. No bump.
Then you did something wrong because it definitely does happen.
BDS
Old April 18th 07, 04:35 AM posted to rec.aviation.piloting,rec.aviation.student
Rip
Tim wrote:
"Mxsmanic" wrote...
Tim writes:
turn
BDS
Tim, get with the program, man. Mxsmanic has never flown anything other
than Microsoft Flight Simulator. Seriously.
Rip
Old April 18th 07, 01:11 PM posted to rec.aviation.piloting,rec.aviation.student
Tim[_4_]
That's what we are talking about.
Even in MSFS you can see the effect of flying back through your own
turbulence when doing a proper 360.
BDS
Old April 18th 07, 05:51 AM posted to rec.aviation.piloting,rec.aviation.student
swag
On Apr 17, 5:18 pm, Mxsmanic wrote:
Tim writes:
Southwest Oregon Regional Airport, using the autopilot to make a perfect turn
Can you set an autopilot to do a 60 degree bank angle turn? Mine
won't do that.
Old April 18th 07, 06:39 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
swag writes:
won't do that.
It depends on the autopilot. On large aircraft you can, although they usually
won't go to 60 degrees.
Old April 18th 07, 08:28 PM posted to rec.aviation.piloting,rec.aviation.student
swag
On Apr 17, 11:39 pm, Mxsmanic wrote:
swag writes:
won't do that.
so didyou when you did your "test flight?" You won't encounter a bump
from wake turbulence unless you are doing a steep turn ( like 45
degree bank angle which should take 19 seconds to go 360)
Old April 18th 07, 09:45 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
swag writes:
In the sim? No, there was no bump.
You won't encounter a bump from wake turbulence unless you are
doing a steep turn ( like 45 degree bank angle which should
Why would the steepness of a turn matter?
A 2-G turn is rather close to the load limits for many types of aircraft.
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 01:11 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 01:26 AM
