![]() "Mxsmanic" wrote... Tim writes: Yes, it will. Try it - if you're good enough you will see it happen. If not, you have to practice your 360s. It doesn't happen. I did try it, in perfect weather, at 2500' MSL over Southwest Oregon Regional Airport, using the autopilot to make a perfect turn with a constant altitude. No bump. Then you did something wrong because it definitely does happen. BDS |
Tim wrote:
"Mxsmanic" wrote... Tim writes: Yes, it will. Try it - if you're good enough you will see it happen. If not, you have to practice your 360s. It doesn't happen. I did try it, in perfect weather, at 2500' MSL over Southwest Oregon Regional Airport, using the autopilot to make a perfect turn with a constant altitude. No bump. Then you did something wrong because it definitely does happen. BDS Tim, get with the program, man. Mxsmanic has never flown anything other than Microsoft Flight Simulator. Seriously. Rip |
![]() "Rip" wrote Tim, get with the program, man. Mxsmanic has never flown anything other than Microsoft Flight Simulator. Seriously. That's what we are talking about. Even in MSFS you can see the effect of flying back through your own turbulence when doing a proper 360. BDS |
On Apr 17, 5:18 pm, Mxsmanic wrote:
Tim writes: Yes, it will. Try it - if you're good enough you will see it happen. If not, you have to practice your 360s. It doesn't happen. I did try it, in perfect weather, at 2500' MSL over Southwest Oregon Regional Airport, using the autopilot to make a perfect turn with a constant altitude. No bump. -- Transpose mxsmanic and gmail to reach me by e-mail. Can you set an autopilot to do a 60 degree bank angle turn? Mine won't do that. |
swag writes:
Can you set an autopilot to do a 60 degree bank angle turn? Mine won't do that. It depends on the autopilot. On large aircraft you can, although they usually won't go to 60 degrees. -- Transpose mxsmanic and gmail to reach me by e-mail. |
On Apr 17, 11:39 pm, Mxsmanic wrote:
swag writes: Can you set an autopilot to do a 60 degree bank angle turn? Mine won't do that. It depends on the autopilot. On large aircraft you can, although they usually won't go to 60 degrees. -- Transpose mxsmanic and gmail to reach me by e-mail. so didyou when you did your "test flight?" You won't encounter a bump from wake turbulence unless you are doing a steep turn ( like 45 degree bank angle which should take 19 seconds to go 360) |
swag writes:
so didyou when you did your "test flight?" In the sim? No, there was no bump. You won't encounter a bump from wake turbulence unless you are doing a steep turn ( like 45 degree bank angle which should take 19 seconds to go 360) Why would the steepness of a turn matter? A 2-G turn is rather close to the load limits for many types of aircraft. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "Mxsmanic" wrote in message ... swag writes: so didyou when you did your "test flight?" In the sim? No, there was no bump. You won't encounter a bump from wake turbulence unless you are doing a steep turn ( like 45 degree bank angle which should take 19 seconds to go 360) Why would the steepness of a turn matter? A 2-G turn is rather close to the load limits for many types of aircraft. What a dumb ****! Are you kidding??? If someone rolled your brain up in to a ball, and rolled it down a razor blade - it would look like a B-B rolling down a four lane highway. |
On Apr 18, 2:45 pm, Mxsmanic wrote:
swag writes: so didyou when you did your "test flight?" In the sim? No, there was no bump. You won't encounter a bump from wake turbulence unless you are doing a steep turn ( like 45 degree bank angle which should take 19 seconds to go 360) Why would the steepness of a turn matter? A 2-G turn is rather close to the load limits for many types of aircraft. -- Transpose mxsmanic and gmail to reach me by e-mail. The steepness matters for two reasons 1. the time of the turn matters to whether the wake turbulance is dissipating 2. the bank angle changes the rate of descent of the wake So if you are doing a standard rate turn that takes two minutes, you will not hit youur wake. But if you do a 2g turn (around 45 degrees) it should take 19 seconds and you will hit your wake. 3. a 2 g turn should not be close to the load limits of any airplane certificated in the standard (let alone the utility) category. My airplane ( a P337) is certificated as standard, not utility. the load limits ar +3.8 flaps up. And is approved for turns up to 60 degrees. |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
