On Apr 26, 7:16 am, "Matt Barrow"
wrote: It is amazing, how many people fail to realize that the 30% of aircraft that HAVE TO HAVE 100LL are the ones that do 70% (or more) of the flying hours. I have seen this 30%/70% number repeatedly, but I don't remember it ever came from a scientific survey, or just someones rough estimate. Regardless of that, this might be true in 1997, but I doubt it's true anymore in 2007. Especially if you exclude engines there're originally certificated for 91/96 avgas. Commercial operators flying large number hours have been increasingly switching to turboprop equipment in the last 10 years for things like feeder line freight, air taxi or charter. That has contributed to the big decline of overall 100LL consumption in U.S. |
![]() "M" wrote in message oups.com... On Apr 26, 7:16 am, "Matt Barrow" wrote: It is amazing, how many people fail to realize that the 30% of aircraft that HAVE TO HAVE 100LL are the ones that do 70% (or more) of the flying hours. I have seen this 30%/70% number repeatedly, but I don't remember it ever came from a scientific survey, or just someones rough estimate. FAA figures. Regardless of that, this might be true in 1997, but I doubt it's true anymore in 2007. Especially if you exclude engines there're originally certificated for 91/96 avgas. Commercial operators flying large number hours have been increasingly switching to turboprop equipment in the last 10 years for things like feeder line freight, air taxi or charter. It'll take years to convert. That has contributed to the big decline of overall 100LL consumption in U.S. Do you have a cite for that last one? What's the GA activity level over the past few years? |
Matt Barrow wrote:
What's really strange is all those new 4 seaters are designed with engine requiring 100LL, instead of 91/96. It part of a big bore engine. It has nothing to do with the bore, and everything to do with the compression ratio. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200704/1 |
![]() "flynrider via AviationKB.com" u32749@uwe wrote in message news:70fea2213e94e@uwe... Matt Barrow wrote: What's really strange is all those new 4 seaters are designed with engine requiring 100LL, instead of 91/96. It part of a big bore engine. It has nothing to do with the bore, and everything to do with the compression ratio. Yes! My bad! And what is the threshold for compression ratio? Why does my current 7.5:1 CR still need 100LL when my older 8.5:1 did as well? |
Matt Barrow wrote:
And what is the threshold for compression ratio? Why does my current 7.5:1 CR still need 100LL when my older 8.5:1 did as well? Sorry, I must have missed this post over the weekend. Is your current engine turbocharged? I'm scratching my head trying to come up with a 7.5:1 engine that requires 100LL. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200704/1 |
![]() "JGalban via AviationKB.com" u32749@uwe wrote in message news:714b95624358f@uwe... Matt Barrow wrote: And what is the threshold for compression ratio? Why does my current 7.5:1 CR still need 100LL when my older 8.5:1 did as well? Sorry, I must have missed this post over the weekend. Is your current engine turbocharged? I'm scratching my head trying to come up with a 7.5:1 engine that requires 100LL. TSIO-550C -- Matt Barrow Performace Homes, LLC. Colorado Springs, CO |
Matt Barrow wrote:
TSIO-550C That's what I figured. Turbocharged engines are a different kettle of fish. The main reason is the higher temperatures in the induction system lowers the detonation margin considerably. John Galban=====N4BQ (PA28-180) -- Message posted via http://www.aviationkb.com |
![]() "JGalban via AviationKB.com" u32749@uwe wrote in message news:7159afcd0261c@uwe... Matt Barrow wrote: TSIO-550C That's what I figured. Turbocharged engines are a different kettle of fish. So was my last one; TNIO-550 (okay, turboNORMALIZED). The main reason is the higher temperatures in the induction system lowers the detonation margin considerably. Hmmm... Deakins "Detonation Myths". /quote Now, somewhere about 20 to 25 degrees before the piston reaches top dead center (TDC) of piston travel, the spark plug lights the fire. The flame front starts spreading from each spark plug, slowly at first, then more rapidly within the cylinder. This flame front plays an important role in all of this. Ever stick your hand up close to a hot flame? Not in the flame, just close? It gets hot fast. There is a LOT of infrared heat being given off by that flame front. It travels at the speed of light. Maybe a few million times (or so) faster than the flame front is traveling across the cylinder. That infrared radiation heats up those little local pockets of fuel and air. Further, since the piston is rising rapidly in the cylinder, those little remote local pockets of fuel and air are also experiencing a sudden rise in pressure. Still further, because the flame front is a combustion process, it, too, is causing a further and much larger rise in pressure in the cylinder. Hold that thought for a moment, while we mention the time scale for all this. During the combustion event, the speed of sound (at the higher bulk gas temperatures) is such that a sound wave can bounce across the cylinder and back in about 1/5000th of one second, or about 1/5th of a millisecond. This is easy to instrument and measure. You see the evidence of this in the little detonation shock waves bouncing back and forth past the pressure transducer on the back side of the down slope of the combustion pressure event in the graphics depicting the medium and heavy detonation. The crankshaft is rotating about 45 times per second and that works out to about 22 milliseconds for each crankshaft rotation, or about 16 degrees of crankshaft rotation for each millisecond. So in the time it takes a shock wave to travel back and forth across the inside of the cylinder, the crankshaft has only moved about three degrees. So, now that we have the time scale firmly in mind, we go back and summarize what is going on: 1.. We have nice cool induction air and fuel entering a cylinder; 2.. The cylinder happens to have very hot walls. Those hot walls cause some of that nice cool induction air to start to heat up. And it doesn't all happen uniformly. 3.. Further, shortly after the sparks go off, we have a couple of flame fronts, giving off lots of infrared heat, adding to the continuing heat load being absorbed by some of those little remote pockets of fuel and air that are waiting for the flame front to arrive and consume them; 4.. The unburned mixture is experiencing a very rapid increase in pressure, because of two things: A) The piston is rising rapidly during the compression stroke; and B) the flame front combustion products are creating a huge increase in released energy and resulting bulk gas pressure, all of which is neatly measured on the pressure traces you see in the accompanying graphics. 5.. At least some of those little "local pockets" of unburned combustion mixtures have exactly the right mixture of fuel and air to be just a hair-trigger away from exploding. 6.. And . if the fuel is the wrong octane, or the spark advance was set too soon, or the manifold pressure was too high, or the cylinder head temperature was too high ... then one or more of those little "local pockets" of unburned fuel do just that ... they "explode." That is what we call "detonation". Each explosion creates a shock wave that travels at the speed of sound (remember, the speed of sound inside the cylinder, at somewhere near 4000 degrees, is very much faster than at a standard day!) and bounces off the walls of the combustion chamber every 1/5th of a millisecond or so (giving off a 5KHz "ping" that you will not hear in the cockpit). Each of those explosions creates a very sharp rise in pressure and sets off a shock wave, which vibrates back and forth across the cylinder. This shock wave can be just the right amount of additional pressure to cause some other little remote local pocket of fuel and air to, in turn, explode, adding to the problem. As detonation grows more serious, it will become audible, and this is the pinging you'll hear from that old auto engine on the uphill grade. Remember, you will NOT hear it on an aircraft engine. Let's Talk Temperatures We know that combustion temperatures are in the 3,000ºF to 4,000ºF range, but TIT and EGT "only" run around 1,600ºF, and CHTs down around 400ºF. How can this be? 4,000ºF is more than enough to melt steel, so how does the interior lining of the cylinder survive? Why don't we see hotter temperatures on our instruments? Why doesn't the aluminum piston melt down, when aluminum melts at less than 1,000ºF? There is a "thermal boundary layer," on the order of a millimeter thin or so, that acts as a buffer to protect the steel cylinder walls and the surface of the aluminum piston. Think of it as the thermal equivalent of the aerodynamic boundary layer out on your wing. The metal and the molecules right next to it will be at roughly the CHT reading or a bit higher, the next layers will be hotter and hotter, until the layer next to the combustion event will be at the combustion temperatures. That very thin thermal boundary layer acts as a nice insulation barrier, limiting the rate at which heat can be transferred from the bulk combustion gases into the interior walls of the cylinder head, cylinder barrel, and piston. The heat transfer is continuous, as the heat moves first through the boundary layer, and then the cylinder wall and is finally carried away by the cooling airflow around the fins on the cylinders. Each intake stroke brings in a cool new charge, which starts the process all over again. There is also a matter of time of exposure. The high-pressure part of the combustion event takes up only about 40 degrees or so of crankshaft rotation, and the very hottest part of that only about 20 degrees, so during the other 700 degrees of crank rotation, cooler temperatures prevail. Many pilots mistakenly focus on the temperature of the exhaust gas as measured by their familiar EGT probes. EGT shows only a number that represents a momentary flash of heat during a small portion of the combustion cycle (when the exhaust valve opens and exhaust gas flows across the EGT probe), and a rapidly dropping temperature at that. This is NOT the major factor that determines how hot their exhaust valve is during operation. The events that happen a few degrees of crankshaft rotation earlier are much more significant because the temperatures are MUCH hotter than the piddling little 'ol 1500ºF measured by the EGT probe. Once detonation becomes serious enough, it disrupts the previously well-organized thermal boundary layer and allows a greatly increased rate of heat transfer from the very hot bulk combustion gases (up around 4,000F) into the cylinder head and the piston. This last stage in the process is what starts the damage, and drives the CHTs up. /end |
![]() "JGalban via AviationKB.com" wrote That's what I figured. Turbocharged engines are a different kettle of fish. The main reason is the higher temperatures in the induction system lowers the detonation margin considerably. Not just the temp, but the pressures involved. In a turbo, not producing boost, a low compression ratio is fine with low octane gas. When the boost is putting all of that extra air and gas into the combustion chamber, it is still compressing at the same ratio. You end up with the normal internal pressure, plus the extra pressure the turbo boost shoved in there. Then detonation becomes a big problem, without the extra octane. But you knew all of that, already. g -- Jim in NC |
The Beginning Of The End Of Airline Transportation? | Larry Dighera | Piloting | 1 | October 7th 06 10:17 AM |
Beginning Flying Questions | [email protected] | Piloting | 23 | June 2nd 06 11:15 PM |
Beginning IFR book? | John T | Piloting | 10 | November 28th 05 03:19 AM |
Did I hurt my alternator? | Paul Tomblin | Piloting | 5 | October 24th 04 04:21 AM |
Are we beginning to see the secondaries? Libya to abandom WMD | John Keeney | Military Aviation | 61 | January 1st 04 09:58 AM |
