![]() "Matt Barrow" wrote in message ... "M" wrote in message oups.com... What's really strange is all those new 4 seaters are designed with engine requiring 100LL, instead of 91/96. It part of a big bore engine. True, but IO-470J/K can run on 80/87. 80/87 is leaded fuel. That's even a worse problem than 100LL. I'm sure they'll do fine on SR-20 airframe. It also won't be very hard for TCM engineers to reduce the compression ratio a bit and make IO-550 run on 91/96. My point is the aircraft manufacturers are short sighted. Relying on a fuel that's going to be increasingly more expensive than automotive fuel doesn't do GA much good. You better dig into things before making such a statement. You're speaking from a vacuum. Don't tell the government that 80/87 is a leaded fuel. They have made such a big deal out of it being unleaded so it won't poison your platinum catalytic converter that afterburns your exhaust to clean up the combustion partial products! :-) There has been a move afoot for some time to eliminate 100 octane "Low Lead" aviation fuel, because it is the only leaded fuel still being made in the US. Then all aircraft would have to use the available unleaded fuel. My experience with the big modern engines is somewhat limited since my newest airplane left the factory in the spring of 1955, about the time I started college. However, I can say with the authority of experience that the IO-520's that I have flown not only demand 100LL but are finicky about that. I have gotten brands of 100LL that the 520 definately didn't like, and brands that caused her to hum along just fine. My poor old main ride also has a three hundred horsepower engine and burns exactly the same amount of fuel per horsepower per hour as the IO-520. It actually get a bit MORE efficiency because an airplane runs on thrust, not horsepower. My 1800rpm cruise allows considerably more pounds of thrust per horsepower than the higher cruise rpms of the more modern engines. Of course I squeeze my 300 horsepower out of a measly 680 cubic inches instead of 520. That does add a few pounds of weight and a bit of frontal area. I also have half again as many cylinders hanging in the breeze as the little 520! :-) Plan now. The 10th or 11th ( I lost count several years ago ) annual rec.aviation annual EVENT at Pinckneyville is coming up soon. It is planned this year for May 18, 19, and 20. It is an unparalleled opportunity to actually see some of the people you have exchanged various views with on the internet. If you have never heard of the Pinckneyville Flyin see the unofficial FAQ at http://www.ousterhout.net/pjy-faq.html If you still have any questions you will have to come to the flyin to get them answered. Or, perhaps, merely rendered irrelevant. :-) We would appreciate any folks planning to attend drop an email to Mary at and let her know how many folks are coming and what days. It is a long way to the nearest grocery store and even farthur to a good liquor store from the airport and we don't want to run out of essential supplies! :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
![]() "Highflyer" wrote in message ... "Matt Barrow" wrote in message ... "M" wrote in message oups.com... What's really strange is all those new 4 seaters are designed with engine requiring 100LL, instead of 91/96. It part of a big bore engine. True, but IO-470J/K can run on 80/87. 80/87 is leaded fuel. That's even a worse problem than 100LL. I'm sure they'll do fine on SR-20 airframe. It also won't be very hard for TCM engineers to reduce the compression ratio a bit and make IO-550 run on 91/96. My point is the aircraft manufacturers are short sighted. Relying on a fuel that's going to be increasingly more expensive than automotive fuel doesn't do GA much good. You better dig into things before making such a statement. You're speaking from a vacuum. Don't tell the government that 80/87 is a leaded fuel. They have made such a big deal out of it being unleaded so it won't poison your platinum catalytic converter that afterburns your exhaust to clean up the combustion partial products! :-) Right you are...I was thinking 100 or the old other stuff (heavily leaded). It is amazing, how many people fail to realize that the 30% of aircraft that HAVE TO HAVE 100LL are the ones that do 70% (or more) of the flying hours. The recreational aircraft that can burn Sterno, rubbling alcohol, or Jack Daniels, just don't make much of a market. |
On Apr 26, 7:16 am, "Matt Barrow"
wrote: It is amazing, how many people fail to realize that the 30% of aircraft that HAVE TO HAVE 100LL are the ones that do 70% (or more) of the flying hours. I have seen this 30%/70% number repeatedly, but I don't remember it ever came from a scientific survey, or just someones rough estimate. Regardless of that, this might be true in 1997, but I doubt it's true anymore in 2007. Especially if you exclude engines there're originally certificated for 91/96 avgas. Commercial operators flying large number hours have been increasingly switching to turboprop equipment in the last 10 years for things like feeder line freight, air taxi or charter. That has contributed to the big decline of overall 100LL consumption in U.S. |
![]() "M" wrote in message oups.com... On Apr 26, 7:16 am, "Matt Barrow" wrote: It is amazing, how many people fail to realize that the 30% of aircraft that HAVE TO HAVE 100LL are the ones that do 70% (or more) of the flying hours. I have seen this 30%/70% number repeatedly, but I don't remember it ever came from a scientific survey, or just someones rough estimate. FAA figures. Regardless of that, this might be true in 1997, but I doubt it's true anymore in 2007. Especially if you exclude engines there're originally certificated for 91/96 avgas. Commercial operators flying large number hours have been increasingly switching to turboprop equipment in the last 10 years for things like feeder line freight, air taxi or charter. It'll take years to convert. That has contributed to the big decline of overall 100LL consumption in U.S. Do you have a cite for that last one? What's the GA activity level over the past few years? |
On Apr 27, 6:40 pm, "Matt Barrow"
wrote: I have seen this 30%/70% number repeatedly, but I don't remember it ever came from a scientific survey, or just someones rough estimate. FAA figures. Care to provide the source (URL of the original data)? That has contributed to the big decline of overall 100LL consumption in U.S. Do you have a cite for that last one? What's the GA activity level over the past few years? Year US Avgas production and import (thousand barrels) 1999 7485 2000 6648 2001 7121 2002 6584 2003 6255 2004 6295 source: http://www.indexmundi.com/en/commodi...ly_monthly.htm |
wrote: That has contributed to the big decline of overall 100LL consumption in U.S. Do you have a cite for that last one? This is an even better source showing the decline of 100LL consumption: http://tonto.eia.doe.gov/dnav/pet/hist/a403600001m.htm |
The Beginning Of The End Of Airline Transportation? | Larry Dighera | Piloting | 1 | October 7th 06 10:17 AM |
Beginning Flying Questions | [email protected] | Piloting | 23 | June 2nd 06 11:15 PM |
Beginning IFR book? | John T | Piloting | 10 | November 28th 05 03:19 AM |
Did I hurt my alternator? | Paul Tomblin | Piloting | 5 | October 24th 04 04:21 AM |
Are we beginning to see the secondaries? Libya to abandom WMD | John Keeney | Military Aviation | 61 | January 1st 04 09:58 AM |
