#11
Recently, Tom posted:
So I went for a lovely flight yesterday, from Bedford (KBED) down to Nantucket (KACK) for dinner. We flew down there in the last hour or so of daylight with a smooth ride and great views, and then returned at night with an even smoother ride and great night-time views, including a few circles over Harvard, MIT and Back Bay on the way home. ATC were very accommodating since it was fairly late. Bedford tower was closed so I was on the CTAF frequency as I approached the field. I was initially thinking of taking runway 24 since the winds were 190. When I announced my imminent arrival in the vicinity of the field an aircraft informed me they were on final for 11. They also mentioned an aircraft in the area that was at 5,000 and on an IFR flight plan but not talking to ATC, possibly inbound for landing as well. Armed with this information, I changed my plan and entered a downwind leg for 11 (since the winds were not strong and that seemed to be the established pattern). I announced my downwind leg, my base and my final (looking out for traffic all the way). When I was at 1 mile final, I hear "Nxxxx, 3 mile final for 11, Bedford" I respond with "I am 1 mile final for 11, Bedford" He responds with "We'll slow it down" This doesn't comfort me that much, since I'm only going 65 knots. Maybe I should have said this to him at the time. Then he comes in again with "We're going to break off our approach, do a 360 and rejoin" As I'm at 50ft, he says "Have you landed yet" I reply with "Just about to touch down" Then I land, clear the runway, inform him I am clear, and then he lands. Everything works out fine although my landing isn't exactly a greaser. I didn't feel that great about the incident: did I do something wrong? Why didn't I see him on final before I turned final (I specifically remember looking in that direction before turning final)? What if the timings had been slightly different? And for his part, shouldn't he have been on the frequency and known I was in the pattern? Shouldn't his first call have been a lot sooner than 3 mile final? Shouldn't he have flown a circuit rather than come straight in? I'm assuming he wasn't in any kind of emergency situation as he would have asked me to go around. Thoughts appreciated, especially from those with extensive flying experience. Tom My first reaction is that I'm surprised that he wasn't looking for you, given that he was attempting a straight-in from only 3 miles out with known traffic in the pattern. He shouldn't have had to ask whether you landed yet or not. At uncontrolled fields anything can happen, and should be watched for. The uncontrolled field I use most often has two crossing runways and *no* established pattern. It isn't unusual to have several planes in the pattern as well as incoming traffic of various kinds from biz jets to biplanes and helos. People come in as they wish, and only those with radios can announce. Gives "see and avoid" a bit of signficance! ;-) Neil |
On 27 Apr 2007 10:13:14 -0700, Tom wrote in
. com: I didn't feel that great about the incident: did I do something wrong? That depends on the altitudes of your and his aircraft: http://ecfr.gpoaccess.gov/cgi/t/text... .1.3.10.2.4.7 § 91.113 Right-of-way rules: Except water operations. (d) Converging. When aircraft of the same category are converging at approximately the same altitude (except head-on, or nearly so), the aircraft to the other's right has the right-of-way. (g) Landing. Aircraft, while on final approach to land or while landing, have the right-of-way over other aircraft in flight or operating on the surface, except that they shall not take advantage of this rule to force an aircraft off the runway surface which has already landed and is attempting to make way for an aircraft on final approach. When two or more aircraft are approaching an airport for the purpose of landing, the aircraft at the lower altitude has the right-of-way, but it shall not take advantage of this rule to cut in front of another which is on final approach to land or to overtake that aircraft. Why didn't I see him on final before I turned final (I specifically remember looking in that direction before turning final)? Perhaps he was so low, that his visual conspicuity was diminished against the surface clutter? |
This sounds like misinformation. What do you mean? As far as looking down final, ...the base leg is a busy period where you're rolling level, maintaining your decent, watching your airspeed, maybe adding flaps, looking for your landing point, and clearing the final approach for any other inbound. Lots of times, if you are not aware of an actual inbound, that "look" is just cursory and short of a 747 with lights on, you'll miss that traffic. Also, pilots do not always report the distances accurately. Sounds like he may have initiated a standard rate 360 and called you on roll out, which would be about 2 minutes later. But you state a 1 mile final, and approx two minutes later you were 50agl, that's a long time for a no wind 1 mile final. Good point about the look possibly being cursory. My guess is he called my half way through the turn (which was why he couldn't see me), which would be about right for a 1 minute 1 mile final at 65 knots. But again, the events you describe sound pretty routine for after hour ops at any airport under a B or C shelf. When I first learned to fly I actually avoided non-towered fields because planes seemed to pop out of the strangest places. Places I know I just looked and were empty. ;-o |
I had an opportunity to go head to head with someone once. I was in the established pattern, there were about 3 or 4 of us. I called my turn to base. Shortly after, this guy announces base. I'm looking around like my head was detached from my body. I called and asked if he really had announced base because I can't find anyone. He never answers. I'm still looking and turn final. I announce my position and he announces final. Lo and behold, there he is, about a mile away from me coming from the opposite direction. I move over to the right a bit and stop my descent. Someone told him that he was opposite the calm wind runway. He announces he's leaving the area and splits. I go around and do it all again. (Note to self: Remember that yours isn't the only pattern, there's another on the other runway) |
landing. A plane calls out that he is 5 miles for the straight in. I
replied that with the traffic, traditional pattern may be appropriate. He called that he would enter the correct pattern. -- Regards, Ross C-172F 180HP KSWI Are you working on your junior "G" man controller badge? I'd have told you to mind your own business! Karl |
On Fri, 27 Apr 2007 18:02:13 +0000, ktbr wrote:
I like to be over on the local frequency by at least 5 miles out. Even w/o being cleared, I like to at least be monitoring CTAF further out than that. However, if the frequency is busy this becomes impossible as it interferes with my ability to communicate with ATC. So it's a sometimes thing. [Why doesn't an audio panel have a "priority" mechanism, so a squelch break on com X squelches com Y (or nav X or nav Y)? Or do some have this feature?] It's a little annoying, in a way. I was just at an ASF seminar where "anyone in the pattern" was [justifiably] ridiculed. But the idea that anyone approaching the airport should be on the CTAF while still way out ignores the reality of IFR in some locations/under some conditions. - Andrew |
karl gruber wrote:
landing. A plane calls out that he is 5 miles for the straight in. I replied that with the traffic, traditional pattern may be appropriate. He called that he would enter the correct pattern. -- Regards, Ross C-172F 180HP KSWI Are you working on your junior "G" man controller badge? I'd have told you to mind your own business! Karl That is exactly what I was thinking. Who the hell is he to tell someone that doesn't give a crap about the pattern what to do! I hate the busy bodies that are always sticking their nose in there trying to disrupt people that are doing their own thing regardless of what everyone around them are doing. Why, just the other day I was at Carl's Jr and there was a big line. I thought, "I don't want to wait all this time!" and went right to the counter. Some busy body behind me told me to get back in line. I told them where they could stick it. |
ktbr wrote in :
If he was IFR its possible ATC did not clear him to go to advisory frequency soon enough, for whatever reason... maybe he did not have the airport in sight soon enough. I like to be over on the local frequency by at least 5 miles out. If he was IFR, ATC would have probably informed him there was traffic in the pattern at his destination and might have tried to wait until he had a visual before allowing him to change frequency. If he was a big plane with multiple radios (and perhaps pilots), he should have been monitoring CTAF for many more miles than 3, but he might not have been talking. He yielded and did a 360, which implies to me that he might have known the OP was there and what to expect... |
Andrew Gideon wrote in
news
On Fri, 27 Apr 2007 18:02:13 +0000, ktbr wrote: [Why doesn't an audio panel have a "priority" mechanism, so a squelch break on com X squelches com Y (or nav X or nav Y)? Or do some have this feature?] On our CNX-80's (or whatever they're called now , you can push a button to monitor the standby frequency. The selected frequency will cut off the standby frequency if both are receiving... It's a great unit... |
Erik wrote: Because straight in approaches at an uncontrolled airport disrupt the pattern that everyone is using. Perhaps if there were no other traffic at the time, it would be perfectly fine but when everyone is in line and doing their thing, someone cutting in sucks. There is a fairly large municipal airport nearby that accommodates jets and sometimes, we single engine folk have to anticipate them, but it still disrupts things. So you'll gladly adjust the size of your pattern, maybe extend an upwind or crosswind to fit somebody in the pattern because he enters it the 'right' way. But if he tries to enter on a straight in it's disrupting the pattern? |
| Thread Tools | |
| Display Modes | |
| Interesting experience yesterday | Paul Folbrecht | Instrument Flight Rules | 5 | January 2nd 06 11:55 PM |
| "Interesting" wind yesterday | Jay Honeck | Piloting | 36 | March 10th 05 05:36 PM |
| A Moment of Thanks. | Peter Maus | Rotorcraft | 1 | December 30th 04 09:39 PM |
| Looking For W&B Using Arm Instead of Moment | John T | Piloting | 13 | November 1st 03 09:19 PM |
| Permit me a moment, please, to say... | Robert Perkins | Piloting | 14 | October 31st 03 03:43 PM |
