#81
Recently, John Godwin posted:
"Neil Gould" wrote in news:nHOZh.4712$uJ6.3886 @newssvr17.news.prodigy.net: No. That detail was one of the rationales used by the CFI to make the claim. That being the case, it should be left taffic. That's how I understood it, and how most of the traffic flows. Most != all. Neil |
#82
I've flown into LNN many times for gas. The pattern should be left, unless
otherwise indicated. If you're flying out of T and G, Larry and his instructors may need some re-education. "Neil Gould" wrote in message t... Recently, Steven P. McNicoll posted: "Neil Gould" wrote in message . .. Look up Lost Nation Municipal airport (LNN). There is only a pattern altitude. Direction is up to the pilot. That's not correct. When approaching to land LNN each pilot of an airplane must make all turns of that airplane to the left . Where is that established? Apparently, you are aware of something that the CFIs and other pilots based at LNN don't know. While most of the time people fly left traffic, it certainly isn't what happens all of the time. Neil |
#83
Recently, Viperdoc posted:
I've flown into LNN many times for gas. The pattern should be left, unless otherwise indicated. If you're flying out of T and G, Larry and his instructors may need some re-education. I am a T & G member, and know that Larry doesn't need re-education. ;-) As for your "unless otherwise indicated", I'm not sure what you're suggesting. As for the instructor that made the statement, I haven't flown with him before or since, but for other reasons. I don't know if he's still with T&G. I brought this up because it is not unusual to see right traffic at LNN (non-T&G planes, btw), and I haven't heard of anyone getting busted for this (that lent credence to the instructor's statement). FWIW, I always fly left traffic at LNN, regardless of what others are up to. Neil |
#84
Neil Gould wrote:
I brought this up because it is not unusual to see right traffic at LNN (non-T&G planes, btw), and I haven't heard of anyone getting busted for this (that lent credence to the instructor's statement). FWIW, I always fly left traffic at LNN, regardless of what others are up to. Maybe these right traffic folks were taught by the CFIs you were referring to originally. To tell students that LNN is somehow exempt from 91.126 seems ludicrous. You implied that there is more than one instructor at that airport that thinks this is the case. John Galban=====N4BQ (PA28-180) -- Message posted via http://www.aviationkb.com |
#85
Recently, JGalban via AviationKB.com u32749@uwe posted:
Neil Gould wrote: I brought this up because it is not unusual to see right traffic at LNN (non-T&G planes, btw), and I haven't heard of anyone getting busted for this (that lent credence to the instructor's statement). FWIW, I always fly left traffic at LNN, regardless of what others are up to. Maybe these right traffic folks were taught by the CFIs you were referring to originally. To tell students that LNN is somehow exempt from 91.126 seems ludicrous. You implied that there is more than one instructor at that airport that thinks this is the case. I wouldn't know where the right traffic folks were taught, but if pilots are not busted for flying right traffic, what does that imply? And to be clear, I only heard one CFI say such a thing, and I have no idea whether he is still around there. Neil |
#86
On Fri, 27 Apr 2007 21:14:32 +0000, Judah wrote:
On our CNX-80's (or whatever they're called now , you can push a buttonto monitor the standby frequency. The selected frequency will cut off the standby frequency if both are receiving... Perfect. It's a great unit... Sigh I'll have to take your word on it. - Andrew |
#87
Neil Gould wrote:
I wouldn't know where the right traffic folks were taught, but if pilots are not busted for flying right traffic, what does that imply? It doesn't imply a thing to me. I don't expect FAA cops to be hanging around non-towered fields monitoring traffic patterns. The only time you usually see anyone "busted" for a violation like this is after metal gets bent. And to be clear, I only heard one CFI say such a thing, and I have no idea whether he is still around there. Gotcha. In one of your earlier posts you had referred to CFIs in the plural sense. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200705/1 |
#88
Andrew Gideon wrote in
news
On Fri, 27 Apr 2007 21:14:32 +0000, Judah wrote: On our CNX-80's (or whatever they're called now , you can push a buttonto monitor the standby frequency. The selected frequency will cut off the standby frequency if both are receiving... Perfect. It's a great unit... Sigh I'll have to take your word on it. They're marketed now as GNS-480 I believe. You might be able to find one on EBay... |
#89
Steven P. McNicoll wrote:
"Orval Fairbairn" wrote in message news
An aircraft on final has the right-of-way, big jet or 150. Not if he is 5 mile out! Distance doesn't matter. If right-of-way is an issue the aircraft on final has the right-of-way. It appears you interpret "right-of-way" to mean "the next aircraft to land". That's not what it means. Right-of-way rules come into play only if the aircraft concerned would otherwise occupy the same piece of sky, or nearly so. If you're on downwind when another similar aircraft announces a long straight-in you should be well in front of him and right-of-way shouldn't be an issue. If it's a faster aircraft then right-of-way may well be an issue so you'll have to extend your downwind to follow him. I prefer the overhead approach, so I can determine the least disruptive arrival. You approach at pattern altitude, down the runway, check for traffic on downwind and break to the downwind. That way, you are not charging into traffic turning base to final, while you are watching for the airspeed to diminish to drop the gear, wait for "gear safe" and set up landing. IMHO, the straight in ranks among the "least preferred" of approaches. There's nothing inherently wrong with a straight in approach, it is often the safest. The problem is many pilots that believe a full pattern should always be flown don't properly scan for traffic. I don't have a problem with folks flying a straight in as long as they do it well. I did have issue with the twin who's first announcement was XXXX final abeam the Cessna when I was on my 2nd pattern of my FIRST SOLO. I think he was low and in the ground clutter when I looked up final. About 30 seconds after he announced I say him shoot past me and well below. When I was a student the other thing that bothered me a lot was the instrument guys coming in on straight in and they were playing strictly by the books, but I had NO idea what Rikki inbound meant. 5 miles out on a straight in would have made so much more sense to me! Margy |
#90
Margy Natalie wrote:
Steven P. McNicoll wrote: "Orval Fairbairn" wrote in message news
An aircraft on final has the right-of-way, big jet or 150. Not if he is 5 mile out! Distance doesn't matter. If right-of-way is an issue the aircraft on final has the right-of-way. It appears you interpret "right-of-way" to mean "the next aircraft to land". That's not what it means. Right-of-way rules come into play only if the aircraft concerned would otherwise occupy the same piece of sky, or nearly so. If you're on downwind when another similar aircraft announces a long straight-in you should be well in front of him and right-of-way shouldn't be an issue. If it's a faster aircraft then right-of-way may well be an issue so you'll have to extend your downwind to follow him. I prefer the overhead approach, so I can determine the least disruptive arrival. You approach at pattern altitude, down the runway, check for traffic on downwind and break to the downwind. That way, you are not charging into traffic turning base to final, while you are watching for the airspeed to diminish to drop the gear, wait for "gear safe" and set up landing. IMHO, the straight in ranks among the "least preferred" of approaches. There's nothing inherently wrong with a straight in approach, it is often the safest. The problem is many pilots that believe a full pattern should always be flown don't properly scan for traffic. I don't have a problem with folks flying a straight in as long as they do it well. I did have issue with the twin who's first announcement was XXXX final abeam the Cessna when I was on my 2nd pattern of my FIRST SOLO. I think he was low and in the ground clutter when I looked up final. About 30 seconds after he announced I say him shoot past me and well below. When I was a student the other thing that bothered me a lot was the instrument guys coming in on straight in and they were playing strictly by the books, but I had NO idea what Rikki inbound meant. 5 miles out on a straight in would have made so much more sense to me! Margy I was taught to make calls based on distance rather than approach fix when practicing approaches in VMC at an uncontrolled airport for just this reason. Matt |
| Thread Tools | |
| Display Modes | |
| Interesting experience yesterday | Paul Folbrecht | Instrument Flight Rules | 5 | January 2nd 06 11:55 PM |
| "Interesting" wind yesterday | Jay Honeck | Piloting | 36 | March 10th 05 05:36 PM |
| A Moment of Thanks. | Peter Maus | Rotorcraft | 1 | December 30th 04 09:39 PM |
| Looking For W&B Using Arm Instead of Moment | John T | Piloting | 13 | November 1st 03 09:19 PM |
| Permit me a moment, please, to say... | Robert Perkins | Piloting | 14 | October 31st 03 03:43 PM |
